Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Poll
Vote!
BryceGP - CB750
___________________________________________________
125 (56.3%)
timdhawk - CB750
27 (12.2%)
Andrew - CB550
29 (13.1%)
ctluba - GT550
41 (18.5%)
Total Members Voted: 222
Voting closed: Mar 13, 2012, 12:00:07
Author Topic: MARCH 2012 DO THE TON BIKE OF THE MONTH - VOTING  (Read 9136 times)
Offline Tim
  • Administrator
    • DO THE TON
« on: Feb 28, 2012, 10:58:50 »
Vote!
Zed's dead baby... Zed's dead.
Offline Dale
  • Site Supporter
    • [B]Moto Guzzi V50II Detailed Cafe Build Diary [/B]
Re: MARCH 2012 DO THE TON BIKE OF THE MONTH - VOTING
« Reply #1 on: Feb 28, 2012, 14:30:49 »
Vote in.
Been a big fan of BryceGp's 750.
As usual great bikes in the lineup.
Offline Ringo
  • Site Supporter
« Reply #2 on: Feb 28, 2012, 15:13:45 »
Great bikes all, but pulling for the smoker.  That thing's so well done, and I recon would be a kick in the pants to ride!
« Last Edit: Feb 28, 2012, 19:41:08 by Ringo »
Offline brycegp
  • Stop being sad and be awesome, instead!
« Reply #3 on: Feb 28, 2012, 17:56:41 »
So what's my story...?  Hmmm...   Well...I needed a hobby!  I had just bought a '72 CB500 cafe style...and I loved it.  After a few months, I started scoping out the internet for bikes I liked and found the CB750 to be the best option for me to start with.
So I bought this...and if you've read my build thread you know that it wasn't supposed to be a huge project.  I thought I was buying a completed bike but figured I could make some light changes just to break myself into doing some mods.
But as I started removing parts that I didn't like...I started realizing I didn't like A LOT of the bike.  And one by one, parts started falling off the bike till I had torn the whole damn thing down to a pile of parts I did want.  But it was far from enough parts to make a completed bike.
So I started imagining all the aspects of a bike I would really love.  I wanted minimal.  I wanted classic.  I wanted raw. And I wanted it low...
There are a few aspects of the bike that I am proud of...feel that I really solved a challenge when it presented itself...or came up with a nifty mod to make it cooler in some way.
1.  I wanted it lower. But I didn't like the way guys drop the fork tubes into the triple tree.  And in the back, I certainly didn't want to use blocks.  So I found 1978 Cb550f forks that have identical caliper mounts and are 2" shorter than stock cb750F forks.  And then I found a thread describing a relatively easy way to mount up a DOHC CB750 Swing arm that is 2" longer...dropping the bike roughly 2" in the back.  And the tubular swing arm from the DOHC, IMHO, is a better aesthetic match to the frame than the squared off stock swing arm.  Problem solved...a lower, longer bike...which I really wanted.
2. I wanted minimal switches and gauges.  I wanted the triple tree empty.  I scoured the internet for a headlight just the right proportions to both go with the lines of the bike AND house all my electrical and gauge.  CEV headlight off some european moped was the answer.  While it did come with a speedo hole...I had to drill out the rest to fit the headlight switch, kill switch and idiot lights.  The one thing I think is super cool is where I put the start button...installed into the triple tree center nut.  Its so stealthy there...no one has been able to find where to start it yet...till I point it out.  Then there are the mini turn sigs that are installed in the rear as caps to the frame rails and finish the back nicely.
3.  Remove that ugly ass oil tank.  Well...I know there are lots of after market or custom oil tanks out there...but I really didn't like any of them.  Those round or octagonal barrels under the seat just didn't flow with the lines of the bike.  Till one day I was rummaging around at The Garage Company and found some old piece off a 1964 Ducati...and my oil tank dreams began to take shape.  Its painted black on the bike...and the pics don't do it justice...but it just works so well with the rest of the bike that I'm really proud of it.
4.  The gas tank and tail section combo.  Now you may not know it...but I went thru 3 tank and tail sections before I settled on this set up.  The others were off the shelf FEEBAY purchases...that just didn't really pop.  I was almost ready to buy a Benjie tank and tail till...I saw the Black Bomber tank.  Those aggressive lines...the hump back shape...the chrome panels and knee grips.  Man it just really got me thinking.  Well...it took me over a year to piece together a mint condition Bomber tank.  The knee grips  are impossible to find.  And I bought the left and right side...6 months apart from each other.
And then I was determined to find a tail section that followed the same lines.  After months of searching...and no luck...this tail section was a junkyard find...and began life as a 1950's Johnson outboard motor.  It had the same raised striped down the middle...so I cut it up, had a fab guy weld it together...and presto!  The tail section is truly my favorite part of the bike.
5. Wheels, Tires and Brakes:  So I wanted Coke 2" White Walls...maybe it was the gangsta coming out in me.  ;)  But I needed 18" hoops front and back due to sizing limitations of Coker Tires.  So I found a set of Harley hoops both 18x2.5, had them re-angled, new Buchanan spokes and laced them up to the stock hubs.  Personally, I think the white walls set this bike apart...but I COMPLETELY agree they aren't typically good set on a cafe style bike.  But in this case, I feel like I pulled it off.
The dual disc brakes with cross drilled rotors give its a more sporty look, I think.
6. 4 into 2 exhaust:  I love the look of these pipes.  'Nuff said...
