haha back to the bike.. the extended swing arm looks cool but it looks like it would sag if you sat on it because it already sits low.. maybe im blind. I think it would look even cooler if you adjusted those shocks and raised the ass end up a little to compensate for some compression once you sat down.. No? Also, no go on the back fender UNLESS you matched the front fender with something similar.
i can only imagine the amount of Asian porn in your collection...
I used longer shocks so actually the bike still sits at the stock height. I have almost 3" before the fender would bottom out on the frame. Also, Illinois roads can get pretty rough so I always keep the shocks at their softest setting. Havent bottomed yet. and the fenders are pert near identical. the front is the stock 69 350..cut down. and the rear is the original 76 360 front.
So that's why you went with the brat seat! No room for sluty Asian girls with a cafe seat bump! Good thinking! Lol
Ahhh i see now. Hard to tell in the pictures sometimes. You should have went a little longer with the swinger and then stuffed a NOS bottle in the gap between the tire and the "u" of the swing arm... why now? All the Busa guys do it
You read my mind!!!! I wanted to get a small NOS bottle. cut the top off, add a hinge and clasp and use it for my tool box!!! tucked right in the swing. If i could find a used one cheap enough I would do exactly that!!!
