DO THE TON
Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: 71 Indignant CB175 - New Updates!  (Read 13478 times)
Offline SeekingZero
    • Seeking Zero
Re: 71 Indignant CB175 - Wiring & Linkage Done!
« Reply #165 on: Sep 20, 2012, 23:15:15 »
I saw the ones on vintage connections site, but I was looking for something different.  I am going to go with these cheap terminal strips.  One front, one rear should tidy everything up.
"We make our world significant by the courage of our questions, and by the depth of our answers." - Carl Sagan
CB175
My Site
Offline andycafe
  • If you don't want anyone to know, Don't do it!
« Reply #166 on: Sep 21, 2012, 04:29:48 »
if you do use a couple of terminal blocks, make sure you get the insulated ones  ;)
Honda CB250rs cafe (Current project)
Honda CB400f brat (Next project)
The New Bike Thread
The workshop & deck build
If you can't fix it with a hammer, You've got an electrical problem mate!
Offline SeekingZero
    • Seeking Zero
« Reply #167 on: Sep 21, 2012, 04:49:10 »
Oh nice! Where may I find those sir?  If I can get those then I won't have to undo all my nice connector work.
CB175
My Site
Offline misteroddjob
  • Site Supporter
« Reply #168 on: Sep 21, 2012, 08:37:23 »
Radioshack has them.
Offline andycafe
« Reply #169 on: Sep 21, 2012, 08:40:42 »
http://www.radioshack.com/product/index.jsp?productId=2103231
haha i was just looking for the link misteroddjob  ;D
The New Bike Thread
Offline SeekingZero
    • Seeking Zero
« Reply #170 on: Sep 21, 2012, 12:04:25 »
Thanks guys.  I was going to go there for the other one anyway.  :D
CB175
My Site
Offline SeekingZero
    • Seeking Zero
« Reply #171 on: Sep 29, 2012, 23:03:58 »
Well I guess its been while.  I suppose you all are expecting to see a painted tank and seat...
I uh...its a lot of sanding.  So much so that I will seriously consider not undertaking anything else in the future that has to do with fiberglass or filler.
Right now the last touch up of filler is on the seat, to get those last little holes and marks to go away.  Tomorrow I will do a final sanding and I will be ready for paint.
I also finally got the rear turn signals mount as well.  I had them mounted before with the bolt on the outside of the frame.  As it turns out, when the seat is mounted, the bolt catches when it lifts on the hinges.  So I got some...well I don't know what they are called, but I turned them into something that resembles a weld nut and drove a bolt from the inside of the frame.
And I got the kickstand installed.
Still finishing up installing the wiring as I was waiting on the turn signals.  No progress on the clutch either.
CB175
My Site
Offline andycafe
« Reply #172 on: Sep 30, 2012, 01:57:40 »
WHAT??? it's not painted  ??? lol, no need to rush these things! Would hate to be looking at it and think I wish i'd taken more time.
The New Bike Thread
Offline timbutterfield
« Reply #173 on: Sep 30, 2012, 10:43:47 »
Did you use a layer of bondo body filler on top of the fiberglass?
1995 honda nighthawk 250
1972 honda cb175 project bike
  • Site Supporter
« Reply #174 on: Sep 30, 2012, 12:26:15 »
Those are called Tee Nuts.
It looks like neither of us are going to win for September...
Offline SeekingZero
    • Seeking Zero
« Reply #175 on: Sep 30, 2012, 19:40:02 »
Yes, auto body filler coated over the fiberglass, then sanded smooth.
Apparently not.  Good things take time right?  ;)
CB175
My Site
  • Site Supporter
« Reply #176 on: Sep 30, 2012, 19:59:20 »
Ain't that the truth.
Offline bsnodgre
« Reply #177 on: Oct 01, 2012, 14:04:09 »
I'm waiting on the rear sets from Viet for my CB200.  Did you have any trouble rotating the rear brake lever 180 degrees so that it was pointed up and not down?  I noticed mine has a notch in the mounting post that goes into the drum so that it can only be put on in one direction...
Offline SeekingZero
    • Seeking Zero
« Reply #178 on: Oct 01, 2012, 14:59:34 »
The shaft on the brake drum for the CB175 has splines all around except for a small portion.  This can be faced at 90 or 270 degrees (up or down).  So for me, it was just a matter of rotating the shaft to allow the brake arm to face upwards.  I am not familiar with the CB200.
CB175
My Site
« Reply #179 on: Oct 06, 2012, 21:44:04 »
Any closer to paint?
