Author Topic: The Red Bike  (Read 15798 times)
Offline crazypj
Re: The Red Bike
« Reply #40 on: May 11, 2015, 05:42:26 »
Alright, what's the transmission looking thingy under the welding cord?
 I noticed that as well and wondered, what is it?
Best thing I ever overheard
Brian Morgan, 1982
Offline crazypj
Re: The Red Bike
« Reply #41 on: May 11, 2015, 05:45:22 »
Oh, I don't remember when we last spoke about it, but, Phil Irvin didn't do 76 degree crank to reduce vibration, he did it to loose flywheel so motor would accelerate much faster.
It's the reason I'm doing it (and grinding on flywheels  8) )
The reduction in vibration was only a 'happy' side effect of the crank mod.
 I remember reading the actual Irvin article somewhere instead of the later ones which talk more abut vibration reduction
« Last Edit: May 11, 2015, 05:47:09 by crazypj »
Brian Morgan, 1982
Offline kopcicle
  • antidisestablishmentarian
Re: The Red Bike
« Reply #42 on: May 11, 2015, 13:32:02 »
'94 Ford A4LD 4x4 .
~kop
"If a man wants to carry two cats home by their tails, by all means let him. He値l learn things that he might not have otherwise even guessed, and the experience will be one he値l not soon forget!"
~S. Clemens
If it leaks after all this? I'm gonna pull a "Brad" and bulldoze the fucker!
Quote from: Scruffy;1025553
As an equal opportunity bigot, I'll insult any brand, any style, any time...:wink:
-Scruffy
http://tinyurl.com/TheRedBike
https://www.gofundme.com/nancy039s-final-expenses RIP Nancy
Offline Texasstar
  • Can't is a four letter dirty word
    • Zoom With Zeke
Re: The Red Bike
« Reply #43 on: May 13, 2015, 18:24:08 »
2.50-18 Borrani laced to KZ70B2 (twin) hub . 130/80-18 66P TT K180 . The 40 tooth sprocket is somewhat excessive :-) .
Thanks again Matt .
~kop
woohoo new rubber
It's an optimization exercise and not a maximization trip.-Teazer
And though she be but little, she is fierce - WS
http://zoomwithzeke.com/
Third Times a Charm cb175
http://www.dotheton.com/forum/index.php?topic=66169.0
Honda Cb175 Victoria!
www.dotheton.com/forum/index.php?topic=52299.0
Honda Cb200 Lucky!
http://www.dotheton.com/forum/index.php?topic=45872.0
Bultaco El Montadero 360
http://www.dotheton.com/forum/index.php?topic=64349.0
Offline Texasstar
    • Zoom With Zeke
Re: The Red Bike
« Reply #44 on: May 14, 2015, 19:52:15 »
Finally subscribed thru taptalk
Honda Cb200 Lucky!
Offline kopcicle
Re: The Red Bike
« Reply #45 on: May 28, 2015, 23:37:13 »
a bit more work
~kop
~S. Clemens
-Scruffy
Offline canyoncarver
  • 'hacking is learning'
Re: The Red Bike
« Reply #46 on: May 29, 2015, 00:13:01 »
Sexy wheels buddy.    Oh and Hey, when you try to tune those CV carbs with pods, I've got some shit for you to read. ...
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline Texasstar
    • Zoom With Zeke
Re: The Red Bike
« Reply #47 on: May 29, 2015, 11:28:33 »
a bit more work
~kop
pretty sexy
Honda Cb200 Lucky!
Offline kopcicle
Re: The Red Bike
« Reply #48 on: May 29, 2015, 18:15:06 »
I need to add that the clean up wouldn't have been possible without one amazing product .
http://www.ospho.com/
Once the orange had been scraped away with a wad of aluminum foil and a wire brush for the hard to get spots it was off to the buffer with the usual assortment of compounds .
final finish was done with
http://bluemagicusa.com/index.php/blue_magic/products/210/blue_magic_metal_polish_cream_jar/
I also use the Blue Magic as a finish for the aluminum covers .
A brief word about polishing . Heat is your enemy , oil and grease not far behind . When changing from coarse to finer compounds it's better to change the mop with it rather than mix grits . Although most modern auto wax and finish products will not turn color within reasonable temperatures a few will go blue or amber with just normal engine heat . To this day the only thing I've found for protecting the pipes is the oily rag ;-) .
And last but not least I made a final mop from circles cut from a chamois and stacked onto a a die grinder cut off wheel arbor . Too large a circle and the chamois just winds up on the shaft . Too small a circle and the die grinder easily over speeds the cloth and it disappears at extraordinary velocities .
~kop
~S. Clemens
-Scruffy
Offline kopcicle
Re: The Red Bike
« Reply #49 on: May 29, 2015, 18:17:59 »
I found the before pics
~kop
~S. Clemens
-Scruffy
