Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.townmoto.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: points or condenser  (Read 277 times)
Offline jomama
points or condenser
« on: Jun 15, 2012, 21:43:02 »
OK Lads here is a problem that I cant seem to solve so any insight would be greatly appreciated. On my cb360, at idle the R cylinder pops through the carb and pops out the muffler. When the right plug is disconnected it quits. Runs fine on the left one alone. The spark from the grounded R plug is good at anything above an idle but poor to intermiten at idle. I checked the points and the R setdo not arc at all. Whats up here?n is constantly arcing while the L which is good and strong does not arc at all. Could I have a condenser going south on me? The coils are within specs . I mean the R points arc like crazy while the L ones dont arc at all and that cylinder runs perfect. Iterestingly enough it starts and runs pretty good at speed but idles like sh t.
Offline Sonreir
  • Moderator
  • Oregon
Re: points or condenser
« Reply #1 on: Jun 15, 2012, 21:47:22 »
Possible bad connection in the plug caps.  Popping in the carbs and muffler is a classic lean symptom though (and almost definitely not related to your spark issue).  I think it may be time to clean the carbs.
1982 Honda CB750C - Project Zoidberg
1963 Yamaha YDS3
1973 Suzuki T500
1982 Yamaha Seca XJ750R
Custom Gauge Graphics
Custom Wiring Harnesses
If you wish to make an apple pie from scratch, you must first invent the universe.  - Carl Sagan
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
Whether or not you can never be great at something, you can always become better at it.  -Neil deGrasse Tyson
Basically, it comes down to this, do you know what your doing?  If not, forget about what you want and do what your told (sucks but that's life)  -crazypj
« Reply #2 on: Jun 16, 2012, 00:25:40 »
Sonreir is right...first thought that came to mind with back firing is a lean condition.  Run it for a few minutes and check your plug burn to verify.  Cleaning the carbs isn't a bad idea...Also check for any air leaks in/around the carbs.  Use carb cleaner or starter fluid.  When it gets sucked in the RPM will change (lower for carb cleaner/higher for starter fluid).  That'll help you find if any leaks.
Offline jomama
« Reply #3 on: Jun 17, 2012, 22:26:28 »
Well lads the starting fluid was the give away. Immediate rise in RPMs when sprayed on R intake. After I replace (locate first) the intakes I will persue the weird spark issue.
Offline Yeahbro
« Reply #4 on: Jun 25, 2012, 03:18:02 »
Sounds Like a bad condensor to me. A lean condition will not cause the points to arc.
