Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: Sachs 650 Street tracker/ Now with video !!!!!!  (Read 10882 times)
Offline jeff4uk
    • 71 triumph T100c
Re: Sachs 650 Street tracker/ fork brace/back light
« Reply #45 on: Oct 12, 2011, 04:39:14 »
AAAAAAAA gotcha, No this idea has been ditched to a straight through and use K&Ns and hide the reg under the seat, the seat on it as in this pic is the duel seat and im fabing up a single  at the moment (cant use a standard tracker seat there to narrow at the tank end for this frame and it kicks up at the back after 6 inches)
Any more obs and il be pleased to here them
Cheers
Offline jeff4uk
    • 71 triumph T100c
Re: Sachs 650 Street tracker/ No more air box / single seat fabbed
« Reply #46 on: Oct 15, 2011, 14:33:22 »
So spent today on the bike (wife was out) rear wheel has to come out to ditch the air box !!!!
and i fabbed up my single seat (spayed it to stop it going rusty and to give me an idea of colour view)
Offline jeff4uk
    • 71 triumph T100c
« Reply #47 on: Oct 15, 2011, 14:36:07 »
put in a bit of body filler over the welds
Offline peteGS
  • Zuk's Rock!
« Reply #48 on: Oct 15, 2011, 19:34:29 »
Mate well done! That should work nicely.
Can I suggest one little addition though? Maybe fab up a little trim piece for either side that extends from the front of the seat under the tank a bit to blend it in a little? Just to get rid of that very obvious step from tank to seat... just a suggestion though, that tail piece is a great shape :D
'82 Suzuki GS450E Scrambler - Back on the road after nearly 10 years!
http://www.dotheton.com/forum/index.php?topic=28302.0
1949? Ducati Cucciolo T2
http://www.dotheton.com/forum/index.php?topic=37749.0
Offline jeff4uk
    • 71 triumph T100c
« Reply #49 on: Oct 16, 2011, 10:18:09 »
Thanks pete, ya this was always gonna be challenge to get this idea to flow with the tank, because of the shap of the frame under the tank, I may try exstending the flange at the base of the tank just to tayper it in???
Offline peteGS
  • Zuk's Rock!
« Reply #50 on: Oct 16, 2011, 16:47:21 »
Actually yeah that should work! Extend it down from the very front of the tank so it's just a gentle slope back, and if you can extend the white area down a bit that should help blend it in so it looks natural too...
Offline jeff4uk
    • 71 triumph T100c
Re: Sachs 650 Street tracker/ tank flange fabbed
« Reply #51 on: Oct 22, 2011, 07:00:51 »
Man that was a flaff!!! Thats the best i can do ,Im happy with the result and with a pro paint/filler job at Daytona paint will look smooth
Need to tidy up wiring now and fit the K&Ns
« Last Edit: Oct 26, 2011, 04:38:00 by jeff4uk »
Offline peteGS
  • Zuk's Rock!
Re: Sachs 650 Street tracker/ tank flamge fabbed
« Reply #52 on: Oct 22, 2011, 18:23:08 »
Perfect! That makes the tank flow nicely to the seat and tail, just what the Dr ordered  ;D
Offline jeff4uk
    • 71 triumph T100c
Re: Sachs 650 Street tracker/ shocks and bits and bobs
« Reply #53 on: Oct 28, 2011, 16:41:13 »
So im trying some other shocks (not bad !) Fitted the horn,indis and thorttel cable and trying to tidy up the back of the two seats ill be useing
the holes from the frame cut off will be filled in and painted black, ?????????????
Offline peteGS
  • Zuk's Rock!
« Reply #54 on: Oct 28, 2011, 17:47:49 »
Definitely getting there, and those shocks look the goods!
As for the open frame ends, I've seen that done two ways.
One is to weld a circular steel cap on.
The other is to use those plastic rubbery bits they put on the bottom of round steel chair legs, although I'm guessing you want a perfect fit with those or some glue so they don't fall out while riding.
Offline jeff4uk
    • 71 triumph T100c
Re: Sachs 650 Street tracker/ K&Ns/Seat ends
« Reply #55 on: Nov 11, 2011, 15:09:56 »
Progress is slow now but the K&Ns came so there on
Also fabbed the seat ends, One the single seat i welded it on but on the duel seat this end  bolts onto the frame via the washers inserted into the cut off holes
Offline peteGS
  • Zuk's Rock!
« Reply #56 on: Nov 11, 2011, 16:22:59 »
Nice work! And don't worry about slow progress. Slow progress is better than no progress  ;)
Offline jeff4uk
    • 71 triumph T100c
« Reply #57 on: Nov 11, 2011, 16:52:28 »
true mate very true.
Offline Erskine
« Reply #58 on: Nov 11, 2011, 17:03:46 »
Just have to say how much I like that frame of yours. Got a great design pedigree :)
Offline jeff4uk
    • 71 triumph T100c
« Reply #59 on: Nov 12, 2011, 09:56:55 »
Thanks Erskine ,here;s a vid of it up and running
Sounds well loud in real life !!!
