Poll
What to do about front fender??
Loose that ugly heavy POS
4 (40%)
Keep it as it looks quite classy
4 (40%)
Keep it and get a ped cutter
0 (0%)
Chop it in the front and hope you don't fuck it up.
2 (20%)
Total Members Voted: 10
Voting closed: Aug 10, 2012, 12:11:34
Author Topic: Honda cb350 pheonix build  (Read 27730 times)
Offline axeugene27
Re: Honda cb350 pheonix build
« Reply #20 on: Jun 09, 2012, 23:01:56 »
Well took the throttle cables out of the equation and bench synced the carbs per manual. The bike fires up first kick once it was warm. Still needed choke for the first couple times . It still idles insanely high with the choke on. I went with the lowest main jet I had which was a 190 and a 30 pilot jet which was the largest I had. I got it to fire good and adjusted the idle screws till it ran really good at idle. I was really impressed actually. It however seems extremely rich. For a set of carbs that were "set up" for this bike I am relatively  unimpressed. I think I really need to downsize the main jet and perhaps follow the set up from dcc.
Here is the set up i have right now. 190 main - pilot 30 - needle 6F4 - 159 P-5 (what is this????) - Slide is a 2.5 I don't know how to check the air jet??? Some new issues arose though. I re ran a compression test once the engine was warm. Left side is 150 right side is 135-140 I know that's not great and will prob have a top end rebuild on my hands come winter but i want to run it as far as i can this summer and i will have something to do this winter. I am pretty sure the engine is running rich though with that jetting engine is smoking pretty hard???? I know this motoer hasn't started in quite some time but everything seemed to get really hot quick. I think maybe just alot of the crap burning off the surface of the engine but Idk. Also It seems like alot of oil is making it into the left side case.I know it's suposed to get some oil int there but when on the kickstand oil is dumping in there and some is leaking out of the case. I will prob just get a new gasket kit for the engine since a rebuild is inevitable but wonder if getting this much oil in that side of the case is normal????? also realize the bike does not shift very well It will go into first and back to neutral with little effort but not smooth going into second and sometimes need to really work to get it to shift back to neutral. Maybe once warmed up it will get easier otherwise more reason i will need a gasket kit i will have to crack that other side cover and rework the clutch basket. Well it's a can of worms. Fucker was running though. Not near safe. not near rideable. BUt damn it it was running .....cool.
72cb350 barn burner build http://www.dotheton.com/forum/index.php?topic=37654.20
TITAN http://www.dotheton.com/forum/index.php?topic=53037.msg600706#msg600706
"it's better to have an ugly bike that runs well, than an pretty paperweight."
"bullshit goes a long way if you throw it right"
Offline axeugene27
« Reply #21 on: Jun 20, 2012, 12:28:31 »
Time for a little update. I have been working on body work as of lately. I did a whole write up on making my seat in another post. This is my second attempt as the first one was a semi flop and i just didn't like it so i redid one with better research/ measurements and products and it turned out to my liking.
[img width= height= alt=Image Hosted by ImageShack.us]http://img191.imageshack.us/img191/6919/imag0307tn.jpg[/img]
By <a target="_new" href="http://profile.imageshack.us/user/axeugene27">axeugene27[/url] at 2012-06-20
I am working on doing some body filler work on the tank as well trying to get the knee dents smoothed out and ready for paint. I wasn't going to paint but i really wanted to fill in those emblem spots and get those dents super smooth so here we are . Did i mention i hate doing body work and am just cutting my teeth at it.
[img width= height= alt=Image Hosted by ImageShack.us]http://img840.imageshack.us/img840/6940/imag0309d.jpg[/img]
ON another note i got the engine idling well yesterday and actually took the bike for a leisurely stroll through the neighborhood. Got some funny looks as my bike is very rough yet and putts around pretty poorly. Got her to idle really well after i got the ignition system in order. Just have to dial in the jetting i think and i may have myself a good runner. Rechecked compression was 170 on right and 160 on left after warm engine!!!! Pretty happy with the bike right now. It is really killing me all the dirt and knicks you obtain while constantly wrenching on it but hey that's the breaks. I will never paint an engine black again in my life. I think i will rebuild it this winter and the color is def getting changed. Just shows everything.
Offline axeugene27
« Reply #22 on: Jun 20, 2012, 12:31:50 »
Thinking of doing a 2 tone paint job with deep wine maroon and a cream scallop outlined in a gold stripe. Think Modified triumph Want the scallop to run straight down the tank and look like it continued under the seat and come up on the cowl. Contacted a painter to have it done pro. I got quoted $450. I know nothing about paint but thought that sounded pretty reasonable. I Know i can rattle can it for about 150 so i am tossing around that idea just don't know how the rattle can job will turn out. I've had good results in the past but i prefer great results. You guys think 450 is a good price for that described paint job?
Offline axeugene27
« Reply #23 on: Jun 25, 2012, 18:36:28 »
just a little update have been working on getting the body work in order a little more smoothed the cowl out with some body filler and perfected the knee dents they look pretty nice if you ask me. I am considering pro paint but have had some random expenses recently and don't know if i can swing it might do a semi pro rattle can deal for now. I hate to do that but it's pretty flippin costly. Have had some running issues i describe in this thread any comments are welcome.
http://www.dotheton.com/forum/index.php?topic=38633.0
Other than that i ordered some bar end mirrors, some new grips, a condenser and some more jets from dcc. waiting on those parts and some time to get er painted. Till then I am gonna work on tuning these carbs I won't get into the issues i'm having with that as it is in the above listed thread.  But what do you guys think on a paint scheme. I have pretty muched narrowed it down to three possibilities,
1. Wine with cream racing stripe bomber brown leather seat cover
2. Deep green with cream racing stripe bomber brown leather seat cover
3. pacific blue with cream racing stripe bomber brown leather seat
Really want to maintain a vintage asthetic with her and keep it classy san diego.
