Author Topic: CB750: What motor oil to use?  (Read 13731 times)
Offline BArTY
    • Ryan Bartlette Design
Re: CB750: What motor oil to use?
« Reply #10 on: Sep 27, 2012, 15:51:33 »
Crazypj, do you notice any issues with clutch slippage using Rotella T Triple? I'm doing an oil change this weekend and think I might switch over. Is adding ZDDP necessary or more of a precaution? Should I be adding ZDDP to any oil I use? Thanks guys!
My bike doesn't leak, it marks it's territory.
Offline crazypj
« Reply #11 on: Sep 27, 2012, 19:32:47 »
I've had some clutch slip on 378 motors, but, I think they would slip even with conventional oil.
I have used Rotella without ZDDP, it may be just an added precaution but my Katana seems to notice the difference
Best thing I ever overheard
Brian Morgan, 1982
Offline djelliott
  • Real bikes are built in garages.
    • Cleveland Moto
« Reply #12 on: Sep 27, 2012, 20:16:45 »
I haven't noticed on the 350 (bored out from 325 to 358ish) but I did replace the friction disks and alloys with Barrnett parts.
71 CL350 Cafe build thread.
http://dotheton.com/index.php?topic=13543.0
Vitnage Motorcycle Podcast at http://www.clevelandmoto.blogspot.com
Offline crazypj
« Reply #13 on: Sep 27, 2012, 21:24:54 »
Barnett are pretty 'grabby' and slightly thicker than stock so will have slightly more spring pressure.
I use stock plates and heavy duty springs.
In my experience, ALL  70's Honda clutches slip at high rpm
Brian Morgan, 1982
Offline b.flash
« Reply #14 on: May 12, 2015, 20:36:27 »
I have used Castrol 10-40 for over 40 years in all my bikes.
(And I am a Amsoil dealer, and still use Castrol 10-40)
Non-synthetic? So is that the consensus? 10/40 conventional motor oil is best.
(I take it synthetic causes clutch issues?)
1979 CB 750F
Offline b.flash
1979 CB 750F
Offline jpmobius
  • where does this go?
« Reply #16 on: May 12, 2015, 23:09:20 »
Rotella.  (NOT synthetic) I don't use any sort of additional additives.  Viscosity to suit your climate.  Take enough engines apart that have familiar oil history and you will be a believer.  A couple of years ago I put some in the trans of a two stroke when I didn't have anything else on hand.  Made an absolutely noticeable difference for the better!  That bike didn't have any trans issues before, or so I thought - super surprised at the improvement. No effect on the clutch detected.  Use it universally now.
« Last Edit: May 12, 2015, 23:12:18 by jpmobius »
Mobius
Offline Tune-A-Fishİ
« Reply #17 on: May 12, 2015, 23:12:00 »
Valvoline 10/40 is my choice for basic oil and if fresh build old inline 4 I use Yamalube 10/40
Offline crazypj
« Reply #18 on: May 13, 2015, 02:44:25 »
and for further reading:
http://classiccars.about.com/od/maintenancetips/a/Zddp-Debunking-The-Urban-Legend-This-Motor-Oil-Additive.htm
 ZDDP has been reduced to about 1200ppm in most oils
From what I've been able to find out, optimum is around 17~1800ppm, higher concentrations can lead to excess wear and corrosion (2200+ppm)
As I'm not a chemist, I add 2oz instead of 4oz so clutch keeps working  8)
Brian Morgan, 1982
Online The Jimbonaut
    • Lost Apostle
« Reply #19 on: Sep 25, 2017, 15:38:18 »
I'm having a few clutch issues and think it might be down to a heavier oil I used (20W 50).  I found this Rotella T Triple oil in Canadian Tire -
http://www.canadiantire.ca/en/pdp/rotella-t-15w-40-diesel-motor-oil-946-ml-0287929p.html#srp
- but it's listed as a diesel engine oil.  Is that gonna work?
