Author Topic: Brat / Bob  (Read 34451 times)
Offline n0regret5
Re: Brat/ Bob
« Reply #60 on: Dec 15, 2011, 09:30:54 »
I don't know if it makes a difference but I put a pig in there about 2 inches on each side of the cut . Thanks
ah righto. small lesson here, a tube is less likely to bend than a solid bar. I highly recommend at least a shallow gusset there, I'd hate to see all this beautiful work go to waste.
Offline Flugtechnik
  • My bike is not transportation, it is a respite
    • Nixon and Me
Brat/ Bob
« Reply #61 on: Dec 15, 2011, 09:50:47 »
I think you need to qualify that statement. If you have a tube and a solid bar with the same OD the solid bar is less likely to bend. I can prove it with math.
However, given the same amount of material, you can make a tube with a larger OD than a solid bar and the tube will be stronger. But that is really just because it is larger. Tubes are more efficient structurally than solid bars.
I do agree with the area of concern and think a gusset would help.
« Last Edit: Dec 15, 2011, 09:55:34 by Flugtechnik »
Offline VonYinzer
Re: Brat/ Bob
« Reply #62 on: Dec 15, 2011, 12:08:47 »
Im not in the Northside anymore. PM me your addy and Ill toss it in the mail for ya.
Offline sasquach
Re: Brat/ Bob
« Reply #63 on: Dec 15, 2011, 12:33:55 »
PM sent
Offline sasquach
Re: Brat/ Bob
« Reply #64 on: Dec 15, 2011, 12:36:26 »
I highly recommend at least a shallow gusset there, .
Yah I agree with ya on the small gusset after reading some stuff here and looking at it
Offline VonYinzer
Re: Brat/ Bob
« Reply #65 on: Dec 15, 2011, 13:11:02 »
Remember, weld your gussets in on the outside (or inside) of the tubes. Not right down the middle.
Offline 650hardtail
Re: Brat/ Bob
« Reply #66 on: Dec 15, 2011, 14:00:21 »
ya putting in a loop at the frame ends kevin ?
kawasaki triples/parts always wanted
Offline sasquach
Re: Brat/ Bob
« Reply #67 on: Dec 15, 2011, 14:20:41 »
I was going to but with the suspention travel it's not going work plus I kinda like the way it looks without it .
Offline Staffy
  • It's not yours 'til you cut it up.
Re: Brat/ Bob
« Reply #68 on: Dec 15, 2011, 17:49:32 »
I'd put the gussets on the inside so that they can be covered by the seat pan and still keep the clean lines.
Offline sasquach
Re: Brat/ Bob
« Reply #69 on: Dec 16, 2011, 01:48:20 »
Staffy thats what I was thinking just gonna have to change the seast pan alittle bit
