Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
GET DTT UPDATES ON
FACEBOOK
AND
TWITTER
Home
Forum
Help
Login
Register
DO THE TON
Blood Sweat Tears and Grease
Projects
Restorations
(Moderator:
Sonreir
1921 ajs 350 start
GET DTT UPDATES ON
FACEBOOK
AND
TWITTER
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: 1921 ajs 350 start (Read 3452 times)
VonYinzer
Site Supporter
We go where eagles dare...
Re: 1921 ajs 350 start
Reply #15 on:
Dec 12, 2011, 22:59:20 »
Love it.
Logged
If you want a vision of the future, imagine a boot stamping on a human face - forever.
George Orwell
joea
Reply #16 on:
Dec 15, 2011, 15:13:32 »
too bad it does not have the double chain and peddles system as it may make a good down hill mountain bike too! ha ha joe @ vcycle
Logged
joe @vcycle
www.joesvcycle.net
blog:
www.joesvcycle.wordpress.com
joea
Reply #17 on:
Dec 21, 2011, 22:32:12 »
polished both engine and gearbox cases...the crankshaft was rebuilt a few years ago with a new outer main bearing race due to corrosion. fortunately at the time i was still at the airlines and i had the machine shop fabricate the bearing race for me....
then built up and trued ...ready for assembly if i can figure out and find all the hardware and parts...ha
Logged
joe @vcycle
www.joesvcycle.net
blog:
joea
Reply #18 on:
Dec 21, 2011, 22:32:50 »
3 speed hand shift gear box polished and assembled.
Logged
joe @vcycle
www.joesvcycle.net
blog:
martyman
Reply #19 on:
Jan 02, 2012, 17:12:43 »
I really dug that video
Logged
joea
Reply #20 on:
Jan 04, 2012, 13:45:51 »
hi marty,
no thanks to me-ha ha ...my son did it for me and said it was fun so hopefully we can do more in the future..
i had a chance to drill the front hub rivets and shim the hub so the run out was better and installed new hardware and toqued it up ...now i have to remove the damaged paint and repaint it, then rebuild and true the wheel.
i also have to remake the lh main al/bronze bushing as the fit in the case is not tight enough. i have no more material so i think i am going to make a sleeve for the bushing od!
joe
Logged
joe @vcycle
www.joesvcycle.net
blog:
tv321406
Reply #21 on:
Jan 19, 2012, 22:15:00 »
this is aawesome! please dont add a cafe seat and clubamans tho!!!!
Logged
joea
Reply #22 on:
Jan 25, 2012, 20:50:39 »
got a roller!
tore down the front wheel drilled the rivets and decided to shim the hub instead of trying to straighten the flange as i was worried it might crack....it shimmed up fine, repainted urethane and laced built up front end....i still have to make a sleeve for the main bushing when i get a chance....take it easy, joe@ vcycle
Logged
joe @vcycle
www.joesvcycle.net
blog:
joea
Reply #23 on:
Feb 20, 2012, 12:45:06 »
had to true the crankshaft, make a new lh bushing and line ream it. assembled cases and installed in frame.had to make three engine bolts from s/s all thread - all s/s mount bolt hardware was glass beaded to match the cad plating of the other hardware.
the kick spring i made up a while ago had to be bent and trimed at the end attach points. i still have to cut the kick shaft and machine a step in it for the kick arm but i need to see what kind of clearance i need for the exhaust system which i have not made yet.....
joe
Last Edit: Feb 20, 2012, 12:46:50 by joea
Logged
joe @vcycle
www.joesvcycle.net
blog:
joea
Reply #24 on:
Feb 20, 2012, 12:47:51 »
shimming the primary gears to align chain/sprockets
Logged
joe @vcycle
www.joesvcycle.net
blog:
joea
Reply #25 on:
Feb 20, 2012, 13:12:55 »
modern high tech tail light.........lucas acetylene light
joe@ vcycle
Logged
joe @vcycle
www.joesvcycle.net
blog:
ProSimex
Site Supporter
RUN SCREAMING!!!
Reply #26 on:
Feb 20, 2012, 15:06:12 »
This is just too damn cool
Logged
"Love is the feelin you get when you like something as much as your motorcycle."
"That's got CV's? Take a #2 phillips screwdriver, heat the tip with a torch until cherry red and plunge it into your eye. It will hurt less. Really."- Kopcicle
joea
Reply #27 on:
Mar 02, 2012, 17:42:10 »
lucas tail lt mounted
after another week of fabricating a few parts
rh side......now on to making magneto spacer block and a vernier adjuster for the timing sprocket.....have a good weekend,joe
Last Edit: Mar 02, 2012, 17:46:25 by joea
Logged
joe @vcycle
www.joesvcycle.net
blog:
56_oval
Reply #28 on:
May 03, 2012, 06:40:49 »
That is one hell of a good looking bike. Good job there brother...
Logged
http://www.facebook.com/CityofHateVintageCustoms
andycafe
If you don't want anyone to know, Don't do it!
Reply #29 on:
May 03, 2012, 08:15:13 »
this is cool as all hell!
Logged
Honda CB250rs cafe (Current project)
Honda CB400f brat (Next project)
The New Bike Thread
The workshop & deck build
If you can't fix it with a hammer, You've got an electrical problem mate!
Print
Pages:
1
2
3
Go Up
« previous
next »
DO THE TON
Projects
Restorations
(Moderator:
Sonreir
1921 ajs 350 start
