Quantcast
Author Topic: Board tracker bobber  (Read 8961 times)
Offline JRK5892
    • The Powder Pro
« on: Jul 10, 2012, 11:54:21 »
ok so stick with me on this one... so i started this build in 2008... then life happened and it got pushed to the back of the line... then the shop expanded and we have been building bikes, sleds, quads, you name it... well now it is finally the 350's time... it is insane how much has changed since the start of this project so alot of this will be a catch up, and then of course to re-do what i had done before. Now with Tim around and his unreal ability to work with metal and mad man welding skills the bike will finally have the life it started out for so many years ago...
first lets get updated from the past
I rode this bike in college... here is when i got home from school
tear down started
first tank i knee dented
then... about here is where we come in and need to start to redo... i changed the upper rails
then a buddy stretched the swing arm for me
FAST FORWARD TO THE START OF THIS WEEK
Tim and i pulled her from under the covers in the back and decided to build and sell the bike... so here we go
stripped down
made an adjustable bar to figure out ride height and trail so we could move the shock mounts on the swing arm
installed the knobby front tire on a 21 rim... i thought i got a XL250 rim however i got a KL250 rim so this will not work... the XL rim works perfect for the center hub of a 15mm axle, where as the KL has a 12mm... so ill have some spokes cut and i can lace the 21 hoop to the stock 350 hub... i think it will look much cleaner to have it all match front and rear hubs anyway... the back will get a vintage ribbed tire
for mock up a temp axle was made up to work
now we tried to figure out what tank... bear in mind we want to powder everything so the bondo on the knee dent tank would not really work so well and we would have to bust out the guns and shoot it if we went this way...
while that was noodled on... shaved the ears
then we decided on a tank... Tim sectioned the frame... this will all later be welded in and re enforced... rather than re tunneling the tank we are going to mod the back bone
also the stock mounts kind of sucked so those where redone
and with that we have a profile
and here she sat last night as we stared at it trying to plan our next step
« Last Edit: Jul 10, 2012, 12:03:33 by JRK5892 »
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline Maritime
Re: Board tracker bobber
« Reply #1 on: Jul 10, 2012, 13:23:10 »
I really like the stance you have on her so far.  Nice tank choice too.  You going to put a knobby on the rear too?  I think it would tire them in, kind of a back road bomber style.
Offline pablohoney
  • Don't Call Me Shirley.
    • Motorworks Illuminated
« Reply #2 on: Jul 10, 2012, 13:32:32 »
That's looking pretty sick dude. I would love to do a board tracker one day.
Engine Lamps!
http://facebook.com/illuminatedmotorworks
1979 xs650 special "Rock&Roll"
http://www.dotheton.com/forum/index.php?topic=20575.0
1984 GPZ750 "The Ferrous Mistress"
http://www.dotheton.com/forum/index.php?topic=31393.0
2003 Honda CBR600RR "Molly"
Offline DesmoBro
  • Busted Nut
« Reply #3 on: Jul 11, 2012, 02:58:41 »
an extra set of hands and idea's can go A LONG WAY! Nice to see this one come out from the wood work
"I desire the things that will destroy me in the end"
Offline andycafe
  • Northern Suburbs, Melbourne Victoria, Australia
« Reply #4 on: Jul 11, 2012, 08:17:01 »
yeah, this will be a cool little bugger! nice work boy's..............................................  ;)
Offline JRK5892
    • The Powder Pro
« Reply #5 on: Jul 11, 2012, 18:31:11 »
spent some time doing the small things today like cleaning up the frame... next we will jig it and redo the back section of the frame
tank mount is no more
center stand supports
Joe
Offline JRK5892
    • The Powder Pro
« Reply #6 on: Jul 12, 2012, 11:55:08 »
well the awesome fun of building a vintage bike strikes again... just when i get a new swing arm on the way... found the 2nd issue... the trees are done on this bike... done... the back up set that i have is different, but the fork tubes are destroyed on the back up set... soooooo looking for a new set of trees now... after the upper tree is all shaved and looking clean now we may not be able to use the upper either...
smooth shaved upper
few shots of the lower tree
but now on to some cool stuff!
time to fill in the area for the frame that was cut out to allow for the new tank to work
then Timmy welded up the seam and smoooooothed out the back bone
next to address the tank sitting so high on the back bone the seam that these fames have needed to be removed... this was done in sections filling in the area with weld till it was completed and smooth
then some small things... found the seat pan kit i had stashed away... ditching the bee hive springs and going to 3.5 Torsion Springs instead
trying to keep the vintage look i did find a HUGE old school speedo that we'll tear down and restore
then last i am going to convert this old brass bell into a tail light for the bike
Joe
Offline Maritime
« Reply #7 on: Jul 12, 2012, 14:46:02 »
Wow Joe, too bad you are selling it, someone is going to end up with a sweet little bobber.  Heal up so you can at least rip up the road once before you sell it.
Offline JRK5892
    • The Powder Pro
« Reply #8 on: Jul 12, 2012, 14:51:14 »
thanks man... we are going to try to start flipping some vintage bikes... there are like none out here cause all the shops will refuse to work on them.  so this way we can be the go to shop for work/bikes... plus, i love working on them!
Joe
Offline Maritime
« Reply #9 on: Jul 12, 2012, 14:55:01 »
Good plan.  I know what you mean very few shops around here will look at old bike either.  I know 1 good shop but they are like 2 months backlogged with re-builds etc. I feel like setting up something for fixing old bikes up too, once I get a little more knowledge under my belt.
