www.Moto-Madness.com
Author Topic: Deacon's KZ650 Cafe Seat Build  (Read 72805 times)
Offline HerrDeacon
« on: Mar 10, 2008, 21:24:46 »
I wasn't going to start a thread on this yet, as I was going to wait until it was totally finished. However, I got dragged away on business so I may as well do something bike related while I'm away from my baby :)
First off here is a pic of the bike as it was when I bought it. Check out the "custom" seat! No matter how mine turns out it
can't be that bad...can it? No where to go but up :)
Underneath the seat cushion was a really rusty seat pan. The top was fine, but the edges were totally gone. I wasn't
planning on using it anyway, so no loss. After that was tossed aside, I just had to grind off a few things: seat hinges, seat lock and helmet hook had to go.
« Last Edit: May 23, 2008, 14:57:27 by locO leoN »
Perry
1972 Honda CB350 K4 / 1978 Honda XL250S /1982 Honda MB5 / 2014 Honda CB500X
Offline HerrDeacon
Re: Deacon's KZ650 Cafe Seat Build
« Reply #1 on: Mar 10, 2008, 21:27:32 »
To get the shape I wanted I used a combination of green florist foam bricks and Great Stuff expanding foam. If I had to do it again I wouldn't have used the expanding foam, as I didn't like shaping it at all. In contrast, the florist foam is a dream to shape, it cuts and sands easy.
After cutting and shaping I ended up with something that I was happy with:
Perry
Offline HerrDeacon
« Reply #2 on: Mar 10, 2008, 21:31:44 »
Next step is getting ready to fibreglass. Before applying the fibreglass I needed to seal up the foam. I used a combination of foil and painter's tape. Since the strength of fibreglass is in the curves, I built in some curves to the seat section. Problem is that I forgot about the battery box that would be underneath the seat. So I later had to change this section to accommodate. You'll see this in later pics.
Perry
Offline HerrDeacon
« Reply #3 on: Mar 10, 2008, 21:39:09 »
Time to get messy...lay some fibreglass. Not much to say just make sure you have everything ready before you start: fibreglass mat all pre-cut and layed out, anything you don't want resin on covered up, gloves on, and most importantly put your mask on, you don't want to be breathing these fumes. I know I can't afford to lose anymore brain cells  ;D You can see in the last pic the modification I needed to make to the seat section for the battery box.
Perry
Offline HerrDeacon
« Reply #4 on: Mar 10, 2008, 21:51:48 »
Now comes the dusty stage...body filler. I first gave the seat a nice coat of body filler just to fill in the unevenness of the fibreglass. Then once I had this smoothed out somewhat, I mixed up a milkshake (combination of body filler, fibreglass resin, mekp and body filler hardener) to coat the seat with. This mixture is a lot more fluid then ordinary body filler and so creates a nice smoother finish. Regardless, still needs to be sanded...and sanded...and sanded and then sanded again.  ;D Finally I'm happy with the look and spray a coat of primer.
Milkshake pic:
After sanding:
Couple of pics post primer and on bike:
Perry
Offline Tim
  • Administrator
    • DO THE TON
« Reply #5 on: Mar 10, 2008, 21:56:17 »
Wow - next to shaping metal, being able to do that is something I'd love to be able to do.  Nice work.
Offline HerrDeacon
« Reply #6 on: Mar 10, 2008, 22:00:42 »
Thanks Tintin, so far this has been the best part of my project so far, I've had a great time. The smell of fibreglass throughout the house is not the best but that's all you can do.  :D
Perry
Offline HerrDeacon
« Reply #7 on: Mar 10, 2008, 22:02:28 »
As I said earlier I had to go on a business trip this week, so this past weekend I did the last of the fibreglass work needed for the seat so that its all ready for me to finish when I get back.
I wanted/needed to have somewhere on the bike to store some things: tool kit, camera, phone, lunch when going to work, etc., so I decided to build a glovebox into the seat. This area wouldn't be secure, I will just need to lift the seat cushion to gain access. I just marked the underneath of the cowl to clear the frame and the cross brace, and also clear the hole I have made for the light (more on the light later). I then filled in this marked off area with green foam and glassed over it. This is the way I left it. I'll cut a hole in the seat part when I get home and remove the foam. I'll post more pics when I complete this part.
Florist Foam:
Fibreglass:
Perry
Offline HerrDeacon
« Reply #8 on: Mar 10, 2008, 22:18:10 »
The last bit of glass work necessary is for the seat pan needed for the cushion.
I really have to thank Scarcat for his post on making a seat pan as I would have never had thought to use wood to enable you to staple the fabric to the pan. Thanks for the great post Scarcat. We need a thumbs up emoticon  Oh, just found it, here you go Scarcat ;D
Here is a pic of the wood laid out the way I wanted.
A couple of pics after some fibreglass has been laid under and above the wood.
I then did a rough trim to see how it looked on the bike. I'm mostly pleased with the pan except for the vertical part (i.e. seat back). I never got the fibreglass mat to sit down very good over the wood so its a bit high. I'll probably have to sand this down a bit and maybe lay a bit more glass. I'll finish trimming this and then start covering it when I get home next week. Still need to determine what I'm going to use to cover it, have to go out looking.
« Last Edit: Mar 11, 2008, 10:53:17 by HerrDeacon »
Perry
Offline Ease
  • 83 XJ650RK, 77 TS-250
« Reply #9 on: Mar 10, 2008, 22:46:16 »
Lookin great!
You plan on doing the Upholstry yourself too?
... I lost the name / number of the guy who did my seat ... But as far as I know there are a few decent guys around doin it.
« Last Edit: Mar 10, 2008, 22:55:05 by Ease »
