Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: 77 CJ360. "Sadie"  (Read 4473 times)
Offline MrBlueSide
  • 1977 Honda CJ360T
77 CJ360. "Sadie"
« on: Jan 27, 2012, 00:01:21 »
So I introduced myself a while ago and have been lurking about on here since then, while ordering parts and getting arrangements made at work to get started. This is my first build. My Boss, who is a gear-head guru, will be overseeing most of what will be going down, if it weren't for his tools, help, and social circle, this build wouldn't have gotten far.  Not that I am a complete newbie, I've worked on cars and trucks and I just finished rebuilding and restoring a 1962 Boston Whaler, but with his help this should turn out sick. Anyways, tangent completed...
Here's what I started with, the day she got home.
There's my dog again.
I posted in the "special" section mostly so I don't get a lot of "Hey man that bike isn't really a _______ style!" comments from other people. This is because I'm sure my project won't fit into any specific category besides whatever a 26 year old on my budget/ know-how can afford/ do. Anyways. I showed the picture of what I am planning on doing, and since I'm going through the trouble of posting this long first, I'll let the pictures do the talking from now on.
On minor note / major color change: I am going to kind of model the bikes color and look a bit from my truck.
That blue should be very nice indeed.
I moved my bike to where it will be stationed for the next couple months on Monday, taking one last pretty ride through town on my way back from lunch Monday.
That evening I got her up on the stand and the exhaust off.
This is where we're at right now.
Progress... so I'll keep going and hopefully see more on here sooner than later....
In advance I'll apologize for updating only every now and then when I get the chance. Life is crazy busy, as I'm sure it is for most you guys reading this.
« Last Edit: Mar 27, 2012, 21:29:50 by JakubAnton »
Offline YogiBear
Re: 77 CJ360. "Sadie"
« Reply #1 on: Jan 27, 2012, 06:21:52 »
Looks like one heck of a clean CJ360
Offline frogman
  • Site Supporter
  • '74 CB360, '71 CB450
« Reply #2 on: Jan 27, 2012, 09:54:25 »
+1 yep
The reason I talk to myself is that I’m the only one whose answers I accept.
Offline IndieSol
  • "This one goes to eleven." -Nigel Tufnel
    • Project: Pariah
« Reply #3 on: Jan 27, 2012, 12:37:49 »
Wow...Yeah...Crazy clean.
BMW R100
XT350
CJ360 Cafe Project
Project: Pariah
Offline Red Devil
  • Paint er up!
    • Chilliwack Custom Auto Refinishing
« Reply #4 on: Jan 27, 2012, 12:46:39 »
NIce!
The only difference between pink and purple is how hard you grip it.
www.custompaintshop.ca
Offline MrBlueSide
  • 1977 Honda CJ360T
« Reply #5 on: Feb 01, 2012, 00:06:30 »
Thanks, it definitely was a steal to find. Very clean and ran pretty smooth from the moment I got her.
Here's progress as of tonight.
I did run into a bit of a question though, and through looking all over the manual and these forums, I have yet to find the solution to my problem.  Maybe any of the 360 gurus out there (pj?) can help me out with this one...
After I took the clutch cover off, theres a ground wire coming from the stator; its connected to some odd point that isn't a screw like I thought at first glance. But its not. And I am stuck on how to disconnect it so that I can reconnect it without just cutting and re- soldering...
This guy right here.
Any advice?
Offline DannyMotor
  • Blood, sweat and beers.
« Reply #6 on: Feb 01, 2012, 01:38:43 »
That, sir... is your Neutral indicator switch. When the bike's in neutral it turns the little green light on your speedo on.
By the looks of the picture, remove those two 10mm bolts above the sprocket, remove the chain guard and the switch should come out with it!
The wire is held in place through a hole in the post by a round washer on a spring, simply push the washer back towards the case and pull the wire out to the left. Clean and simple.
There may be a rubber O-ring around the switch as well... make sure everything is SUPER clean before re-installing it as it goes directly into the transmission... and replace the O-ring if you can...
Also, if you're going to power-wash or use a chemical cleaner on the motor in any-way, re-install that switch with the chain guard to prevent any unwanted contaminants from entering the motor!
Good luck! Looks like a fun build!
« Last Edit: Feb 01, 2012, 01:44:01 by DannyMotor »
Offline MrBlueSide
  • 1977 Honda CJ360T
« Reply #7 on: Feb 01, 2012, 10:56:12 »
Many thanks Danny! worked perfectly... Your advice is appreciated!  8)
Offline MrBlueSide
  • 1977 Honda CJ360T
« Reply #8 on: Feb 01, 2012, 21:42:24 »
After tonight I have another round of questions; if anyone can help a brother out, it'd be awesome.