7. Polish Aluminum velocity stacks:
So those are the highlights and in my opinion the best parts of the bike. I hope you guys like it...but in all honesty...I was just making a bike that I loved.  There were countless times where I wanted to sell it off or throw it in a river....or just burn it.  But after finally seeing it thru, I am extremely proud of finishing it.  And boy does it draw attention...
Credits:
Gas Tank, Oil Tank, Tail Section fabrication:  La Ca Fe´ Motorcycles
http://www.facebook.com/profile.php?id=100000884782328
Upholstery: Markel Auto Upholstery
Paint: Beverly La Brea Auto Body
Wiring Harness:  My brother, Jason AND PABST BLUE RIBBON...without which this bike might not have ever come to life.
« Last Edit: Mar 08, 2012, 22:50:20 by brycegp »
1971 Honda CB750 Cafe
1972 Honda CB500 600cc Big Bore Project
1973 BMW 2002 "Roundie"
1975 Honda CB750 (836cc) Project
Online VonYinzer
  • Site Supporter
  • We go where eagles dare...
« Reply #4 on: Feb 28, 2012, 18:45:50 »
Done. Had to go with the smoker. Looks like it would punch me in the face if I voted for someone else. That makes me happy.
“Fuck this "Don't speak ill of the dead" shit! People don't become better when they are dead; you just talk about them as if they are. But it's not true! People are still assholes, they're just dead assholes.”
Lemmy Kilmister
Offline motorpsykler
« Reply #5 on: Feb 28, 2012, 19:34:34 »
TOUGH month to vote.  All the bikes are great.  Bryce's CB750 certainly photographs the best.  But if I could ride any of them, the GT550 would for sure be my choice, so that's how I voted.
Offline thebronze
    • Custom Fighters .com
« Reply #6 on: Feb 28, 2012, 20:32:13 »
Suzuki all the way  8)
Offline Hoosier Daddy
    • My build Pics gallery
« Reply #7 on: Feb 28, 2012, 21:26:40 »
Tough choice yet again... but I watched only one from the begining so I let that be my guide.
Don't wait for opportunity to knock... kick the door down and drag the old harlot in!
ROCK-IT '81 CB750C
STAY CLEAN '67 BSA Spitfire
BOMBER '81 GL1100
OVERKILL '80 GS750
NO CLASS '72 CB450 K5
Online Sonreir
  • Oregon
« Reply #8 on: Feb 28, 2012, 21:33:04 »
I just did what I always do:  Which bike do I want to own or ride the most?
1982 Honda CB750C - Project Zoidberg
1963 Yamaha YDS3
1973 Suzuki T500
1982 Yamaha Seca XJ750R
Custom Gauge Graphics
Custom Wiring Harnesses
If you wish to make an apple pie from scratch, you must first invent the universe.  - Carl Sagan
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
Whether or not you can never be great at something, you can always become better at it.  -Neil deGrasse Tyson
Basically, it comes down to this, do you know what your doing?  If not, forget about what you want and do what your told (sucks but that's life)  -crazypj
Offline ctluba
« Reply #9 on: Feb 29, 2012, 00:37:51 »
Cool Hondas, top notch bikes!!!!!!!!! Good luck to all, hopefully I can smoke you guys out!! ;D
I always wanted a two stroke triple ever since I was a kid and some guy around town had an H2 750 that he would bring out about one time per year. I can remember the hair standing up on my neck when he rode down main street and every head would turn to see what was making all the friggin noise!!! 8) I was lucky to find this one at a good price. Did some tweakin and have her right about where I want her, loud and dirty!!!!!!!! Hope you like. ;D
The devil arrives at home
crash diet
gixxer front end
SV 650 swinger
mounted the stock guages to the new front end with a home made bracket
YAAAAAAA HOOOOOOOOOOOOOOOOOOOO
New top end after a boo boo
An earlier set up with cafe tail and clip ons
ditched the dual shocks and went mono
New tail cowl, seat and ditched the clip ons for super bike bars
new LED taillight (Big brother 750F in back ground)
and yes, she even runs!!!!!!!!!!!!! 8)
« Last Edit: Mar 10, 2012, 18:06:29 by ctluba »
Offline FunJimmy
« Reply #10 on: Feb 29, 2012, 13:01:59 »
Nice bikes. All of them, but I love BryceGp's Rockabilly 750.
FJ
Some people are like slinkies, basically useless, but they still make me smile when I push them down the stairs.
Build Blog: http://www.dotheton.com/forum/index.php?topic=21648.0
Offline milehigh
  • giggity giggity.
« Reply #11 on: Mar 01, 2012, 13:06:20 »
Bryce's bike makes me drool. well done sir.  Better keep it locked up or i'll find a way to track you down and steal it. lol
so a dolphin is driving and his car breaks down...he takes it to a mechanic...the mechanic says its going to be a few hours if he wants to wander around the town...upon his return, the mechanic says "looks like you blew a seal" to which the dolphin replies: "no sir, it was a walrus"
« Reply #12 on: Mar 02, 2012, 13:54:30 »
Being the hotrodder I am, I'm a sucker for whitewalls!!!
.........raised on 2 wheels!!!
1969 CB350 cafe
http://www.dotheton.com/forum/index.php?topic=24448.0
Offline NvgtrWiggles
« Reply #13 on: Mar 05, 2012, 20:25:20 »
That GT550 looks so purposeful... Damn, had to vote the CB750.
Offline LearnAsIGo!
  • 1974 Honda CB550 Cafe Racer in Progress
« Reply #14 on: Mar 07, 2012, 13:11:51 »
How do you choose the nominees?  Because I liked the CB550 - Tronda
http://www.dotheton.com/forum/index.php?topic=34357.0
