Swagger, a few more items you will encounter if you do the front motor mount swap:- No room for the coils in the original location. I mounted them under the frame just in front of the rear cyl and just behind the front cyl.... might not work if running the stock carb setup.- No room for a oil cooler at the front cyl head location. That one hurts, since I had planned a cooler in that spot, dedicated to the oil going to the heads and turbo. Still pondering a plan "B".
