Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
GET DTT UPDATES ON
FACEBOOK
AND
TWITTER
Home
Forum
Help
Login
Register
DO THE TON
Blood Sweat Tears and Grease
Projects
Cafe Racers
(Moderator:
Sonreir
Out in a field Build ... XS 500 The Sock Monkey
GET DTT UPDATES ON
FACEBOOK
AND
TWITTER
« previous
next »
Print
Pages:
1
8
9
10
11
12
13
14
15
16
17
18
34
Go Down
Author
Topic: Out in a field Build ... XS 500 The Sock Monkey (Read 20723 times)
MotorbikeBruno
Re: Out in a field Build ... The Sock Monkey
Reply #180 on:
Jun 14, 2012, 13:13:39 »
I wish you good luck sir! I bet you'll get it fixed up in no time!
Logged
Self-proclaimed Carburetor Enthusiast
CB500 tracker project
http://www.dotheton.com/forum/index.php?topic=43859.msg477545#msg477545
My KZ550 build
http://www.dotheton.com/forum/index.php?topic=21275.new#new
The CBR600 F1 build
http://www.dotheton.com/forum/index.php?topic=38281.new#new
axeugene27
Reply #181 on:
Jun 14, 2012, 13:19:46 »
interested to see how this plays out. I went to kick over my bike the other day and it felt like i just put it into a pile of mud Really weird. Drained the oil and refilled it. Seems that there was too much oil in the engine somehow.....may have been me idk. Seemed to self resolve after draining some of the oil out. very tight looking machine btw.
Logged
72cb350 barn burner build
http://www.dotheton.com/forum/index.php?topic=37654.20
"it's better to have an ugly bike that runs well, than an pretty paperweight."
"bullshit goes a long way if you throw it right"
DreadRock
Site Supporter
Bang Cut Grind ..Dam Did I Need That Part ?
Reply #182 on:
Jun 14, 2012, 17:42:50 »
So im all pissed at work and all i can do is think of what the problem is and what to do. As i said i most always " Plan for the worst and hope for the best " well might turn out to be the best . I said fuk it and took the rest of the day off to go home and work on the bike . So after sitting and thinking what could it be and what did i do last from when it worked to when it didnt i came up with the clutch engage /disegage arm . I Drained the oil and pulled the started side cover off which the arm is bolted to and there you have it !!!!!!! Works like it should so now am thinking that the clutch was half engaged half out . Now im going to look around and see if thats was it 100% or only 80% . So if it turns out to be just the arm is messed up will fix or replace and go from there !!!!!!!!! We will see and thanks guys for all the help !!!
Logged
'07' Victory Hammer
'85' FJ1100
1972 LS2 100 build ....
http://www.dotheton.com/forum/index.php?topic=40717.01975
1975 XS500 Build....
http://www.dotheton.com/forum/index.php?topic=29668.msg318711#msg318711
MotorbikeBruno
Reply #183 on:
Jun 14, 2012, 18:16:08 »
NICE!!!!
Logged
My KZ550 build
The CBR600 F1 build
axeugene27
Reply #184 on:
Jun 14, 2012, 18:17:11 »
hmm i recently adjusted my clutch as well maybe on to something here.
Logged
DreadRock
Site Supporter
Reply #185 on:
Jun 15, 2012, 12:12:05 »
So after pulling the left side motor cover off everything went back to working right . Im thinking something with the clutch set up is off and not engageing / disengageing the kicker . Or something is wrong with the clutch arm where the clutch cable engages the clutch .... this lil sucker
Will be looking into if its this lil part as dont know what the PO did or didnt do so will start there. If thats not it will move on to the clutch plates itself and see if there stuck or need replaced ! When i was doing the motor work the clutch seemed fine . If i have to replace will be looking to up grade the clutch and get it right !
Logged
'07' Victory Hammer
'85' FJ1100
two-smoker
I reject your reality, and substitute my own!
Reply #186 on:
Jun 15, 2012, 12:39:43 »
Well, if you do need to replace the clutch, at least you can still get new parts... The FZ and Maxim motors used the same bits. One of the few things Yamaha thought good enough to use in something else!
Logged
"I suppose I'd say.... BOLLOCKS! But that's pretty much a reflex for me...."
1973 Yamaha TX500- project Shinjimei
DreadRock
Site Supporter
Reply #187 on:
Jun 15, 2012, 12:47:00 »
Cool thanks for the info man
so a FZR clutch will slide right in NPs ?
Logged
'07' Victory Hammer
'85' FJ1100
two-smoker
Reply #188 on:
Jun 15, 2012, 21:10:41 »
Not quite... Before the FZR- the FZ600, or a Maxim 550 should work, too. I gotta be honest, I don't know if the FZR was even close. I do know the plates and steels fit into the TX/XS clutch basket, though. Same part numbers, even.
Last Edit: Jun 15, 2012, 21:12:37 by two-smoker
Logged
ryanbfast
Reply #189 on:
Jun 15, 2012, 22:20:47 »
wow, really impressive. great work!!!!!!!
Logged
DreadRock
Site Supporter
Reply #190 on:
Jun 16, 2012, 01:14:49 »
Thanks ryan and 2smoker ! Will look into it and spent some time in the shop and thinking that its not so much the clutch itself . Thinking its more of a adjustment with the clutch as it seemed to be engaged/disengaged so left the kicker in limbo. So plan on starting from there and see what happens!
Logged
'07' Victory Hammer
'85' FJ1100
axeugene27
Reply #191 on:
Jun 16, 2012, 12:03:01 »
IDK dread rock i just loosened my clutch adjustment and bingo bango problem gone. I was thinking it would of been the same for you. Hope it's not to crazy a fix.
Logged
cyclefreak
Site Supporter
Reply #192 on:
Jun 16, 2012, 14:17:30 »
Dreadrock, just in case you didn't know. THIS BUILD THREAD IS FREAKIN AWESOME!
Keep up the good work brother.
Logged
When in doubt gas it!!!
DreadRock
Site Supporter
Reply #193 on:
Jun 20, 2012, 10:28:23 »
Thank you very much im trying ! Well got the order from Dime City and this is what i got ...
Spent some time messing with it last night and have to say im likeing it . Still waiting on the spacers going to give the guy all the time he needs so there right the first time around i m hoping !
Also can anyone give me some info on the adjuster arm for the clutch as the manual sucks !
Logged
'07' Victory Hammer
'85' FJ1100
axeugene27
Reply #194 on:
Jun 20, 2012, 11:23:26 »
ooohhhh shiny
Logged
Print
Pages:
1
8
9
10
11
12
13
14
15
16
17
18
34
Go Up
« previous
next »
DO THE TON
Projects
Cafe Racers
(Moderator:
Sonreir
