Slipstream Cycle
www.caferacerxxx.com
www.roccitycafe.com
www.townmoto.com
www.oldschoolspeed.com
www.moto-madness.com
www.rustrev.com
Vintage Customs
www.monstercraftsman.com
www.bullitcustomcycles.com
DWMS Racing
Author Topic: "Woody" a '75 cb750k cafe racer with woodgrain paint  (Read 5772 times)
Offline FGKouki
Re: "Woody" a '75 cb750k cafe brat
« Reply #60 on: Nov 10, 2012, 23:01:03 »
 ;)  got a bleeder screw off of a late 80s Honda Prelude today at the junkyard.  works just fine now.
Offline juan@crqcycles
  • Not a lot of cafe's down here in Mexico...
    • CRQ Cycles
« Reply #61 on: Nov 29, 2012, 00:24:56 »
Any updates / pics?
Offline FGKouki
« Reply #62 on: Nov 29, 2012, 00:45:16 »
Thanks for asking Juan.  I starting making some rearsets and I will fab up the oil sump after that!  I'll post some photos in a couple days.
« Last Edit: Nov 29, 2012, 00:47:18 by FGKouki »
    • CRQ Cycles
« Reply #63 on: Nov 29, 2012, 01:54:06 »
I'll be waiting! Looking at your 240 I am really waiting for the end result of this bike
Offline FGKouki
« Reply #64 on: Nov 29, 2012, 02:21:10 »
:D Thanks.   The car's look is very unassuming to most people but very detail heavy with one off bits everywhere.  I hope the bike has that same vibe when I'm done with it.
    • CRQ Cycles
« Reply #65 on: Nov 29, 2012, 03:00:25 »
What engine mods are you running?
Offline FGKouki
« Reply #66 on: Nov 29, 2012, 12:00:58 »
oversized pistons, forged rods, arp main and headstuds, s13 cams, 57trim t4, custom intake plenum,  equal length turbo manifold, 90mm throttle body, and all the supporting stuff.
    • CRQ Cycles
« Reply #67 on: Nov 29, 2012, 12:50:26 »
I knew something was going on down there! Thanks!
Offline LtGeorge
« Reply #68 on: Nov 29, 2012, 15:39:27 »
kouki kinda looks like my old one except I had a bottom mount turbo!! super sweet car
Offline FGKouki
« Reply #69 on: Nov 29, 2012, 22:42:21 »
Thanks.  Here's where I am with the rearsets.  cut some 1/4" plate out on the bandsaw and put some radii on the edges and some pilot holes for the hardware.  The bmx pegs will make the heel portion (may get smaller pegs) and I have an idea for the front.  Need to make a trip to the hardware store to figure that out and to get some clevis pins or heim joints and threaded rod for linkage.
« Last Edit: Nov 29, 2012, 22:46:50 by FGKouki »
    • CRQ Cycles
« Reply #70 on: Dec 02, 2012, 14:51:45 »
You can probably use non-flatland smaller diameter aluminum BMX pegs and put some skateboard griptape around them!
(Tree sticks for example: http://www.treebicycleco.com/tricksticks/)
    • CRQ Cycles
« Reply #71 on: Dec 15, 2012, 19:17:05 »
Something new bro?
Offline FGKouki
« Reply #72 on: Feb 09, 2013, 21:05:18 »
No real updates Juan, although the rear sets are mostly finished (just need the linkage).  I've taken a bit of a break from it as it got cold out but should be back to work on it shortly.  I really need to pull the motor and do the headgasket next.
Offline FGKouki
« Reply #73 on: Mar 28, 2013, 19:18:24 »
I'm not really happy with the rearsets thus far so I've put that on the backburner...  I hate looking at the bike without paint so I'm taking the plunge finally.
Sanded the spray paint off the tank with 80 grit.  I didn't want to strip it all the way down since the paint under the spray paint was okay besides the terrible chopper flames
Filler
Filler blocked down with 120 grit
Epoxied it
Sanded the epoxy down with 220 and added some glazing putty in areas I didn't think the 2k will build enough
Ready for 2k
2k!
That's where I'm at right now.  I'll be wetsanding then shooting the base for the special paint treatment tomorrow
Offline ISMarco
« Reply #74 on: Mar 28, 2013, 20:11:26 »
Good to see the table frame is still getting good painting use haha
