Author Topic: The Red Bike  (Read 16865 times)
Offline kopcicle
  • antidisestablishmentarian
Re: The Red Bike
« Reply #10 on: Apr 28, 2013, 04:44:30 »
happy I found it too . :-)
Pete it will be a week or two before I get the crank and bore sorted then we'll see how the MIC actually fit .
I may get all four and just keep two around for whatever reason .
~kop
« Last Edit: Dec 14, 2014, 04:50:03 by kopcicle »
"If a man wants to carry two cats home by their tails, by all means let him. He’ll learn things that he might not have otherwise even guessed, and the experience will be one he’ll not soon forget!"
~S. Clemens
If it leaks after all this? I'm gonna pull a "Brad" and bulldoze the fucker!
Quote from: Scruffy;1025553
As an equal opportunity bigot, I'll insult any brand, any style, any time...:wink:
-Scruffy
http://tinyurl.com/TheRedBike
https://www.gofundme.com/nancy039s-final-expenses RIP Nancy
Offline kopcicle
Re: The Red Bike
« Reply #11 on: Apr 28, 2013, 15:03:55 »
some crapy pics of the pistons ...
~kop
~S. Clemens
-Scruffy
Offline Sonreir
  • Moderator
  • Oregon
Re: The Red Bike
« Reply #12 on: Apr 28, 2013, 15:48:59 »
More content!  \o/
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline kopcicle
Re: The Red Bike
« Reply #13 on: Apr 28, 2013, 17:49:22 »
...I reposted part of the aussie sight somewhere else and it was ready to paste
The late Phil Irving could hardly have wished for a more loyal disciple than Ron Valentine, best known in motorcycling circles as designer of the highly successful Westlake racing engines. More than 30 years ago nobody was quicker than Valentine to recognize the merit of Irving's proposed cure for the engine vibration that, in varying severity, had long plagued Britain's big four-stroke parallel twins, condemning their riders to mobile vibro-massage without the option.
The essence of Irving's brainwave was to replace the standard crankshaft with its crankpins in line, by a shaft with its pins staggered so that when either piston is at top dead centre (where it primary inertia force is greatest) the other is approximately at midstroke and generating no primary force. This arrangement considerably reduces the engine's maximum inertia force, and thus vibration - though not by so much as the 50% one might suppose, as we shall see later.
A second benefit stems from the fact that when either  piston is stationary at tdc, the other is moving at or near its maximum speed and thus contributing to the flywheel effect, so that the flywheels themselves can be a bit lighter for the required level of smoothness. It was this consideration that dictated Irving's original choice of 76° for the spacing of the crankpins. For with that angle - given that the centre length of most connecting rods is near enough four times the crank radius - when either piston is at tdc, the "big-end" angle (con-rod to crank) in the other cylinder is a right angle, hence piston speed highest.
To their shame - and perhaps because of an irrational horror of uneven firing intervals? - the manufacturers of even the most vibratory parallel twins showed not the slightest interest in Irving's proposal despite the relative ease with which they could have converted an engine for test by twisting the crankshaft and camshaft, adjusting the spark timing and fitting a second carburetor where necessary to obviate a mixture bias from overlapping induction phases.
Following the demise of the British industry, it eventually fell to Ron Valentine (and his assistants, including mathematician Tom Oliver) to prove the soundness of Irving's scheme when (three or four years ago) they completed their second 76° crankshaft for Steve McFarlane's 952cc (80.5mm x 93.5mm) BSA parallel twin classic racing sidecar outfit. Stretching both bore and stroke of the original A65 engine had aggravated its vibration to the point where the crankcase was in danger of disintegration.
Machined from a solid bar by Dave Nourish, Nourish Racing Engines (NRE), in his Oakham workshop, the new shaft proved to require balancing (to a factor of 50%) as if it were two separate flywheel assemblies joined together. Once that was done, the engines character was transformed. Gone were the frantic shakes. Instead, said McFarlane, there was a slow and lazy throbbing sensation as - to the accompaniment of a pleasant off -beat exhaust lilt, reflecting the 436°/284° firing intervals - the revs soared to 7,000 RPM and the more powerful 1000cc - 1200cc Imp engined outfits were humbled as the BSA won its heat in the Snetterton Race of the Year meeting in 1990.
Encouraged that his and Nourish's sacrifice of valuable time and effort had proved worthwhile, Valentine decided to follow his hunch that a 90° pin spacing would give even better results. True, the instantaneous contribution of the descending piston to flywheel effect, while the other was at tdc, would be slightly reduced because it would be just past its maximum - speed position (big-end angle only76°, not 90°) but there would be two overriding benefits - one to mechanical balance, the other to the smoothness of the flywheel effect.
Balance would be enhanced because the top and bottom dead - centre positions of either piston (where the secondary inertia forces act upward) would coincide with the midstroke positions of the other, where the secondaries act downward. Thus those forces would counterbalance one another at the cost of a small rocking couple.
