Author Topic: Justin's DT tank.  (Read 7374 times)
Offline milehigh
  • for your health, dummy.
Justin's DT tank.
« on: Jun 27, 2012, 11:57:56 »
Here is a rough start on Justin's tank.  All the metal work is finished, been testing different paint to see what sticks best.  Scribbled down an outline last night about 40x and kept testing different paints...i think i've cracked the code, now its time to lay down some patient awesome shit.
so a dolphin is driving and his car breaks down...he takes it to a mechanic...the mechanic says its going to be a few hours if he wants to wander around the town...upon his return, the mechanic says "looks like you blew a seal" to which the dolphin replies: "no sir, it was a walrus"
Offline JustinLonghorn
Re: Justin's DT tank.
« Reply #1 on: Jun 27, 2012, 12:03:46 »
Yep. I can definitely dig it!
Into The Sunset, CB750 build
TT500 the Animal
Offline axeugene27
« Reply #2 on: Jun 27, 2012, 12:26:15 »
The only concern I would have is oxidation of the raw tank . I think usually guys treat tanks with wd40 or something like that regularly to prevent this but how do you plan to protect the paint from the solvent?. I had thought of doing something like this but ran into this conundrum. I have heard that the raw metal can actually show oxidation under clear coat as well. Just a thought.
72cb350 barn burner build http://www.dotheton.com/forum/index.php?topic=37654.20
TITAN http://www.dotheton.com/forum/index.php?topic=53037.msg600706#msg600706
"it's better to have an ugly bike that runs well, than an pretty paperweight."
"bullshit goes a long way if you throw it right"
Offline hurley209
« Reply #3 on: Jun 27, 2012, 12:27:11 »
clear coat dude.
your mom
your sister
yeeeeah buddy
Offline hurley209
« Reply #4 on: Jun 27, 2012, 12:28:49 »
oh and awesome lol
your mom
your sister
yeeeeah buddy
Offline milehigh
« Reply #5 on: Jun 27, 2012, 12:52:23 »
this ain't my first rodeo. lol.  the metal raw would certainly have some corrosion if left that way--esp. considering the spirals strip it down to a fresh layer.  That being said, it also provides the cleanest look to the tank.  I've found that some 2k paint does the trick, adheres pretty well and does not allow for oxidation or solvent damage.  Check the tank on my CL450...been that way for months, hasn't changed a bit--rain, gas, whatever, not a change.  There are also other alternative coatings you can put on there to protect a bare tank, if that is your desired look.  Check out Gibbs penetrant http://www.roadsters.com/gibbs/  shits pretty awesome from what i've heard.  The 2k clear coat gives the tank a constant wet look and is really bulletproof stuff--just don't inhale it or you die. X-(
Offline axeugene27
« Reply #6 on: Jun 27, 2012, 12:56:24 »
Yeah i saw your tank and had the same thought. Only time will tell i suppose. Does the 2k clear have good adherence to raw unetched metal without primer?
Offline milehigh
« Reply #7 on: Jun 27, 2012, 13:14:43 »
Seems to be ok thus far.  Got to do some heavy coats to make it thick enough to hold up.  I've also heard the POR15 DTM 2k works well...but haven't tried it yet.  If it fails, its just a matter of removing it and redoing it...so its not like there is much concern there.
Offline Swapmeet Louie
  • Put some metal in yer eye....
« Reply #8 on: Jun 27, 2012, 14:38:42 »
I like...
" an opinion form someone who knows not of which he speaks is worse than worthless" TEAZER
"Carb tuning is a black art. It's voodoo(sic), scientiology and comet worship all rolled into a pile. There's is no blue pill, it's a matter of taking the time and earning the bloody knuckles. " Swagger
Offline Bellicose
« Reply #9 on: Jun 27, 2012, 19:26:20 »
Try some POR15 Glisten PC. Designed for metal, brass, copper and all sorts of other surfaces and looks like glass when finished.
"IF IT STAYS STILL LONG ENOUGH, I"LL PAINT IT"
