www.Moto-Madness.com
Author Topic: '79 BMW R45 build  (Read 28364 times)
Offline regomodo
'79 BMW R45 build
« on: Aug 28, 2012, 08:18:39 »
I meant to open this thread back when I got the bike in March but only now i've decided to sort it out.
A little intro. My dad used to use this bike as a courier almost 22years ago. After he left that job it basically sat in a garage under a sheet for 13years until someone torched my dad's car, which spread to the garage and generally made a mess of the dozens of bicycles and 6 motorbikes that were in there.
My Suzuki DR125 came off the worst with most of the rubbers and plastics melting. This BMW had its paint tarnished and scorched a lot of the rubbers.
Fast forward almost 9 years and I decided to take it off my dad's hands. He nicely gave it to me for free.
This is what it looked like first:
BMW R45 by jonno85uk, on Flickr
Stripped down for transport (hard to believe but there are 4 motorbikes back there):
IMG_20120310_163355.jpg by jonno85uk, on Flickr
The heavy lump in my car:
_DSC0002.jpeg by jonno85uk, on Flickr
« Last Edit: Aug 28, 2012, 12:37:13 by regomodo »
Offline regomodo
Re: '79 BMW R45 build
« Reply #1 on: Aug 28, 2012, 08:25:16 »
1st thing on the list to do was getting it running. It probably hadn't turned over in 10years. I remember my dad saying a long while back that one of the carbs would overflow until he knocked the float bowl.
So, carb cleaning 1st.
1 carb and a stuck choke:
IMG_20120317_162702b.jpeg by jonno85uk, on Flickr
IMG_20120317_162635b.jpeg by jonno85uk, on Flickr
The left-hand carb had a load of detritus in the bowl and took a lot of effort clean up the blockages.
IMG_20120317_162539b.jpeg by jonno85uk, on Flickr
The righ-hand float adjusting tab was deformed so that was what caused the overflow.
It's 1st run on 20yr old 4star petrol:
Offline regomodo
« Reply #2 on: Aug 28, 2012, 08:27:11 »
The most major problem on this bike was its front brake. It dried up and seized a long time ago and was fire-damaged.
IMG_20120314_183032b.jpeg by jonno85uk, on Flickr
IMG_20120314_184638b.jpeg by jonno85uk, on Flickr
Offline regomodo
« Reply #3 on: Aug 28, 2012, 08:30:16 »
The engine was filthy. In the fins bits of burnt wood mixed with ash, tar and oil were lodged. Lots of carb-cleaner, wd40, scotchbrite and elbow-grease was employed.
A midway through pic. No before & after unfortunately.
Engine cleaning by jonno85uk, on Flickr
One of the exhaust nuts was stuck firm. Bent my spanner slightly trying to get the damn thing off even after copious amounts of wd40 and heat. Managed to remove it using a hacksaw blade to cut down to the threads and a cold chisel to free it up.
« Last Edit: Aug 28, 2012, 11:41:26 by regomodo »
Offline regomodo
« Reply #4 on: Aug 28, 2012, 08:32:42 »
As I was going to use clipons (I don't like the look of clubmans) the top-brace needed sorting.
After an evening with a hacksaw, angle-grinder, files and sandpaper I had a nice looking flat top clamp.
IMG_20120428_123903_v2 by jonno85uk, on Flickr
IMG_20120428_125618_v1 by jonno85uk, on Flickr
IMG_20120428_151133_v1 by jonno85uk, on Flickr
Offline session101
« Reply #5 on: Aug 28, 2012, 08:40:42 »
dude! friggin sweet, that actually is a rare bike! you better keep it!
the bike sounds great
Offline regomodo
« Reply #6 on: Aug 28, 2012, 08:41:30 »
When I first assessed the paint on the frame I thought a rub-down would suffice. Whilst starting the sanding bubbles of rust appeared and paint fell off. A complete paint strip and handsand was needed. This took me for freaking ever.
Nitromors 1st
IMG_20120504_124704 by jonno85uk, on Flickr
Handsand and wirebrush on angle-grinder
IMG_20120504_173527 by jonno85uk, on Flickr
Paint-thinner clean
IMG_20120504_182321 by jonno85uk, on Flickr
« Last Edit: Aug 28, 2012, 10:51:58 by regomodo »
Offline regomodo
« Reply #7 on: Aug 28, 2012, 08:47:06 »
Paint. I know that hammerite chips and powdercoat lasts but my thinking and experience suggests that hammerite is easily touched up. I decided to use smooth black in spray cans. Took about 2.5 (or 3.5) cans. A bit drippy in places (usually on the undersides, so out of view) but a very nice finish nonetheless, much better than brushed hammerite.
IMG_20120504_191759 by jonno85uk, on Flickr
DSC_0008 by jonno85uk, on Flickr
DSC_0007 by jonno85uk, on Flickr
DSC_0009 by jonno85uk, on Flickr
DSC_0010 by jonno85uk, on Flickr
DSC_0011 by jonno85uk, on Flickr
My swingarm painting rig
IMG_20120512_114921 by jonno85uk, on Flickr
IMG_20120512_130955 by jonno85uk, on Flickr
« Last Edit: Aug 28, 2012, 10:52:44 by regomodo »
Offline regomodo
« Reply #8 on: Aug 28, 2012, 08:55:19 »
Next up were the snowflake wheels. The lacquer had aged quite nastily so it needed to be removed. This was quite fiddily and very time-consuming: paintstripper, scotchbrite, wirewool, sandpaper and wirebrushes were all used. In the end I couldn't get it all removed on the rear rim and hoped as long as it was clean and the surface was keyed, the etch primer would take care of the rest.
Front wheel prepped:
IMG_20120526_143041.jpg by jonno85uk, on Flickr
Alu etch primed wheels
IMG_20120526_150121.jpg by jonno85uk, on Flickr
IMG_20120526_193913.jpg by jonno85uk, on Flickr
Halfords gloss black and clear lacquer shod with Avon Roadriders:
IMG_20120710_184740.jpg by jonno85uk, on Flickr
img_0001 by jonno85uk, on Flickr
IMG_20120710_182818.jpg by jonno85uk, on Flickr
img_0001_01 by jonno85uk, on Flickr
I had problems with these tyres with the bead not sitting correctly. Turned out they needed inflating to ~80psi to sit. They look awesome on these rims and the rest of the bike.
« Last Edit: Aug 28, 2012, 09:53:29 by regomodo »
Offline regomodo
« Reply #9 on: Aug 28, 2012, 09:00:10 »
Assorted bits of alu to clean andpolish next. All of it was heavily corroded.
The bevel-gear case:
IMG_20120506_151232 by jonno85uk, on Flickr
IMG_20120506_151245 by jonno85uk, on Flickr
Looks a lot better IRL
IMG_20120522_192225.jpg by jonno85uk, on Flickr
Bits of engine casing:
IMG_20120624_171340.jpg by jonno85uk, on Flickr
IMG_20120624_171332.jpg by jonno85uk, on Flickr
Also polished the air filter and electrics casings.
Not alu. Took the angle-grinder with sand paper wheel and dremel to this cast steel brake-arm.
Brake lever by jonno85uk, on Flickr
« Last Edit: Aug 28, 2012, 09:19:12 by regomodo »
