Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: Out in a field Build ... XS 500 The Sock Monkey  (Read 21957 times)
Offline DreadRock
  • Site Supporter
  • Bang Cut Grind ..Dam Did I Need That Part ?
Re: Out in a field Build ... The Sock Monkey
« Reply #165 on: Jun 04, 2012, 11:50:47 »
Thanks man hopin to get it all work out ! Now was told a few things to think about which are good points. These are just a mock up and are a long way to getting right and spaced right. The spacers and getting everything centered right still needs to be worked out and mounting needs to be tweaked to fit right and functional .
Offline DreadRock
  • Site Supporter
« Reply #166 on: Jun 08, 2012, 22:57:42 »
Thanks Guys !
   Small update : Got the small parts to rebuild the kickstarter also waiting on a order from Dime City.As for the brake set up going to start on the back and get it all done first . Will be starting with getting the hanger and caliper mounted . Then will get the spaceing for the rotor and center of the caliper . Ordered all the metal to make front and back spacers : 1 3/16 303ss round stock , 6 1/2 ''x 1 1/2 , 4"x 1 1/2 round stock 6061 . Will pick it up monday and take it right to the machinist to get started . Once the rear is done and buttoned up will move on to the front .
Offline Maritime
« Reply #167 on: Jun 09, 2012, 11:24:58 »
Nice.  Cant wait to see this thing in person.
Sent from my MB525 using Tapatalk 2
My Build: My full figured girl: http://www.dotheton.com/forum/index.php?topic=13950.msg135199#msg135199
Offline DreadRock
  • Site Supporter
« Reply #168 on: Jun 11, 2012, 19:31:56 »
Picked up all the metal for the spacer ....
Offline JustinLonghorn
  • Site Supporter
« Reply #169 on: Jun 11, 2012, 19:58:57 »
Huzzah!
"Art is never finished, it is only abandoned."
"Motorcycles do not define a person's character." -BigRich
My Dearest Darling -Sold
CB400F
Offline SeekingZero
    • Seeking Zero
« Reply #170 on: Jun 13, 2012, 02:33:53 »
Nice work.  I like the attention to detail.  Subscribed.
"We make our world significant by the courage of our questions, and by the depth of our answers." - Carl Sagan
CB175
My Site
Offline gentlemanjim
« Reply #171 on: Jun 14, 2012, 00:43:33 »
Well done and such great attention to detail.  Very ambitious getting the modern brake set up to work.  What did you use for the carbon fiber look panels on the seat cowl?
"More Wrenching than Riding"
Offline DreadRock
  • Site Supporter
« Reply #172 on: Jun 14, 2012, 09:59:09 »
Thanks guys ! It very simple i used CF sheet tape to make them .
 OK so all has been going smooth as much as you can say that on a build no big hicups ! If you have read my thread didnt mess with the motor other then new gaskets and valve adjustment . Got the motor to run and everything NPs > Then just pulled the motor and set it to the side to have the frame PCed. Got that back and but the motor back in again NP as i buttoned everything up. So I know it started with the E button and when i put the motor in the kicker worked . So here comes the kick in the teeth moment !!!!!!! I was tighting the main bolt on the front sproket and as i was it turned the motor over backwards !!! Now I have read that could be a very bad thing  ! So now when the kicker is pushed down theres NOTHING just some resistance . There are no grinding sounds or anything and goes thru the stroke smooth . Then i checked to see if its even turning the motor over and its not . So then took the valve cover off to have a look and seemed to me that the kicker was not engageing the motor .
  So jumped online to have a look at how the kicker engages the motor and there is a larger gear that sits on a worm gear . I m thinking that maybe by the motor going backwards a lil it might have slide the larger gear off of the smaller one . Which if it did will have to pull the motor and pull it apart which im very pissed at myself if thats the case.
Now im not 100% this is the problem going to do some more looking and reading and asking dumb things . Im hoping that its more simpler then im thinking ( Plan for the worst hope for the best ) but if anyone can help out as to what i might have done or what to look at befor i pull it all down would be great !!!!!!
