Total Members Voted: 156
Voting closed: Apr 13, 2012, 17:10:33
want more pictures of the xs 750!!!!!!!!
so i figured i should talk a little about the build..well first, i picked the this rd125 at the barber vintage festival for $250 bucks and pushed it a mile back to the car with a locked up front brake. i wasn't going to go as crazy as i did when i originally started the build but per the usual i decided to spend about 40 more hours than intended and a bunch more money. The tank was originally a yamaha 80 tank that i extended using sheet metal and is usable with gas til about 4 inches from the end where the battery and electronics are housed. with the frame i took all the un-needed tabs and brackets off and added the trellis rearsets and high rear loop to fit the tail section and gave plenty of clearance. the wheels i wasn't originally going to change (just clean up), but i found the excel hoops and R5 front hub and couldn't not build them up. As for the motor, i beefed up the clutch, cleaned up the top end and cylinders, got rid of casting marks on exhaust, modded reed blocks to fit ds7 mikuni 28mm carbs, and made sure eveything was working properly. To help the motor breath on the exit, i took some french expansion chambers and hacked them up, added spring mounted header that tuck closer to the motor, and build serviceable expansion chamber that fit a bit closer to the swing arm. The front body work was build by airtech and the windscreen is from gustaverson. the seat is one of my "costello" tail sections. here are some build pics
Agreed - Congrats Branden! A great bike for sure.