I'm looking to take the rear wheel off, and while going about this, looking at the chain, it doesn't look like there is a master link anywhere on there... Is this how all the factory installed chains were? I mean, sans master-link? Just cause one of those would make taking the chain off all the easier... Also, I was just about to hunting for a new chain, I've found a couple on ebay and amazon around, but I was wondering if anyone around here had any experience with that, or any place in particular where as to find a new reliable chain?
hopefully the next update wont be so much me asking questions as much as me showing off photos... :P
Offline frogman
  • Site Supporter
« Reply #9 on: Feb 01, 2012, 22:12:49 »
There has to be a link some where, if not then just grind the heads off one of the links and knock the pins out. Did you look at the back side of the chain?
Stay away from O-ring chains, they are wider and can possibly damage the clutch actuator under the sprocket cover.
Offline teazer
  • Site Supporter
« Reply #10 on: Feb 02, 2012, 19:38:27 »
That has to be one of the cleanest 360's i have seen in a long time.  Suggestion:  Clean it up, service it and ride the heck out of it.
Offline MrBlueSide
  • 1977 Honda CJ360T
« Reply #11 on: Feb 03, 2012, 00:30:46 »
So I got all the engine casings off, tomorrow they are going down the street to our metal guy to get shined up real good.  :D
A new set of CL speedo and tach rings came in today to replace the dented one on mine.
I don't know how you dent just this part without hurting anything else, but the previous owner apparent "hit a sign" or something... I forget exactly what he said.
Also, here is a picture of my oil leak...
As you can see, its on the left side, it looks like it could be just below the head gasket... this I hope is not the case, but has anybody had a leak like this on their 360? Or know the source? I was looking to not completely disassemble the engine so... heres hoping its not too bad. time will tell...
heres another angle....
thanks anybody and everybody for the replies.
ps thanks frogman, i was looking at the x ring, good call...
Offline frogman
  • Site Supporter
« Reply #12 on: Feb 03, 2012, 22:55:35 »
Looks like just filth man, maybe pull the valve cover and re-torque the head nuts. A leaking exhaust can do that if you run in water a bit. Top end gasket kits are all over eBay and worth the the time IMHO if you think you need to rebuild something. I'd leave the engine intact if everything is operating correctly though.
Keep it up! That's a pristine rig if you ask me.
Offline MrBlueSide
  • 1977 Honda CJ360T
« Reply #13 on: Feb 09, 2012, 13:52:56 »
Just bout finished with tearin it down. I sent all the engine casing out to be polished by my friend who has a metal shop down the street. This is where I'm at now
Theres parts all over the place...
I started to disassemble the tach and speedo last night, got the plastic cut very clean on them so they came apart fairly easy. I replaced the lightbulbs with LEDs and they are looking sick. I had some gauge faces made by sonreir, but the blue writing on black was too dark...
So a set of stocks with the white numbers are on their way today... Thanks Matt!
But upon changing the bulbs in the tachometer, I noticed a lack of light source for the turn signal indicator light on the gauge face... And I can seem to either remember where the bulb is/ was, or if there was even a light there to begin with... In sure there was something because I remember seeing the idiot light blinking after I had left my blinker on before...
This is the guy..
If you look down the shaft for the nuetral light, there's a bulb there. Also the middle socket for lighting the housing unit, but no third bulb in the shaft for the turn signal inidicator... And from beneath: no help either...
How is this possible? There's no wire running to it, not bulb, no slot in the. Broke exterior ring that covers the back.... Nothing.
Anybody know what's up? Or can possibly take a picture of their 360 tach disassembled?
I even took pictures and notes I every connection I've disconnected, and nada, nothing.. I'm at a loss, and not that I particularly need the indicator light to tell me she. My blinkers are on, but you know, it'd be nice... Thanks for any help dudes.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #14 on: Feb 09, 2012, 19:22:51 »
Hey man,
There should be an orange wire and a blue wire that connect to the bulb for the turn signal indicators.  I can't remember 100% how mine looks, but you're welcome to it if you want it.  I'm not using it.
Sorry to hear the blue on black didn't work out as hoped, but there's a trick you can try if you're still interested in giving them a go.  Basically, just paint the inside of your gauge casings in gloss white (avoiding the transparent plastic face, of course).  This causes the light to reflect internally to a much higher degree and significantly brightens up your gauges.  This is even more effective if you decide to replace those old incandescent bulbs with some white LEDs.
1982 Honda CB750C - Project Zoidberg
1963 Yamaha YDS3
1973 Suzuki T500
1982 Yamaha Seca XJ750R
Custom Gauge Graphics
Custom Wiring Harnesses
If you wish to make an apple pie from scratch, you must first invent the universe.  - Carl Sagan
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
Whether or not you can never be great at something, you can always become better at it.  -Neil deGrasse Tyson
Basically, it comes down to this, do you know what your doing?  If not, forget about what you want and do what your told (sucks but that's life)  -crazypj
