www.Moto-Madness.com
Author Topic: 1974 BMW R60/6 -  (Read 9449 times)
Offline IndieSol
  • "This one goes to eleven." -Nigel Tufnel
    • Project: Pariah
1974 BMW R60/6 -
« on: Dec 24, 2011, 02:58:01 »
I was lucky enough to pick up this barn fresh 1974 R60/6 a few days ago.  An old airhead has been on my short list ever since my love affair with older bikes first started, so when I saw one I could afford pop up on Craigslist, and the ad was only like five minutes old, I jumped on it.
It's actually in pretty good shape, runs, and aside from the front signals, is complete.  It also came with Krauser hard bags, a Clymer manual (of course I'd prefer a factory manual) and the original sales brochure from a dealer in Seattle.
My plan is to more or less just fix what needs to be fixed in order to ride it safely, make a few small changes, and ride it.  A lot.  I'm going to start at the front tire and work my way back, but I'm going to leave the engine in the frame.
Changes:
Norman Hyde "M" bars
Epco Peashooter exhaust
Paint the tins black with white striping (as nature intended).
Possibly an earlier headlight bucket with integrated instruments
It'll be a couple weeks before I can really start ordering parts for it, but I'll be cleaning up some of the easy stuff in the mean time.  This afternoon I took a wire wheel to the latches on the krauser hard bags and got rid of most of the rust shown in the picture.  The latches function properly now and, while they don't look perfect, they're presentable and show a nice patina.  I'm going to look deeper into how to properly restore the bags and see what's involved.   The inside straps are trashed, so I may have to get creative there.
I also plan on taking some steel wool to the front spokes and rim, and cleaning some of the oxidation off the front hub/drum.  Any suggestions would be appreciated on the hub/drum portion.
BMW R100
XT350
CJ360 Cafe Project
Project: Pariah
Offline beemerbuy
Re: 1974 BMW R60/6 -
« Reply #1 on: Dec 24, 2011, 03:48:41 »
Hi!
I've had my hands on a few Airheads and using some xxxx steel wool on the spokes and rims will be ok, the hubs will need to be soda blasted. The fork legs will clean up with polish and a few rags.
Once you get to your engine cases, be very careful not to ruin the casting grain. Once again, soda blasting is your friend.
It took a while but I turned this:
Into this:
Offline ben2go
  • Two Wheel Projectile
« Reply #2 on: Dec 25, 2011, 21:41:16 »
Those are sweet bikes.I have found myself longing for an old airhead lately.
Offline VonYinzer
« Reply #3 on: Dec 26, 2011, 13:00:23 »
Absolutly awesome man! Old Airheads basically dont exist here... :(
Offline IndieSol
    • Project: Pariah
« Reply #4 on: Jan 01, 2012, 15:07:21 »
Thanks, Yinz  and all.  I'm so stoked about the whole thing.  Unfortunately it caused me to spend more than I really wanted to right before Christmas, so I sold my triple yesterday, but I wasn't really all that into it anyways.  I'd rather have an RD or CB400F than the S3, to be honest.
When I got the Beemer, the wiring in the headlight was a bit of a mess due to the previous owner's removal of the touring fairing.  I was able to get that cleaned up the other night and got the headlight to work as it should.  I didn't realize these bikes had a "flash" setting on the headlight, as well as off, low beam and high beam.  Kinda neat.   I'm not sure the headlight I have for it is correct, though, as it really doesn't want to mate up easily with the bucket.  That, or else I'm missing some hardware.
Still missing front signals (ordering this week), but once those arrive I suspect they'll work fine, assuming the flasher is good.
Since I know the bike runs, but it won't be running again for a bit, I went ahead and drained the tank while I was in the garage working on it.
Plans for the next couple weeks are to clean up the front end.   Steel wool to the rims and spokes, soda blast and paint the front hub and fork legs, new front tire, new brake shoes, fork gaiters and seals, change fork oil, new grips and cables, new rubber trim rings for the gauges, clean up or replace rusted bolts, etc.  Also going to repaint the Krauser cases and hit the insides with some bed liner.
BMW R100
XT350
CJ360 Cafe Project
Project: Pariah
Offline FluffyUnderside
« Reply #5 on: Jan 01, 2012, 15:27:36 »
When I did mine on my CB360 i used a mix of WD-40 and Simple Green Cleaner with a toothbrush. Got that oxidation right off there!
-=EMPTY GARAGE=-
Offline IndieSol
    • Project: Pariah
« Reply #6 on: Jan 02, 2012, 16:39:22 »
Thanks for the great tip!  I'll give it a whirl tonight.
BMW R100
XT350
CJ360 Cafe Project
Project: Pariah
Offline TipsyMcStagger
« Reply #7 on: Feb 06, 2013, 19:35:19 »
Do you have a restoration thread someplace?
Tipsy
