DO THE TON
Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: Another cafe build, Honda CB200T  (Read 2612 times)
Offline CanadianBacon
« on: Jan 09, 2012, 01:45:50 »
Hello All,
I've been working on this little cb200t for a few months and thought it was time to finally get around to posting some pics. I have been getting a bunch of tips from here and Stik70 has given me some help on a few things. Hopefully there will be a few things new on my ride but I'll skip the boring stuff.
Like most she started as a CL find and I have to say I almost left her the way she was. A bit of cleaning and some new parts and I could have had her looking like she did the day she left the factory. Tool bag was never opened and the manual was still under the seat.
But I just had to cut her up and try to make her go a bit faster.  ;)
First I was just going to do a basic cafe with a new seat from the magic web and some new bars, remove the lights, clean it up and have some fun. But as I started to work on it I realized I wanted to make it my own and started to really get into it.
Here are a couple shots of the first days I had it. Things started to go really fast after that.
More pics soon.
Cheers.
That's beautiful, what is that velvet?
My stable:
1978 Triumph Bonneville
1968 CB350 vintage race bike
1972 CB350 vintage race bike
1975 CB200T
My CB200 build: http://www.dotheton.com/forum/index.php?topic=32874.0
Re: Another cafe build, Honda CB200T
« Reply #1 on: Jan 10, 2012, 02:01:42 »
I took a ton of time polishing the engine and painted the frame. Then changed out the front disk wheel for a drum off a cb175 for a cleaner look.
Polished up the spokes and hubs and re-laced the front and back rims.
Put Avons on for a nice sticky ride.
Still working on the color scheme but I've got it pretty much figured out.
I still need to make the seat and the headlight mounts but made the cables yesterday and did most of the wiring today.
cheers.
My stable:
1975 CB200T
Offline rentedshoes
  • More problems should be solved by stabbing.
« Reply #2 on: Jan 10, 2012, 10:37:20 »
Lookin' good so far. I will definitely be watching to see how it turns out.
« Reply #3 on: Jan 11, 2012, 00:06:34 »
So like anyone out there I hate paying for parts. So when it came time to put the cables on and I needed custom sizes I just had to make them myself.
There are a few "How to's" on the web so I gathered as much info as I could and had a go at it. The first few turned out horrible but I got it down to a pretty good system and thought I would share it.
I machined two small pieces of metal 3/16" with holes for the ends and a channel for the cable. I figure this would make the end a bit long but I could just file it to size after. In the picture there is only on hole but I also made the brake cable so I used the same piece for the clutch with two holes in each half.
I cut the cable to length and then frayed the ends out to help grab the metal that I used for the ends.
Then clamped it all together with a healthy dose of flux for good measure. I filed in some solder shavings to help start the melt process and hopefully fill in the gaps. There was a bit of trial and error but I found that with some shavings and flux there was enough heat to melt it all and pull in the solder so I wouldn't have any air pockets.
Then heated the bottom until it was good and hot and melted the old end and some extra solder into the hole. It turned out pretty good once I had the system figured out. Just be careful to not torch the cable or that will bend and ruin your whole day.  :'(
And boom! New cables. :D
My stable:
1975 CB200T
« Reply #4 on: Jan 11, 2012, 00:44:48 »
So I put in the engine too. It was a bit of a wrestle and I will have to do some frame touch up but after it went in everything else went on super fast.
I'm still not sure about running rear sets and pods on it. I like the look of the old style cafes with side covers and stock pegs. It looks a bit more authentic to me. I guess I shouldn't be using Clubmans either but what's a guy gonna do...
So after a bunch of days with a ton of time in the shop this is where she sits.
I have a piece of foamcore where the seat is to go. I'm still trying to figure out what the seat will look like. But this is pretty close, I should be starting on that this week. And the headlight brackets are just temps too. I'm going to make some nice minimal ones to cut down on the clutter up front.
My stable:
1975 CB200T
Offline SeattleMark
  • You must go too far, to know what is far enough
« Reply #5 on: Jan 11, 2012, 13:48:16 »
Looks Great, love the 200s, still one of the best looking tanks Honda ever made. That engine was worth your time it looks amazing polished
76 Honda XL250 http://www.dotheton.com/forum/index.php?topic=26494.msg283660#msg283660
84 Honda Interceptor 500
78 Suzuki GS550 - donated to another build
Offline Ritz cracker
« Reply #6 on: Jan 11, 2012, 21:30:29 »
lookin good nice polish job
Offline full on tin
    • www.benjaminfullerton.com
« Reply #7 on: Jan 17, 2012, 02:31:28 »
Good thing the buffing wheel doesn't charge by the hour...
FINISH HER UP!!! The snow is melting and we gotta ride!
Offline odin836
« Reply #8 on: Jan 17, 2012, 03:15:31 »
Looking good!
« Reply #9 on: Jan 18, 2012, 01:15:54 »
Figured out a wiring issue with a friend of mine and then hooked up a plastic bottle to the fuel lines to test the thing. Fired up and ran like a Banshee!!! I still can't believe that sound came out of a 200!
Seat is being shaped and molded soon. Hope to get some pics of that up soon. Stay tuned.
It's turning out way better than I thought.
cheers.
My stable:
1975 CB200T
Offline cyclefreak
  • Site Supporter
« Reply #10 on: Jan 18, 2012, 02:09:11 »
Looking great man
When in doubt gas it!!!
« Reply #11 on: Jan 29, 2012, 17:23:23 »
Well, after a bit of a break I was able to get back into the shop and work on the seat and tank.
I decided to cover up the emblem mounts on the tank and make it smooth for some graphics I'm working on. I was a bit sad to see them go but I'll get over it i think.
I then sealed the foam model and covered it in plaster and burlap. Now I just have to wait for the mold to dry and I will lay up the fiberglass and hopefully have a new seat by weeks end! I can't wait to get this all to the paint shop and put all the finishing touches on it.
So close!
My stable:
1975 CB200T
Offline rockland213
« Reply #12 on: Jan 29, 2012, 17:59:33 »
That mold looks good
What do you plan to do for a seat pad ? I am at that stage now and need some help .
Offline Tim
  • Administrator
    • DO THE TON
« Reply #13 on: Jan 29, 2012, 18:42:54 »
Man you guys make that stuff look too easy.  One day I'm gonna try my hand at it.
Zed's dead baby... Zed's dead.
« Reply #14 on: Jan 30, 2012, 00:58:50 »
It's actually not that hard. it just takes some time and searching the internets for tips. The seat will be done in white and black leather hand stitched by a friend of mine. It will be pretty kick ass I think. He is actually finishing up his own CB750. Check out his build here:
http://www.dotheton.com/forum/index.php?topic=30272.0/[/url
I will take some good pictures of the process, hopefully it will encourage others to try their own stuff! The problem with the CB200 is it's so small and every other pre-made seat is way too big! Someone has to look out for the little guy! ;)
Cheers.
My stable:
1975 CB200T
