So... for SOME odd reason (ahem!), the LH turn-signal switch on my '71 Honda CB500 got... well, DISASSEMBLED, and now I'm having trouble figuring out how it goes back together.
What I'm looking at are the following, all from the inside of the switch housing:
* A white plastic sliding block
* A switch lever that protrudes through a slot in the housing and actuates the sliding block
* A contact bar with 3 soldered connections, from which 3 wires depend (blue, gray, orange)
* A teeny-weenie ball-bearing
* 2 springs, both small, but one slightly larger than the other
* A small, squared-"C"-shaped brass (?) clip
I can tell that the wires (as well as one end of the contact bar it looks like) are clipped under a silver, metal piece which holds them down in place, and I can also tell how the switch lever itself attaches to the sliding block to make it actuate - what I can't tell is the relationship of the ball-bearing, springs, and tiny "C" clip in relation to the 3-point contact bar, since the gubbins were concealed until I removed the set screw and everything fell out.
Dur.
Can someone describe or, even better, SHOW me in a pic or diagram how everything goes back together?
Thanks a million in advance for any assistance...
Dur.
