Author Topic: KZ650 Street Fighter  (Read 19175 times)
Offline ctluba
Re: KZ650 Street Fighter
« Reply #20 on: Dec 27, 2012, 01:15:32 »
Looks good. 8)
So what did ya have to do?? Grind a little out of the frame?? Have a little turned off the arm?? Any bushings made for the pivot bolt??
Ya cant just say "its in"!!!! We some tech bro!!! ;D
Offline DNel928
« Reply #21 on: Dec 27, 2012, 20:43:38 »
Looks good. 8)
Just had to grind a little bit off of the frame. Then took the stock zx6r swingarm bolt and bored it out to fit the KZ bolt, so it is pretty much a sleeve. Was able to use all the factory mounting hardware from the zx6r :) Pretty straight forward swap really.
Here's a pic of it mounted in.
« Last Edit: Jan 05, 2013, 18:06:22 by DNel928 »
Offline ctluba
« Reply #22 on: Dec 28, 2012, 01:06:12 »
Nice work, looks really good. 8)
You gonna mono shock or run duals??
Offline DNel928
« Reply #23 on: Dec 28, 2012, 10:58:18 »
Thanks!
 I will be running a dual shock setup. I don't really like the look of the newer swingarm, so the dual shock will at least give it some classic look. Hopefully powder coating the swingarm black will help also.
Offline ctluba
« Reply #24 on: Dec 28, 2012, 12:46:32 »
I think duals will look good also.
As far as the swinger, I like the look with the silver finish. It adds some contrast to the black frame and wheels. But that is just me, you gotta build what you you envision. Who knows, when you get it set up your way and I see it, I will probably like it better than silver!!!!! ;D
Offline DNel928
« Reply #25 on: Dec 28, 2012, 18:56:51 »
Exactly! The frame and swinger are all that will be black really. Wheels will get a metallic gunmetal color, tank & plastics will be a different color (I think), and all the little stuff will be contrasted as well.
Offline DNel928
« Reply #26 on: Dec 30, 2012, 21:05:21 »
Finally getting somewhere.
« Last Edit: Jan 05, 2013, 18:06:53 by DNel928 »
Offline M.B Co
« Reply #27 on: Dec 31, 2012, 16:25:45 »
Yum. Looks great.
Offline .Spindat.
« Reply #28 on: Jan 01, 2013, 14:15:40 »
love that rear subframe, great work!
Offline VonYinzer
« Reply #29 on: Jan 01, 2013, 16:03:52 »
Very cool so far...
