sweet one dude......being from sydney you must be a scr member yeah??i myself am in bondi junction at the moment but i work on my bikes in miranda....and yes the cold is a biatch for painting at the moment....although ive had some success.....the smaller parts i chuck in the oven....get one of those cheap heaters that doesnt have a fan.....not like an oil heater.....they use an element and have a reflective foil on the inside that radiates heat.....also spray the floor down with water an hour before you spray...this stops dust coming off the floor when you walk around.spray one side at a time and leave the wheels infront of the heater between coats....it also helps if you soak the spraycans in hot water...it also helps if you use good paint.....not the cheap shit in bunningswhilst all this is going on im sure you can find plenty of things to do on the bike with you new goodies from webbike japan.what are your plans for a seat?peacejames
The bad thing about the 2-1 is only 2 companies (1 is in the states) make them and they cost an arm and a leg. I'm having my 2-1 custom made for about the same price as buying the ones that everyone has. If you're dropping the airbox to run pods, loosing the h-box will make getting your carbs tuned in a lot harder. I dropped mine and have pods and it's been hell trying to get them adjusted right. That's why I'm doing a Mikuni swap in the very near future.
Mine used to have sportster take offs. I've seen the emgo cigar mufflers look pretty good on it. I bought a supertrapp and intend mounting underneath the engine. I really like these on the CX...emgo shorty setup
