Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: Master cylinder and brake lever issue  (Read 501 times)
Offline 72texas350
« on: Apr 11, 2012, 00:06:58 »
I got a new, to me, brake lever and master cylinder for an '89 zx750f and I just went to put brake fluid in it to set up my front brake system. the master cylinder doesn't leak at all but it won't let any fluid into the line. I can't find why not.
Any thoughts?
This is my first time setting up a hydraulic brake system so its definitely a possibility I am just doing it all wrong
Online AlphaDogChoppers
  • Science is true whether you believe in it or not.
    • Alpha Dog Choppers
Re: Master cylinder and brake lever issue
« Reply #1 on: Apr 11, 2012, 07:48:09 »
Piston is probably stuck in a pushed in position. Sometimes you can use a rod pushed into the outlet to push the piston back and get it working again, but most likely you will have to rebuild it.
Alpha Dog Choppers
Painting
Powdercoating
Custom Fabrication
Repairs
I'm so old, I even know what ignition points are.
Offline 72texas350
« Reply #2 on: Apr 11, 2012, 13:02:07 »
Thank, it was the piston. I finally got it working
