www.Moto-Madness.com
Author Topic: 1981 Yamaha XS 400 Special II Cafe Racer build  (Read 48603 times)
Offline two-smoker
  • I reject your reality, and substitute my own!
Re: 1981 Yamaha XS 400 Special II Cafe Racer build
« Reply #60 on: Apr 10, 2012, 03:43:57 »
Man, you should have hella torque with the length of those intake runners, plus the extra velocity of having just one carb....
"I suppose I'd say.... BOLLOCKS! But that's pretty much a reflex for me."
http://www.dotheton.com/forum/index.php?topic=21144.new#new
Offline riotten22
« Reply #61 on: Apr 13, 2012, 20:51:54 »
Its alive !  Ended up swapping the coil connectors around and it fired up instantly what a simple fix.  It does run lean on left cylinder and rich on the right but hey its running with the single carb.  Its almost finishied ! need to figure out my license plate mounting and tie up a few loose ends but she is almost ready for the street.  Here are two videos and some more pics:
Walk around video
Drive by video
Offline john83
« Reply #62 on: Apr 13, 2012, 21:04:12 »
Nice!
Offline BigBSBusa
« Reply #63 on: Apr 13, 2012, 23:22:12 »
How's the heat around the legs from the pipes?
BigBS
1974 Honda CB550
1977 Yamaha XS750 - Project Maggie Mae
1994 Kawasaki Ninja ZX11 - Project Raven
1999 Suzuki TL1000R - Project Sable
Offline riotten22
« Reply #64 on: Apr 13, 2012, 23:28:01 »
Actually not bad at all, Still probably going to header wrap them.  The powder coat on the pipes wasnt heat rated and the left pipe is bubbling by the head.  It is running lean on left cylinder and rich on the right because of the single carb and 180 degree crankshaft. Not much else I can do other than going back to two carbs. Might end up going with a different exhaust that has mufflers.  I went into the open header idea saying that if the Harley guys all over town can do it I can do it but I think it is just too obnoxious. It is way louder in person / riding it  ;)
Offline Weezy
  • The Impatient Perfectionist!
« Reply #65 on: Apr 14, 2012, 17:00:36 »
Wow! Nice job.
Offline MILLENNIUM FALCON
« Reply #66 on: Apr 14, 2012, 17:29:58 »
Video please! ;D  As far as the lean condition.......there are several guys on xs400.com that are running single carb setups with good results I would check that out before you switch back to 2. I looked into to it for my xs400 because my mono-shock made fitting two carbs a challenge. The bike looks great by the way.
[/quote]
« Last Edit: Apr 14, 2012, 17:32:10 by MILLENNIUM FALCON »
Offline riotten22
« Reply #67 on: Apr 20, 2012, 22:31:33 »
Videos:
Walk around video
Drive by video
« Reply #68 on: Apr 20, 2012, 22:53:27 »
Thanks for the videos, I posted on your other thread.  :)
quote author=riotten22 link=topic=32386.msg393847#msg393847 date=1334971893]
Videos:
Offline riotten22
« Reply #69 on: Apr 22, 2012, 21:54:31 »
Installed some "lollipops" in the headers and it took the bite off the sound and started the wrapping the pipes.  After they dry I will be doing the high temp silicone spray on them that should blackin them up a bit more.
