Author Topic: Engine inspiration thread!  (Read 173000 times)
Offline JRK5892
    • The Powder Pro
Re: Engine inspiration thread!
« Reply #50 on: Oct 04, 2011, 17:58:11 »
i have ground them out, used JB weld, and even body solder as it is easy to sand and work... body filler would prob not hold up due to temp changes and vibrations... i would go solder or jb weld
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline beachcomber
  • TJ - Beachcomber
« Reply #51 on: Oct 04, 2011, 18:58:14 »
Yea, I think you confirmed what I was thinking Joe - cheers.
I'm aiming for something like this [ courtesy Turbodog ] but using satin Black with barrel and head fins filed.
It's the Yamaha script I want to lose - probably be replaced with a "Vindicator" logo.
« Last Edit: Oct 04, 2011, 19:11:45 by beachcomber »
Offline beachcomber
  • TJ - Beachcomber
« Reply #52 on: Oct 05, 2011, 05:07:53 »
BC...bog will crack as will epoxy.  Weld is the only permanent solution.  Cant speak personally for Yamaha...but the metal they use cant be any worse than Honda's and it welds just fine.
Thanx Rev - that's the info. I wanted. I'm only going to do this once [ well twice actually - 2 bikes to build ] !! I was just a bit concerned about the quality of the alloy castings.
I've got nothing against the Yamaha name - but for a 60's inspired Cafe Racer that does scream out a bit !
Offline beachcomber
  • TJ - Beachcomber
« Reply #53 on: Oct 20, 2011, 12:56:33 »
C'mon guys - I need some MORE inspiration....................
Offline maddrill24
« Reply #54 on: Oct 20, 2011, 21:56:50 »
i've been waiting for new piston rings so i got "ballsy" and notched out the fins. it came out awesome. it took about 3 hours. used a small machinist file and a dremel with a ball shaped bur bit. full engine pics will be up soon.
Offline Hoosier Daddy
  • Earache my eye...
« Reply #55 on: Oct 20, 2011, 22:04:47 »
Guiness has a new "Black Lager" out. ;)
STAY CLEAN '67 BSA Spitfire
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
NO CLASS '72 CB450 K5
Offline beachcomber
  • TJ - Beachcomber
« Reply #56 on: Oct 21, 2011, 06:24:16 »
It's the consumption of excess alchohol that has been the starting point for MANY projects over the years !
Offline HerrDeacon
« Reply #57 on: Oct 21, 2011, 08:59:08 »
Mmmmmmmm, going to have to check that out.
Perry
1972 Honda CB350 K4 / 1978 Honda XL250S /1982 Honda MB5 / 2014 Honda CB500X
Offline JRK5892
    • The Powder Pro
« Reply #58 on: Oct 21, 2011, 10:28:52 »
that looks baller man! really dig it!
Joe
Offline teazer
« Reply #59 on: Oct 21, 2011, 13:28:09 »
Color - we don't need no stinkin' color.... Au naturel is the way to go
That one is a CL175 sloper more or less stock with minor modifications. Small can be beautiful too.  Those are 26mm Keihin carbs and under the alternator cover is a single Dyna trigger on a shortened crank nose and it still whips. Stock crank, lightened rockers, modified pistons, lightened valves, light tappet adjuster screws, Megacycle street cam. Now makes around 21hp @ just over 11k and stock it made around 11hp at the rear wheel  and we thought it ran pretty well at that.
« Last Edit: Oct 21, 2011, 13:31:53 by teazer »
