Author Topic: CB360 Carb swap and sync  (Read 12622 times)
Offline MiniatureNinja
Re: CB360 Carb swap and sync
« Reply #10 on: Apr 26, 2018, 18:16:22 »
'Bumping' this to top since I saw someone is looking for it
thanks, I wasn't looking but I'm glad I came accross it!
'75 Honda CB360 - thread
Offline crazypj
« Reply #11 on: Apr 28, 2018, 23:43:11 »
It's amazing the stuff you find when not looking, I know I've wasted hours watching Russian 'driver' video's  ;D
Best thing I ever overheard
Brian Morgan, 1982
Offline crazypj
« Reply #12 on: May 02, 2018, 07:48:44 »
Because of truck issues, I've been looking up Lambda sensors. (O2 sensor)
Even though it doesn't apply to stock 360s (or modified ones really) this is the best video I've ever seen explaining how they work and what they do. It will be of interest to anyone fitting one to older bike. Gives some good information , particularly about NOT using dielectric grease in connectors (lot of bad advice out there about stuff like that)
BTW,. you only need to watch about first 30 mins, the rest is on actual vehicles so pretty worthless to 'us'
« Last Edit: May 02, 2018, 09:48:29 by crazypj »
Brian Morgan, 1982
Offline CrabsAndCylinders
« Reply #13 on: May 03, 2018, 22:45:04 »
Those vids give me the chills!
Lighter, Quicker, Faster.
Offline crazypj
« Reply #14 on: May 12, 2018, 16:05:34 »
After watching the Common Motor Collective video where Brenden uses sealer on carb vacuum chambers I thought I should add this as correct way to make sure you don't have air leaks. DO NOT USE SEALER ON CARBS
Just a few pictures with some explanations .1. Things you need. Carb, Sharpie, flat surface (using a marble floor tile, not everyone has a surface plate) and 220 grit 'WetorDry' 2. Use marker around outside top edge of carb body.. 3.Rub top on wetordry ,shadow still visible between screws.  4.Check surface is flat,pointer doesn't show it too well but just below it is still 'shadow', very common to find as much as 0.030" distortion. 5. when it's all smooth and flat your done. Note - Do the steel tops first as it cut down the 'bite' of sandpaper, they always need doing. If you need a flat surface, anywhere that does marble or granite counter tops should have several pieces where they remove area for sink. It is more than accurate enough for this
« Last Edit: May 13, 2018, 13:34:00 by crazypj »
Brian Morgan, 1982
Online trek97
« Reply #15 on: May 12, 2018, 23:04:27 »
+1.  Nicely done.
Offline crazypj
« Reply #16 on: May 13, 2018, 13:36:28 »
I was going to add link into video replies but gaven't been on You Tube yet
Brian Morgan, 1982
« Reply #17 on: May 13, 2018, 18:01:57 »
Thanks, good idea.
Offline crazypj
« Reply #18 on: Jul 31, 2018, 20:16:36 »
I thought I had picture of correct angle to setfloat level but apparently not here. Just took a pic for a different thread but it's just right for this as well. This is set I just got to work on, will be cleaned and modified then re-set to 21mm for CB360
Brian Morgan, 1982
