Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: RD250 Engine leaking, where is it coming from and what is it?  (Read 709 times)
Offline JiveTalkinRobot
Hi all,
Well I've finally got her started up and running.  However, overnight the engine seems to leak, not sure what it is and how to solve it.
I have an RD250 (with rebuilt 350 top) and use premix, not the Yamalube.
Here are some pics of where the puddles are if it's helpful.
And for safe measure, this is the off position for the petcock right?  I had a hard time understanding the diagram in the service manual because it looked different and was inverted.  I'm looking really mentally challenged right now....I realize this.
Thanks in advance.
« Last Edit: Jun 18, 2012, 15:18:56 by JiveTalkinRobot »
Offline Sonreir
  • Moderator
  • Oregon
Re: RD250 Engine leaking, where is it coming from and what is it?
« Reply #1 on: Jun 18, 2012, 15:04:53 »
Off position on the petcock is almost always in the middle.  Check under your crank cases for leaks.  Any leaks there and you're getting robbed of power as well as leaking fluids.
« Last Edit: Jun 18, 2012, 17:07:29 by Sonreir »
1982 Honda CB750C - Project Zoidberg
1963 Yamaha YDS3
1973 Suzuki T500
1982 Yamaha Seca XJ750R
Custom Gauge Graphics
Custom Wiring Harnesses
If you wish to make an apple pie from scratch, you must first invent the universe.  - Carl Sagan
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
Whether or not you can never be great at something, you can always become better at it.  -Neil deGrasse Tyson
Basically, it comes down to this, do you know what your doing?  If not, forget about what you want and do what your told (sucks but that's life)  -crazypj
Offline VonYinzer
  • Site Supporter
  • We go where eagles dare...
« Reply #2 on: Jun 18, 2012, 16:03:46 »
Off position on the petcock is always always in the middle.  Check under your crank cases for leaks.  Any leaks there and you're getting robbed of power as well as leaking fluids.
Not always true. My petcock points forward for OFF. So does this one. You have it in the RESERVE position, which will allow fuel to flow. Look very closely at the petcock. The positiongs are stamped into the plate that holds the lever on.
As far as the leak, its certainly oil. Where its coming from is whats important though. If its a bad seal, you likely need to rebuild the motor. If its just a cover gasket or drain plug seal, youre lucky. Honestly though, between this and your other thread on this bike (why two threads by the way?) I have a feeling that you have some real work ahead of you.
If you want a vision of the future, imagine a boot stamping on a human face - forever.
George Orwell
« Reply #3 on: Jun 18, 2012, 16:09:47 »
New to forums, I figured this was the "I need help on a specific topic" area...and then the other one was more for providing updates about your build.
Offline VonYinzer
  • Site Supporter
« Reply #4 on: Jun 18, 2012, 16:23:25 »
Gotcha... All good man, just wondering. Where are you located? Id see if there was a more experienced member local to you that would swing by and take a look.
George Orwell
« Reply #5 on: Jun 18, 2012, 16:40:04 »
Yeah I might do that, I'm in Southern California.  Seems to be a few members here.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #6 on: Jun 18, 2012, 17:08:15 »
Ooops.  Sorry... that was a typo... I meant to write "almost always" but accidentally wrote "always always".
1963 Yamaha YDS3
1973 Suzuki T500
Offline Redbird
  • Dolor est Magister Optimus
« Reply #7 on: Jun 18, 2012, 20:26:08 »
My DS7 had the same issue...
Take a dry rag and wipe the bottom of the shift lever shaft first, and then the bottom seam of the side cover (where it bolts to the case). If you get oil in one location but not the other, it's either the shifter shaft seal or the neutral indicator switch o-ring that's bad. If you get oil in both locations, it's probably just the shift shaft seal and it's leaking all over both locations. Either way, both the seal and o-ring aren't that expensive and relatively easy to change. They're right next to each other behind that cover, so change them both while you have it apart. That'll save you from pulling it all apart again in a month or so when the "other one" goes bad.
Those who Dance, are often thought Insane, by those who can't hear the Music
Offline Spoonz
« Reply #8 on: Jun 18, 2012, 21:50:49 »
Did you put a new gasket on the drain plug? Even if you think yours is good, if its been tightend down then removed you need to replace it. It is a one time use gasket. A copper gasket will work and you can reuse it a few times. Shift shaft seals go often too.
« Reply #9 on: Jun 18, 2012, 21:57:31 »
I think I will buy all the gaskets and seals mentioned and also this: http://www.economycycle.com/servlet/the-50/Vesrah-Complete-Gasket-Set/Detail
and just replace everything.
Offline Swapmeet Louie
  • Put some metal in yer eye....
« Reply #10 on: Jun 18, 2012, 22:05:59 »
ya, thats a shaft shaft seal.....
" an opinion form someone who knows not of which he speaks is worse than worthless" TEAZER
"Carb tuning is a black art. It's voodoo(sic), scientiology and comet worship all rolled into a pile. There's is no blue pill, it's a matter of taking the time and earning the bloody knuckles. " Swagger
Offline Spoonz
« Reply #11 on: Jun 18, 2012, 22:13:05 »
Not true... My RD off is back, run is down, and reserve is forward. My Honda is off forward, reserve down, and run back
« Last Edit: Jun 18, 2012, 22:15:15 by Spoonz »
« Reply #12 on: Aug 11, 2012, 17:03:47 »
engine gaskets replaced, shift shaft seal replaced, neutral indicator o-ring replaced....
...still leaks.
Not sure what it could be at this point.  I guess the final remaining thing is the drain plug gasket.