As to the moving piston's contribution to the flywheel effect, this would be the same whether the stationary piston was at tdc or bdc (the big-end angle being 76° in both cases). With the earlier 76° pin spacing the ideal "big-end" angle of 90° was achieved only when the stationary piston was at tdc. When it was at bdc and the moving piston was rising, not descending, the angle was only 62°, so the effect was not constant but fluctuated at high frequency. Of these two benefits in favour of 90° pin spacing, the absence of unbalanced secondary forces is clearly the more significant.
When the subject of "cranky cranks" was discussed in Motorcycle Sport three years ago Charles Bulmer suggested that a 180° crankshaft would be even better provided its primary rocking couple were eliminated by means of a crankshaft-driven contra-rotating balance shaft. Quite so, for an engine so designed from scratch by a manufacturer, as with some Hondas.
But what Phil Irving was proposing was the least possible alteration to already established mass-production lines to overcome a serious deficiency in British parallel twins. Given a clean sheet of paper, he had long since shown his own preferences for twin cylinder four strokes: designed just before the second world war, his 600cc Velocette Model 0 vertical twin was a model of smoothness; like its racing stable mate, Harold Willis' 500cc super-charged "Roarer", it had contra-rotating geared crankshafts and shaft drive. Later, his postwar 50° V-twin Vincent Rapide ranks as one of the industries greatest designs.
Again drawn by Ron Valentine and machined by Dave Nourish, the 90° crankshaft has four flywheel discs and is a replacement for the conventional (360°) shaft in one of Nourish's Westlake powered classic racing 500cc NRE Triumph based pushrod parallel twins. Since the total upward inertia force with the standard crankshaft occurs when both pistons are at tdc together, it might be supposed that separating the tdc positions by means of staggered crankpins would halve the force and double its frequency, regardless of whether the stagger is 76° or 90°. Not so as Mr. A Archdale was at pains to confirm in the original "cranky cranks" discussion, although the individual tdc forces in each cylinder remain one half of the total for the 360° shaft, the total upward force occurs when both pistons are level and their cranks equally disposed each side of tdc, i.e., 38° before and after tdc for the 76° stagger and 45° for the other. The point one must grasp here is that - although one piston is moving upward and the other downward when they are level - their inertia forces are both upward, as can be seen in the accompanying curves, where both points are above the base line. Note too that the 45° points are slightly lower on the curves than the 38s, indicating a slightly lower force in favour of the 90° pin spacing.
~kop
~S. Clemens
-Scruffy
Offline kopcicle
Re: The Red Bike
« Reply #14 on: Apr 28, 2013, 17:50:43 »
The net result, as calculated by Valentine and confirmed by Bulmer, was that whereas the 76° shaft reduces the maximum upward inertia force by a useful 32%, the 90° shaft is an altogether better proposition with a reduction of almost 45% (see Tom Oliver's graphs)
 The first tentative outing for the "90" was at Mallory Park last May, when Martin Smith found the engine considerably smoother than standard. It was also 4-5 bhp up in power as a result of new cam profiles - Valentine had replaced the Triumph type radiused tappets by experimental roller cam followers, since they are less dependant on copious lubrication, and had taken the opportunity to up rate the cams.
 In the Classic TT Robbie Allen was in the hot seat and finished 10th in the 500cc race, eighth in the unlimited. However, in common with most classic racing participants, Robbie is well over the win-or-bust age range and the object of the exercise was not to win but to compare the modified crank with the standard one. Riding apart, the fact that Robbie's bike finished well ahead of a brace of standard NRE's reflected the cam changes rather than the pin spacing. Subsequent bench tests at Oakham gave a repeatable 57-58 bhp at 9,000 RPM and a one off flash reading of 62.5 bhp at 9,800 RPM.
 Since riders with an analytical flair of a Geoff  Duke, John Surtees or Peter Williams are as rare as elephants teeth, Nourish had intended to try the machine himself  at Jurby airfield but was foiled by atrocious weather. Before the final outing (to the Manx GP) however, he took it to East Kirby airfield, in Lincolnshire, for assessment and was delighted by the extent of improvement. A few other invited riders were equally impressed. Alas in the Island, Allen was troubled by a few unrelated problems - valve float and missed gears -  before an ignition failure in one cylinder brought about his retirement in the third lap. But Nourish is now so hooked on the new crankshaft that he is planning to market complete 90° NRE engines.
 Conversion kits for other engines, however, would not be a commercial proposition. Each 90° shaft, says Dave, is suitable only for the precise reciprocating weights of its particular engine - and con-rod weights, for example, vary enormously (the top portion is the critical end), so the balance holes in the flywheel discs must vary too. There are other relevant variations and the net result is that machining a shaft to suit a particular engine would take too much costly time.
