Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: Suzuki GS1000gl bogging out when in gear and accelerating?  (Read 1030 times)
Offline muskywhisperr
Hello,
 I am having some problems with my bike here and have no idea what it is.  Basically when it is neutral everything is fine, But when i put it in gear and start to accelerate the bike has no power and just completely falls on its face.  It also kind of spits and sputters.  It is a 1980 Suzuki GS1000GL and  I thought it was something with the carbs so i sent them to crazypj and he got them all squared away so thats out.  Any ideas?
75 Honda cl360 In progess
77 Honda CB550SS up next
80 Suzuki GS1000GL Back burner
Online Sonreir
  • Moderator
  • Oregon
Re: Suzuki GS1000gl bogging out when in gear and accelerating?
« Reply #1 on: Jul 24, 2012, 19:36:47 »
Try a fresh battery and double-check your timing (provided the bike uses a Kettering system).
1982 Honda CB750C - Project Zoidberg
1963 Yamaha YDS3
1973 Suzuki T500
1982 Yamaha Seca XJ750R
Custom Gauge Graphics
Custom Wiring Harnesses
If you wish to make an apple pie from scratch, you must first invent the universe.  - Carl Sagan
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
Whether or not you can never be great at something, you can always become better at it.  -Neil deGrasse Tyson
Basically, it comes down to this, do you know what your doing?  If not, forget about what you want and do what your told (sucks but that's life)  -crazypj
« Reply #2 on: Jul 24, 2012, 19:51:28 »
It very well could be the battery cuz I'm not sure how old it is and I have yet to ride this  bike when it was actually running good. Thanks Sonreir I will try that out
Offline DesmoBro
  • Site Supporter
  • You Can Make A Difference!
« Reply #3 on: Jul 24, 2012, 21:25:35 »
I had the same problem on my KZ and it was the timing advancer i'll show you some pics if you pop your side cover off and it looks anything like these you have found your problem....Basically some WD40 and moving it around fixes the problem
« Reply #4 on: Jul 24, 2012, 22:19:26 »
Okay so I am really green to this stuff :) .  So the timing advancer is ahead of the clutch?  If so I think I'm the first person to take the cover off cuz it's spotless, doesn't mean that it isn't sticking though.  Can I run the bike with the cover off to see what it does?  What should it do, Thanks much.
Online Big Rich
  • Site Supporter
  • Let your past make you better, not bitter.
« Reply #5 on: Jul 24, 2012, 22:43:48 »
Suzuki's are notorious for um......."sub standard" electrical systems. Fresh battery, clean connections everywhere, test the stator & R/R, etc. It sounds like you are running on 3 cylinders though (maybe just 2?).
Offline DesmoBro
  • Site Supporter
« Reply #6 on: Jul 24, 2012, 23:17:02 »
My stator Cover Was really clean inside but on the opposite side it was the worst I had ever seen....But all these bikes are a little different not sure which side yours is on
Offline DesmoBro
  • Site Supporter
« Reply #7 on: Jul 24, 2012, 23:24:00 »
You can run the bike with the cover off...but on my KZ you can't see the advancer unless you take the plate in the picture off it's behind that and has 2 moving parts and the timing marks become misaligned if they don't get lubed occasionally causing it to rev only to 5,000 rpm or so and not go above that
« Reply #8 on: Jul 25, 2012, 21:30:05 »
Okay now I think we are onto something here desmo.  Here is a pic of mine.  It moves about an eighth of an inch in clockwise direction and the springs bring it back.  However the what i assume are brushes are gone and flush with the two black plastic pieces in the pic so there is little to no contact being made.  What are they called and where can i get them?  Thanks for everyones help with this it is appreciated.
« Reply #9 on: Jul 25, 2012, 21:35:22 »
Sorry for the bad pic but you get the idea.  Should I spray it down with some WD?  Also it's mainly doggy on the bottom end and once you hit a certain rpm it hooks up and happy times are had. ;D
« Reply #10 on: Jul 25, 2012, 21:52:15 »
Here is a better pic and please deal with me here but the contact point inside the black plastic piece is flush with the outside of the black plastic piece so there is not really any contact at all.
Offline DesmoBro
  • Site Supporter
« Reply #11 on: Jul 25, 2012, 22:21:57 »
Those look Fine what you want to check is behind that Plate the plastic units are mounted on..... That's your problem i'm assuming the timing marks aren't lined up which is the case with mine I actually got mine working but now it works really intermittently so I may need to re-check the timing....The Timing Advancer (you can see it behind the plate see the little springs)  I'll have to get a picture of it tomorrow when I Fix it again
Offline crazypj
  • Site Supporter
« Reply #12 on: Jul 28, 2012, 04:56:16 »
Did you check wiring?
I gave my girlfriend an orgasm the other night, but, she spat it back at me
« Reply #13 on: Jul 28, 2012, 20:11:39 »
I have not gotten around to picking up a voltohmeter  yet but maybe tomorrow.  I did pull apart all connections that i could see and cleaned them up with some baking soda and water which did seem to improve its perfomance alittle.  Over the past couple days i put about 160 miles on it and it really did pep up quite a bit.  Now when i start it though its blowing lots of oil smoke until it warms up.  It is still doggy on the bottom end and when holding or maintaining a consistant speed it will start to slow down periodically and then have to give some gas to bring her back up to speed.  Here's a pic of what I'm guessing is the timing advancer but have no idea what I'm looking for.
Offline crazypj
  • Site Supporter
« Reply #14 on: Jul 29, 2012, 00:44:36 »
That's the advancer.
When you turn center, do the bob-weights move all the way to the stopsand return all the way to center?
