www.Moto-Madness.com
Author Topic: 79 CX500 mods...  (Read 7921 times)
Offline phillgripper
  • 79 CX500
79 CX500 mods...
« on: Jan 04, 2012, 00:12:16 »
I have 2 Honda CX500's 1 to bob and 1 to cafe.  I really like the look of pod filters but was told by the people at my local honda moto shop that they would be "too much of a hassle" and that "I would never get my bikes running right if I put pods on and removed the air box."  I've seen a lot of CX's on here with pods so...pod filters, good idea or bad idea?
Phillip
Offline sabastiaanm
  • first learn the rules - then break them
Re: 79 CX500 mods...
« Reply #1 on: Jan 04, 2012, 01:24:42 »
the thing about pod filters is that unless you are planning on p&p'ing and using a header that allows more flow, you are going to run into trouble tuning your bike properly. the stock airbox is there for a reason. you will actually have better performance from the airbox w/ a performance filter over pods on a stock motor.
the guys at the shop are correct that it is a lot of work, but if you're willing to do it, pods are a nice upgrade and look awesome too!
anybody can correct me if i'm wrong, this is just my understanding!
  • 79 CX500
« Reply #2 on: Jan 05, 2012, 17:37:15 »
thanks man.
Phillip
Offline 50gary
  • Under the Limelight
« Reply #3 on: Jan 05, 2012, 18:09:39 »
Over at the CX/GL forum the word is, 90/120 for individual air filter and headers.  I had 90/122 on my CX500 with two into one headers. It ran pretty well with that combo.  I now run Mikuni TM-38 flatslides from a snowmobile.  Which is interesting.
  Cheers, 50gary
« Last Edit: Jan 05, 2012, 18:17:06 by 50gary »
Short track speedskating, cycling, guitars, motorcycles, juggling dynamite. I was born to laugh at Tornadoes.
  • 79 CX500
« Reply #4 on: Jan 06, 2012, 02:45:06 »
crazy concept...you mind elaborating on "interesting"?  i have to hear about this.
Phillip
Offline 50gary
« Reply #5 on: Jan 06, 2012, 09:18:23 »
The TM-38 flatslides have the same mount diameter as the standard carburetors so they fit on the CX spigot inlets.  They are spaced differently so you must re-rack them wider by 25 mm to 160mm then comes the choke linkage, and throttle pull.  I use a single cable as the new carbs are linked mechanically (part of the re-racking)  the real work is in the jetting (no surprise here) I run a set of header that I made from scratch 2/1 ceramic coated with a cut down (12") carbon sportbike slip-on muffler.  When buying the carbs (ebay for fairly cheap) make sure you get a pair that don't have pressed in needles, the pressed in needles are hard to tune around.  You can press them out but it's more work added.   The flatslides are great, they have very quick throttle response, they even sound cool as the slides click at idle sort of like a Ducati with a dry clutch announcing how serious they are.  The performance is the really interesting part, the bike (to me) doesn't feel like a 500cc bike, it pulls very strong especially in the upper rpm ranges.  My jetting is 15/200 not perfect  but it idles fine with a hesitation off idle.  If you can afford it just buy TM-38 flatslides from Sudco.  Sorry for the thread jack.
  Cheers, 50gary
  • 79 CX500
« Reply #6 on: Jan 11, 2012, 17:19:07 »
Thats awesome.  Do you have any video or pics of you bike with this setup?  Preferrably a video because I really want to see and hear it, but pics will suffice.
Phillip
Offline 50gary
« Reply #7 on: Jan 11, 2012, 19:20:34 »
I'll post a picture soon
  Cheers, 50gary
« Last Edit: Jan 11, 2012, 23:16:23 by 50gary »
Offline MikeHall
« Reply #8 on: Apr 20, 2014, 00:46:26 »
50gary, I sure would like more details on your using those TM38 carbs. I have exhausted google, yamaha, skidoo, and artic cats parts diagrams searching for carbs with threaded needle jets but, have found nothing.
Thanks
Mike
Offline cxman
« Reply #9 on: Apr 20, 2014, 08:53:19 »
38 flat slides are to big for street use on a cx500
i have even tried 36mm flat slides they will work but still to big for lower speed city driving
and just attaching the 38/36 s to the stock intake will result in them falling off in a backfire situation or when its hot
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
