You may want to keep that carb. That switch is the best thing I did to my Comando. It turned it from a tempremental weekend bike to my daily transportation
i see it has some aftermarket mufflers and low flat bars which look good...they are nice running machines and the single mikuni works really good.....but the pwk's from jrc (knock off keihen) are a great carb too i have sold and used many and they seem to always work well. good luck,joe@ v cycle
some commando's have a hard time starting using the electric starter even with the cable upgrade.....i kick and push the starter button at the same time if the starter does not spin it fast enough on the initial try... bars actually look a little wide but you can always cut them down if you want.joe@vcycle
