Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: Super Sized Clean Up CBX  (Read 2636 times)
Offline surffly
« on: May 17, 2012, 23:39:51 »
Was offered a 82 CBX at a price that I just could not pass up.
Bike has 6k miles and is very clean.
Stainless supertrapps ;D
Been sitting for a long time so it needs some love
LOL towing bikes home....
Thought that maybe some how the stars would aline and I would just start and ride it....
Carbs needed to be done.
Not really all that bad of a job
More bad luck....
A few of the valves were not sealing all that well so the motor came off and the head was removed
And the hits keep on coming....
The timing chain tensioner was broken.  what used to be a $45 part from honda is now $475!  bought a $100 USED one!
Well its not all that bad and this will be one hell of a fun bike when its done.
Offline Sonreir
  • Moderator
  • Oregon
Re: Super Sized Clean Up CBX
« Reply #2 on: May 18, 2012, 14:16:55 »
Is this your second CBX now?
1982 Honda CB750C - Project Zoidberg
1963 Yamaha YDS3
1973 Suzuki T500
1982 Yamaha Seca XJ750R
Custom Gauge Graphics
Custom Wiring Harnesses
If you wish to make an apple pie from scratch, you must first invent the universe.  - Carl Sagan
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
Whether or not you can never be great at something, you can always become better at it.  -Neil deGrasse Tyson
Basically, it comes down to this, do you know what your doing?  If not, forget about what you want and do what your told (sucks but that's life)  -crazypj
Offline surffly
« Reply #3 on: May 18, 2012, 14:31:53 »
No its the same one.
Really havent done much with it since I dragged it home.
Figured since I have the time now to really put some time into it I would keep track of things in a thread
Offline surffly
« Reply #4 on: May 20, 2012, 21:46:36 »
New bushings and seals for the forks.
New pads, seals, pistons, and slider boots.
The master will also be rebuilt and have the res replaced.
Offline surffly
« Reply #5 on: May 21, 2012, 19:41:00 »
Forks back on
Motor back together.
Not with out some issues.....
Offline andycafe
  • If you don't want anyone to know, Don't do it!
« Reply #6 on: May 22, 2012, 06:19:12 »
Nice work! there is always something that gives you grief eh! lol...........
Honda CB250rs cafe (Current project)
Honda CB400f brat (Next project)
The New Bike Thread
The workshop & deck build
If you can't fix it with a hammer, You've got an electrical problem mate!
Offline Maritime
« Reply #7 on: May 22, 2012, 09:36:21 »
I have broken those bolts 3 times and I think they get week with age because I never over torque.  Looking good so far, Sooo many parts for that motor, everything X6, but soo worth it when completed.
My Build: My full figured girl: http://www.dotheton.com/forum/index.php?topic=13950.msg135199#msg135199
Offline MajorWedgy
  • You don't have to go full throttle all the time.
« Reply #8 on: May 22, 2012, 12:40:12 »
I have the same bike.... just registered it about a month ago. My goal was to have a nice rider... but it turned into a total restoration. After 18 months I ended up with a REALLY nice bike.
1978 Honda CB750F Cafe Project
1982 Honda CBX
1984 Honda VF700s Sabre
1985 Honda VF1100s Sabre
1999 Honda Magna
2006 CBR 1000 Wrecked Parts Bike
Member of Cincinnati Cafe Racer
http://www.facebook.com/CincinnatiCafeRacer
http://www.CincinnatiCafeRacer.com
Offline surffly
« Reply #9 on: May 25, 2012, 17:58:59 »
Rebuilding the alternator
Mildly worn brushes.
I just want to get this thing on the road with a fresh start on everything
Figured I would polish the cover
Offline surffly
« Reply #10 on: May 27, 2012, 19:24:20 »
Alternator polished and ready to go back on the motor
Rear master rebuilt
New side cover rubbers to keep the nice clean covers from breaking
Front brakes back on.  just need to be brake bleed
Motor in
Installed new carb manifolds
Little trick.
These are DOHC Honda needles.  They replace the "tabbed" CBX ones.
And I found that CR750 that I was working on a long time ago....lol
Offline surffly
« Reply #11 on: May 31, 2012, 20:03:08 »
Been kinda of lazy for the last few days so not much has been done.
Front and rear masters and calipers are rebuilt and installed now just need to bleed them
Tank needs to be flushed out and the petcock rebuild is top on the list as soon as the carbs are on.
Just need to set the floats and 90% of things are ready to go back together.
Taking my time to make sure that the carbs are perfect before they go back on as its a real pain to get them off again
It is a large list of "just need to do"
Offline surffly
« Reply #12 on: Jun 17, 2012, 17:49:34 »
These carbs have been kicking my ass.
Almost ready to go back on the bike
Still need to order a battery, chain, sprockets, and shock.
This thing will be worth the effort just hearing the sound throw the pipes
Offline surffly
« Reply #13 on: Jun 29, 2012, 11:46:52 »
I should have known better, but I used some WD40 on the choke plate shafts when I was installing them.....now the plates dont turn.
When the choke is closed on the CBX a small spring closes the plates, but allows them to "flutter".  The WD40 leaves a sticky film when dry and is just enough to hole the plates open, the stickyness is stronger then the spring.  So I now need to take things back apart and clean them.  Cant have the chokes not working, and it a huge job to get the carbs on and off so I want these things to be perfect when they go back on.
The girl and other bikes have been making it hard to devote a few hours of actual focused work to the CBX....lame
Offline Swapmeet Louie
  • Put some metal in yer eye....
« Reply #14 on: Jun 29, 2012, 12:13:41 »
Suuuuuuuuuure, Rocan....haha oh, this is only pg 2. Not 200. sorry my mistake! :)
" an opinion form someone who knows not of which he speaks is worse than worthless" TEAZER
"Carb tuning is a black art. It's voodoo(sic), scientiology and comet worship all rolled into a pile. There's is no blue pill, it's a matter of taking the time and earning the bloody knuckles. " Swagger
