www.Moto-Madness.com
Author Topic: Carb intake boots - use silicone?  (Read 1222 times)
Offline gomotomoto
« on: May 30, 2012, 10:12:22 »
I picked up a nice set of used intake boots from Sonreir. Should I use a bit of silicone between the boot and gasket to ensure an airtight seal?
The boots are in great shape, but theres a slightly imperfect surface as they were installed before; and have a bit of crud on them. I managed to smudge most off, but still a bit remains.
I can't imagine and downsides to silicone, but have never done before.
Online Tim
  • Administrator
    • DO THE TON
Re: Carb intake boots - use silicone?
« Reply #1 on: May 30, 2012, 11:11:51 »
You could use some Threebond 1194 (also known as Yamabond, Hondabond etc.) or some gasket adhesive just to ensure a good seal and it also I believe makes it easier to disassemble in the future (spray gasket adhesive, not Threebond).
I used spray gasket adhesive on pretty much every gasket on my XS650 engine rebuild (except the base gasket where they specifically said not to, and I used some Threebond on the head gasket around critical areas) and I'm leak free.
Offline gomotomoto
« Reply #2 on: May 30, 2012, 11:21:34 »
Thanks Tim, appreciate that.