Offline Maritime
« Reply #173 on: Jun 14, 2012, 10:46:59 »
hmm, I would hope the little bit you moved it backwards would be no worse then rocking back and forth in gear to find neutral?  How much backwards?  Can you shift in into gear and roll it and then go back into neutral and check the kicker again?  They are designed to disengage after starting and maybe that happened and you need to move it a bit to re-set it?  All therory here as the only kick start bike I have worked on is a honda 50 clone.  Good luck, I am sure someone with more yamaha knowledge will chime in,
Maritime
Offline DreadRock
  • Site Supporter
« Reply #174 on: Jun 14, 2012, 11:21:24 »
Yep tried that bud had NP going to neutral or back into gear . Played around with it to see if that would work and nothing . As for how many times it rotated backwards as i was tighting it think it 1 -1 1/2 turns which by the look of a blown up pic could very well spin that gear off the worm gear .
  Was thinking well the E button works could just run it with out a kicker BUT i put way to much time and everything into making this bike and can see it now " I start it up and something that was a pain but could be fixed just " F ed " the motor all up and have to do a total rebuild not just a pull the motor apart and slide a gear back in place " If it comes down to one or the other will pull it apart to fix it first !
 Going to go at it very slow and look at simple things first then "IF" the fix is in the motor will pull it even if keeps the bike off the road till next year GRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!!!! or till i get it done !
  As for mid-ohio which i really wanted to take it to which was my goal will ride the victory or drive ! NOTHING WILL STOP ME LOLOLOLOLOL
P.S THIS SUCKS !
Offline Maritime
« Reply #175 on: Jun 14, 2012, 11:28:52 »
Yes it does. I have been there with the GL, just before Barber I get new points, in a hurry to time so I leave plugs in, set Timing, new points + correct timing equals way better running bike, little did I know my high compression engine allowed me to overtorque the alternator bolt and shear threads off.  I went to do belts about a week before the 2000 mile ride and the bolt was dangling out of the engine.  That meant pulling the motor to fix!  It sucked, and I had to cage it to barber, but live and learn. I hope you can fix this without having to pull the motor.
Offline DreadRock
  • Site Supporter
« Reply #176 on: Jun 14, 2012, 11:53:37 »
Thanks man ! Guess i can look at it this way, if i cant get it done by Mid-ohio can carry a LARGE cooler full of fun lol With a trailer just in case me or someone finds something they cant go with out LOL  ;D
 And yes sir its a learning thing which isnt always bad just no fun !
  • Site Supporter
« Reply #177 on: Jun 14, 2012, 12:35:46 »
This sucks, man. But, even if you have to pull the motor, you can still get this sucker done in time for Mid-Ohio.
CB400F
Offline two-smoker
  • I reject your reality, and substitute my own!
« Reply #178 on: Jun 14, 2012, 12:52:55 »
I kind of screwed up my kicker install, and when I cranked the motor over for the first time with the e-start, the kicker went down through its stroke by itself and whacked me in the shin.... Not fun. The motor spun over fine with the kicker and it returned to the top of its stroke just fine until I used the electric leg. Turns out I had the spring installed wrong.
 Long story short, see if cranking it over with the electric leg clears up the problem before you open her up again. Having the extra speed of the electric start may just knock her right back into place.
"I suppose I'd say.... BOLLOCKS! But that's pretty much a reflex for me...."
1973 Yamaha TX500- project Shinjimei
2010 Hyosung GT250R
Offline DreadRock
  • Site Supporter
« Reply #179 on: Jun 14, 2012, 12:57:31 »
Im going to try my friend ! Going to start tonight with a few things and work from the kicker in and see what happens . Have the week of the july 4th off so i hope will have it done by then !
   First thing will try is make sure i look over everything out side motor to make sure im not missing anything . And if that dont work will drain the oil and pull the clutch cover off and see whats there and if anything is disengaged and if i need to go deeper into the motor will pull it out of the frame and pull The monkey motor apart . It sucks because i will have to spilt the case to get to it .
