Maritime
Over 10,000 Posts
OK so I need some help to diagnose an issue, or at least a starting point. Need to fix it by Friday to sell it to get to barber.
1982 CB450T Honda. Was running super fine but the headlight was flickering on and off. Traced all the wires and cleaned everything and found out the filiment was broken but not burned otu so it was on and off. New bulb, fixed it.
Now went to start it up and it won't fire??? What I checked so far:
Fuses all good
Petcock flows fuel, fuel in carb bowls
changed oil as it was milky
check valves, in spec no issues there
charging battery as we speak.
pulled plugs and have spark at each when I hit the starter button
Put new plugs in too as the ones in the bike were pretty old and worn
I don't have a compression tester but did the thumb over hole trick and it blows off so there is enough to run at least.
So my guess is fuel or carbs, but what could change for this to happen all of a sudden?
Bike just turns over and over without a hint of firing?
It is a CDI bike, one coil with 2 wires, could the CDI fail yet still give spark? I am going to pull the carbs tonight to make sure there is nothing funny there but I am kind of stumped.
Any help would be much appreciated, What might I be missing?
Fuses all good
