Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: Another SR250 - The Police  (Read 3477 times)
Offline Fedja
Re: Another SR250 - The Police
« Reply #30 on: Jun 06, 2012, 11:28:19 »
jup, spring is installed correctly. plates are not stuck together i took them out and cleaned.
i tried to attach cable to the rod and pull it with hands...it returns normaly. when i try it with lever like it should...it doesnt return. i'm waiting for new cable...we will see.
Offline interceptor
« Reply #31 on: Jun 06, 2012, 12:15:14 »
Was wondering if you touched or tightened the pivot bolt for the hand lever?  I over tightened mine and it was acting same way.  I loosened it and it works much better now.
Offline Maritime
« Reply #32 on: Jun 06, 2012, 13:43:50 »
I did this once too.  Check it and see.
My Build: My full figured girl: http://www.dotheton.com/forum/index.php?topic=13950.msg135199#msg135199
Offline Fedja
« Reply #33 on: Jun 06, 2012, 15:23:51 »
will do that when i get back to garage on weekend.
cheers
Offline Fedja
« Reply #34 on: Jun 30, 2012, 10:44:19 »
the cable was not the issue, it was the nut...
anyway got new trouble, im in process of rewireing and i have disconected starter relay and now i dont know wich side goes to battery and wich side goes down in crankcase...help :(
Offline SteveG
  • Site Supporter
« Reply #35 on: Jun 30, 2012, 13:31:32 »
Do these help:
SR250 Tracker called Mexico
http://www.dotheton.com/forum/index.php?topic=38765.0
Life is just an illusion induced by the lack of alcohol....
Offline Fedja
« Reply #36 on: Jun 30, 2012, 14:46:08 »
I cant tell, it doesnt look the same.
Mine is hitachi ms5d-191
http://img.auctiva.com/imgdata/1/4/5/4/6/0/8/webimg/533386237_o.jpg
Offline Bert Jan
  • Holy Modification Batman
    • Outsiders Netherlands
« Reply #37 on: Jul 15, 2012, 05:55:33 »
Af far ias i know i doesn't matter. The relais (actuator) connects the 2 big contactpoints (m6) when power is applied to the small wires. It doesn't matter wich wire goes where on this particular part. If you're still in doubt you could open it to see what happens when power is applied.
Don't take my words for wisdom, i could be wrong.
http://outsidersnl.wordpress.com/
Swagger: 'Anything we did for Uncle Scam or Nasa was soldered, period. No crimps allowed.'
Offline Fedja
« Reply #38 on: Jul 16, 2012, 04:36:21 »
thnx Bert, I figured it out, it doesn't matter wich wire goes where.
cheers
Offline Fedja
« Reply #39 on: May 07, 2013, 04:52:00 »
So yeah I finally finished this :D
This is what it looks like now;
I'm really unhappy with front end...its fugly as hell :-/ but I had no more resources (cash or time) to make it look nicer. And I just wanted to ride it.
