Author Topic: 1977 Honda CJ360 - Café SOS - Stage Two™  (Read 42576 times)
Offline Sonreir
  • Moderator
  • Oregon
« on: Jun 30, 2012, 20:30:29 »
OK...  I've decided to put an end to my old thread and start a new one as I consider the first part of the project done and the bike is riding and running well.
If you haven't read the thread for stage one, you can find it here: http://www.dotheton.com/forum/index.php?topic=19672
Stage Two™ is going to mainly consist of fixing anything that didn't quite work out from stage one as well as some general improvements.  I'm approaching this stage with two extra years of experience I didn't have at the beginning of my first stage and I've spent some time thinking and planning.
I kinda wanted to keep you all in suspense as to what I had planned, but I decided against it.  Hopefully it will be just as interesting to know up front and then see it come to realization.  I know it will for me, anyway...
Stage Two™ Improvements (in rough order)
  • General fixes I deem necessary after running the bike for a while after the completion of stage one.
  • Replacement of the analog speedometer with a digital computer with all-in-one speedo/tach/temps sensors, etc
  • Racing style vent for the gas tank Done
  • Removal of stock foot controls and replacement with rearsets - '88 FZR rearsets ordered from eBay for $40
  • Upgrade to the charging system in order to allow use of more electrical gadgetry
  • External oiling system (including cooler) for the cam journals
  • Upgraded suspension both front and rear
  • Venting for the front and rear drum brakes
  • Replacement of stock steel wheels with shouldered aluminum rims
« Last Edit: Jul 25, 2012, 20:37:01 by Sonreir »
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Sonreir
  • Moderator
  • Oregon
Re: 1977 Honda CJ360 - Café SOS - Stage Two™
« Reply #1 on: Jun 30, 2012, 21:00:23 »
OK... first problem to deal with... Remove those zip ties holding my battery in place and get something better and more permanent.
Enter $2 leather belt from Goodwill.
First up, cut said belt into pieces and rivet to my electronics tray:
Next, strap the battery into place using the plastic clasp that came with the belt:
Finally, use a brass clasp (riveted to the belt) to finish things up.  A spare bit of metal left from one of the rivets serves as a pin to keep the clasp from opening:
Though not shown in this pic, I went back and put the wires under the first belt section to help keep some tension off of the terminals.
Offline axeugene27
« Reply #2 on: Jun 30, 2012, 21:04:52 »
A humble suggestion I simply bought industrial velcro straps from lowes. and put a couple thick cuts into the pan and laced it through them and around the battery.. You couldn't rip that battery off the pan.
72cb350 barn burner build http://www.dotheton.com/forum/index.php?topic=37654.20
TITAN http://www.dotheton.com/forum/index.php?topic=53037.msg600706#msg600706
"it's better to have an ugly bike that runs well, than an pretty paperweight."
"bullshit goes a long way if you throw it right"
Offline DoTheJon
  • surfing and motorcycles.... yup
« Reply #3 on: Jun 30, 2012, 21:07:34 »
cool man, i'm tuned in
My CB360 Barn find http://www.dotheton.com/forum/index.php?topic=29298.20
“America is all about speed. Hot, nasty, badass speed.”-Eleanor Roosevelt, 1936
Offline pandknz
« Reply #4 on: Jun 30, 2012, 22:40:34 »
How is the Battery for height? I think I will do a similar thing but I will use a sealed gel battery and lay it on its side.
Offline Swapmeet Louie
  • Put some metal in yer eye....
« Reply #5 on: Jun 30, 2012, 22:51:03 »
That "is" a sealed battery. He can run that anyway but upside down.
" an opinion form someone who knows not of which he speaks is worse than worthless" TEAZER
"Carb tuning is a black art. It's voodoo(sic), scientiology and comet worship all rolled into a pile. There's is no blue pill, it's a matter of taking the time and earning the bloody knuckles. " Swagger
Offline 3DogNate
  • "You Meet the Nicest People on a Honda"
« Reply #6 on: Jul 01, 2012, 00:37:08 »
Interested in your speed/tach choice if you've already done your research. I'm heading in that direction also, the digital gauge is One of those things I keep coming back to.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #7 on: Jul 01, 2012, 02:05:49 »
I'm currently working on getting onto the supplier's list for a company called TrailTech.  They make a lot of gear (mostly for offroad use) and they have a couple of computers that act as speedos and tachometers as well as other functions.
I have one of these on the way to me:
http://trailtech.net/vapor.html
Hoping to resell some at around $110 (includes shipping) once I get the details worked out.
Offline DoTheJon
« Reply #8 on: Jul 01, 2012, 08:28:12 »
i ran the vapor on my ducati monster, it worked pretty good youll like it.
Offline 3DogNate
« Reply #9 on: Jul 01, 2012, 11:48:21 »
The vapor looks pretty cool, i might be down for one of those. I like that it doesn't have a bunch of indicators that we don't need (fuel level, coolant temp, oil pressure, oil temp) but you can add the indicator dashboard to get them.
Unfortunately there are a ton of super cool digital speed/tach combos for V-twins that only go to 8k on the tach...
I keep coming back to this guy too.
Koso DB-01R
http://www.amazon.com/Koso-Multi-Function-Electronic-Speedometer-BA018B00/dp/B0022XS6K4
