Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.townmoto.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: CB350 - Project One (Complete...)  (Read 5643 times)
Offline axeugene27
Re: CB350 - Project One (Paint, waiting on Powder)
« Reply #45 on: Jun 18, 2012, 21:37:04 »
dang those wheels look nice. Amazing what a difference they make.
72cb350 barn burner build http://www.dotheton.com/forum/index.php?topic=37654.20
"it's better to have an ugly bike that runs well, than an pretty paperweight."
"bullshit goes a long way if you throw it right"
Offline axeugene27
« Reply #46 on: Jun 18, 2012, 21:38:34 »
who is buying you vintage motorcycles for your b-day wish my wife would get with that program.
Offline axeugene27
« Reply #47 on: Jun 18, 2012, 21:42:57 »
did you paint the rims yourself how did you even get the red stripes is it tape?
Offline SeaBee
Re: CB350 - Project One (Rolling...)
« Reply #48 on: Jun 19, 2012, 00:11:59 »
Thanks for the compliments on the wheels!  I'm stoked by the way they turned out!  Sometimes picturing something in your mind looks better than it turns out in reality.  Luckily, I think this one worked out.
The rims are powdercoated and then the stripe was painted on.  The red on the wheels is the same as the red on the seat and tank.  Hopefully I'll be able to post pics of everything together after I get the bike wired.
Haha!!  My wife bought it for me.  She knew what I was after, but also knew that she had no idea what she was looking for.  So I found it and went and picked it up.  Very excited about that bike, but nervous about the massive amount of work its going to take...  This 350 has to be running and on the road before the first wrench turns on that one!
Offline Rocan
  • Site Supporter
  • "Long after I rest, my steel will live on"
« Reply #49 on: Jun 19, 2012, 00:26:45 »
looking good, but that brace between the rear shock towers is going to contact the tire. not safe at all.
PJ- Cafe's don't really work right until you get rolling 70mph +
Honda CB350 Project- www.dotheton.com/forum/index.php?topic=8643.0
Honda C100 Restoration- www.dotheton.com/forum/index.php?topic=38653.0
Offline 1chrisb
Re: Re: CB350 - Project One (Rolling...)
« Reply #50 on: Jun 19, 2012, 01:00:06 »
What he said.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Offline SeaBee
« Reply #51 on: Jun 19, 2012, 09:11:38 »
Nice looking out!  Get so excited to put it back together, I can easily over look things.
Definitely not safe...  :(
Offline DBC
« Reply #52 on: Jun 19, 2012, 09:24:31 »
I'm not so sure about that.  He's got a good bit of space, but I don't know how much travel is in those shocks.  looks to me like it might clear.    My only concern is that those look to be uni-directional tires and they are facing the opposite direction.  It looks like the front may be backwards?  Or I could be completely wrong...my 2 cents.  Otherwise, this thing is looking great! love the accent stripe on the wheels.  Keep it up, I'm looking forward to what this thing turns into.
Offline DBC
« Reply #53 on: Jun 19, 2012, 09:27:39 »
then again, I didn't notice it was up on the stand.  It probably is too close. Good call Rocan
Offline DoTheJon
  • surfing and motorcycles.... yup
« Reply #54 on: Jun 19, 2012, 09:56:57 »
Tires are on right. i have the same avons and thats the correct mounting.
My CB360 Barn find http://www.dotheton.com/forum/index.php?topic=29298.20
“America is all about speed. Hot, nasty, badass speed.”-Eleanor Roosevelt, 1936
Offline DBC
« Reply #55 on: Jun 19, 2012, 10:13:52 »
Well in that case, rock on 8)
Sent from my PC36100 using Tapatalk 2
Offline SeaBee
« Reply #56 on: Jun 19, 2012, 10:31:03 »
Avons always look like they're mounted backwards on the front, but they're mounted correctly.
Measured the distance from the tire to the brace at 3.1 inches.
Eye to Clevis on the shocks is 13 in.
Anyone know the full compression length of these shocks?
Couldn't find the info online yet.  I do know that these MDI shocks are stiff and full compression may or may not happen, but not a risk I really want to take.
From looking at Hagon's website as some sort of reference, their shocks full compression is between 50-80mm or 1.96-3.14 in.
I need to test the full compression of these shocks, but if I move up to a 14" eye to clevis I may be able to clear.
Ideas, suggestions??
« Last Edit: Jun 19, 2012, 10:49:59 by SeaBee »
Offline SeaBee
« Reply #57 on: Jun 19, 2012, 13:25:50 »
Damn Rocan!  Now this is all I'm thinking about today!  ;D
So I'm going to fully compress these springs on the bike to see what happens and before I order another set.  It may never contact the brace, but I have to be sure and can't leave it up to hope and chance.
I'm going to measure it again when I get home since I measured it this morning sitting on the center stand.  But with the stiffness of these springs, I'd say the distance from the tire to the brace is the same whether its on the stand or not.
Looking at Hagan's website along with a few others, their 335mm shock has an extended length of 13.2" and full compression at 10".  If I jump up to the 360mm shock I'll have 14.2" extended and 11" compressed.  Looks like I need to remove these shocks and measure the distance between the shock mounts at contact...
Offline ducatiboy
« Reply #58 on: Jun 20, 2012, 08:23:29 »
Support the bike under the engine. Remove shocks from bike. Remove springs from shocks. Replace shocks minus springs onto bike. Check the clearance of rear tyre by lifting the wheel until shock is fully compressed. With the springs removed you will only need to lift the weight of the wheel (which is hard enough but can be done...use a jack and jack it up if you need to).
Just another CB350 cafe (current project) http://www.dotheton.com/forum/index.php?topic=32827.0
In the garage:
Ducati 848 Road bike
Ducati 848 Track bike
Ducati 750 F1 x 2 (next 2 projects)
Honda XL 185 paddock basher (complete)
Honda XL 185 Paddock basher (in pieces)
Offline axeugene27
« Reply #59 on: Jun 20, 2012, 11:21:53 »
good advice duc boy. That said it sucks getting those shocks back together i was pretty red in the face compressing those bad boys.
