junkyard jon
Active Member
hey if your throwing the bearings out how about throwing them my way LOL. sometime's you gotta use washers and play with the spacing. i like the All Beaing brand better, seems like less fuss getting everything to line up. you got washers with the kit right? use the 4mm washer under the bearing to raise it up. maybe this with help you out.
http://www.stephenbottcher.net/Honda/tapered.htm
750 and 550 are the same setup.
