In preparation for getting the motor back from vapour blasting I am turning my attention to the insides, making sure I can get everything together I need to button the motor up. I have a shopping list together including:
1. New DID cam chain
2. Cam chain slider damper rubbers
3. Vesrah engine gasket kit
4. Engine oil seal kit
5. Cam chain tensioner blade
6. Clutch kit
I am thinking I may need to replace all my bearings too so turned my attention to them this evening so I could work out what state they were in and also what replacements I would need.
First up I assume these letters stamped on the cases identify the bearing locations and what their starting dimensions are (BBBBC)?
Looking at my Haynes manual here are the 400F crank and big end bearing specifics:
I am assuming the letters on the case are the crankcase allowance, however I'm going to need some help working this out.
I made a note of each bearing when I took it out of the motor so I could put them back in where they should go:
However on inspection of the bearings it doesn't look like they are in great shape. Not sure if they got this way in the ziplock bag or if they were like this when I took them out of the motor. Some bearings are scuffed and most have what looks like pitting on them:
Doesn't appear like the crank is damaged at all:
I suspect these are beyond service levels which means I need 10 crank bearings and some if not all big end bearings too. This is looking like it's going to be a brand new motor when I'm finished!
Also checked one of the big ends while I was checking the crank and whilst the wear appears uniform there are also the pits at the far ends, I'm going to need some help identifying whether these also need replacing:
Looks like the motor could suck up a bit of cash.