[img width= height= alt=Image Hosted by ImageShack.us]http://img442.imageshack.us/img442/2406/imag0319a.jpg[/img]
By <a target="_new" href="http://profile.imageshack.us/user/axeugene27">axeugene27[/url] at 2012-06-25
[img width= height= alt=Image Hosted by ImageShack.us]http://img137.imageshack.us/img137/4641/imag0318i.jpg[/img]
[img width= height= alt=Image Hosted by ImageShack.us]http://img607.imageshack.us/img607/9171/imag0320g.jpg[/img]
[img width= height= alt=Image Hosted by ImageShack.us]http://img88.imageshack.us/img88/9349/imag0317m.jpg[/img]
Offline axeugene27
« Reply #24 on: Jul 10, 2012, 15:58:49 »
just wanted to update this thread a little. I haven't had a ton of progress lately. Working on the body work is slow and tedious. I have the body work all sorted out and rattle canned some forest green pearl. I am having sonreir make me some custom decals. I am waiting on them to clear coat but have spray max 2k and my booth all set up. I am pretty happy with the color and how the knee dents turned out. I got the tail end sorted out with the lucas taillight and it is growing on me. THe headlight is in place but i think i will eventually swap the headlight and brackets. I would like slightly smaller chrome headlight with brackets that suck the light in a bit more. Gonna roll with this one for now. Other than that just some glamour shots. I am desperately hoping to have her road ready by mid ohio. I want to have some miles on her too before I put her on that long of a ride. Thanks for looking guys and let me know what you think..
Ryan
[img width= height= alt=Image Hosted by ImageShack.us]http://img825.imageshack.us/img825/4263/p7100387.jpg[/img]
By <a target="_new" href="http://profile.imageshack.us/user/axeugene27">axeugene27[/url] at 2012-07-10
[img width= height= alt=Image Hosted by ImageShack.us]http://img521.imageshack.us/img521/3890/p7100389.jpg[/img]
[img width= height= alt=Image Hosted by ImageShack.us]http://img819.imageshack.us/img819/5903/p7100388.jpg[/img]
[img width= height= alt=Image Hosted by ImageShack.us]http://img13.imageshack.us/img13/5595/p7100383.jpg[/img]
[img width= height= alt=Image Hosted by ImageShack.us]http://img855.imageshack.us/img855/129/p7100385.jpg[/img]
[img width= height= alt=Image Hosted by ImageShack.us]http://img29.imageshack.us/img29/865/p7100382.jpg[/img]
Offline Bobbed_out
« Reply #25 on: Jul 10, 2012, 19:44:19 »
Looking good. I like the color, will look great once all done and cleared
76 kz400- bobber project
75 cb360-cafe project
90 vfr750-???
Offline axeugene27
« Reply #26 on: Jul 16, 2012, 22:06:49 »
got word the decals are on the way. Prob get her cleared by the end of the week. If by some miracle i have it up and running well by saturday I may take her to mid ohio. Prob not though sadly. I need to make a list of goodies to buy. I don't know how i intend to get parts back on the bike but will take a big pack. Prob look into getting some better headlight brackets/ headlight/ rear sets/ possibly upgrade rear shocks/ engine bolt kit. might try to source some upholstry work too as i really don't think i should do it myself.
Offline Blackbomber
« Reply #27 on: Jul 16, 2012, 22:28:54 »
Nice build, and I like the color. Thread bookmarked.
Long term CB350 project
Offline axeugene27
« Reply #28 on: Jul 22, 2012, 12:57:06 »
Got my decals in the mail. Thanks sonreir. Got them on the tins. Oh my it's harder to lay racing stripes than i had imagined. But got them on as well as I possibly could. Got the first coats of clear on them. Now just letting them cure gonna wet sand and clear again then go to the buffing stage. Also found a guy local to do the seat. Leather is a bit costly so prob gonna go with vinyl I really don't like the look of brown vinyl so prob gonna go with black vinyl with white or tan stitching.
[img width= height= alt=Image Hosted by ImageShack.us]http://img832.imageshack.us/img832/8527/p7220405.jpg[/img]
By <a target="_new" href="http:/[img width= height= alt=Image Hosted by ImageShack.us]http://img812.imageshack.us/img812/1060/p7220406.jpg[/img]
By <a target="_new" href="http://profile.imageshack.us/user/axeugene27">axeugene27[/url] at 2012-07-22/profile.imageshack.us/user/axeugene27">axeugene27[/url] at 2012-07-22
[img width= height= alt=Image Hosted by ImageShack.us]http://img140.imageshack.us/img140/8662/p7220404.jpg[/img]
[img width= height= alt=Image Hosted by ImageShack.us]http://img440.imageshack.us/img440/7286/p7220403.jpg[/img]
RotaryDanglish
  • Guest
« Reply #29 on: Jul 22, 2012, 13:05:41 »
Nice, the green and creme looks great.
Subscribed.