 Engine vibration is unpleasant in touring machines as well as racers. Some tourists may dismiss a mild case as inevitable provided they don't make day long trips - or try a BMW boxer and realize what they are missing. In racing, however, it is unforgivable, especially in long distance events such as TT races. It can cause not only metal fatigue - breaking anything from brackets to engine plates - but also rider fatigue. It can impair engine performance by seriously upsetting carburetion. And, at best, it must absorb a modicum of power. Phil Irving now has another disciple in Dave Nourish. Only 10 more to go for a full apostolic set!
 VIC WILLOUGHBY
 And a hearty thanks to the xs 650 club of Australia for the info as it was lifted directly from their site
 http://www.xs650.org.au/tech.html
 a great resource and I highly recommend you all visit and contribute .
 ~kop
~S. Clemens
-Scruffy
Offline kopcicle
Re: The Red Bike
« Reply #15 on: Apr 28, 2013, 17:53:21 »
The rephase distributes rather than concentrates forces . With the exception of side thrust near all of the 360 degree cranks forces are in a vertical plane . There is a secondary rocking couple induced by the alternating left right firing sequence but that is actually an order beneath the primary forces .
 The rephase was initially used to increase available traction , in steam locomotives . A timing arrangement that allowed for application of force to one side of the locomotive and then delaying the other side for 90 degrees with respect to the primary and then allowing for 270 degrees "rest" to allow recovery of traction .
 Fast forward to the English and their venerable vertical twin . Their cranks were almost exclusively bolt together although tapered fit and key'd . As modern fuels crept in to the mix higher and higher compression engines became possible due to advanced alloys . The crank became not only the weak link but a source of annoying vibration .
 Enter an old idea with a new purpose . I'll spare you the force diagrams .gif and leave those as a homework assignment  or for some member to post following this monologue . To reduce the inherent vertical impulses one piston was to be at TDC whilst the other was to be at maximum acceleration which is when the connecting rod and piston are perpendicular to the stroke (90 degrees) . This happens to be near our 277 degrees . With the reduction of vertical forces by way of distributing them throughout the cycle and consequently having portions of those forces happily cancel  each other out we have by subjective definition a "smoother" rotating and reciprocating mass .
 Does it make more HP and Ft/Lbs ? Not necessarily . The bore and stroke have not changed nor have the combustion chamber dimensions . So what is the real performance benefit ?
 Honestly it accelerates quicker because it isn't acting against itself throughout its cycle . It acts like a much lighter crankshaft and well it should .
 Longevity . It isn't beating itself to death just to idle . It isn't prone to the wild imbalances of a secondary rocking couple that is at the mercy of combustion processes rather than mechanical timing .
 Mean repeatable maximum BEMP . meaning the ultimate breaking strain of a rephased engine is much greater than  that of a 360 or even 180 degree engine .
 Specifically the limiting factor in our engines is the center crank pin . Anything we can do to keep stresses off this one area will add to the longevity of  the rotating and reciprocating mass .
 Traction . Back to the original reason for the phasing . The reason I used it was specifically to keep up with a well known 45 degree V-twin. There were tire sizes and sprocket ratios unavailable to us with a 360 degree crank because we were hitting on the same spot on the tire every time around !
 This uneven firing order also allowed the tire and chassis  to recover in between power impulses allowing subsequent impulses to gain traction .
 Since I'm sure you have all had enough of this ...
 More Ft/Lbs ? maybe a little
 More HP ? Again maybe a little
 But both due to the reduction in vertical forces
 A fair impersonation of a lighter crank ? Absolutely
 More reliable ? Apples to Apples , yes
 Able to leap tall buildings in a single bound ? YMMV
 ~kop
~S. Clemens
-Scruffy
Offline VonYinzer
Re: The Red Bike
« Reply #16 on: Apr 28, 2013, 17:58:06 »
Hi Dennis. Awesome thread.
Offline crazypj
Re: The Red Bike
« Reply #17 on: Apr 28, 2013, 21:55:04 »
The 76 degree Triumph was to lose most of the rotating mass, less vibration was only a happy consequence
90 degree crank is better to reduce vibration (Yamaha used it on TDM850)
 The 277 XS 650 crank is close to optimum for lighter flywheel.
It was a major thread at XS650 Garage about 7~8 yrs ago
If I ever get back to it I stripped my 840 re-phased motor and started lightening individual flywheels
 BTW, I used to work with a guy from Yamaha, Kenny Roberts works OW motors made 100HP but center pin would either separate or fracture if welded
« Last Edit: Apr 28, 2013, 22:04:03 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
Offline kopcicle
Re: The Red Bike
« Reply #18 on: Apr 28, 2013, 23:38:39 »
Quote
many thanks to Brett ,Greg , Dick , Bubba , LarryC , APE , Cliff @ MTC and Google Calc for the conversions .
http://xs650temp.proboards.com/index...d=17014&page=1 for the original thread
...and you too Pete , it's where we met .  ;)
~kop
~S. Clemens
-Scruffy
Offline crazypj
Re: The Red Bike
« Reply #19 on: Apr 29, 2013, 12:59:31 »
Doh, I forget stuff since the bump on the head  ;D
Brian Morgan, 1982
