Author Topic: The SkyTeam 'Ace' Resource  (Read 561766 times)
Offline 2b
Re: The SkyTeam 'Ace' Resource
« Reply #2590 on: May 06, 2017, 23:33:23 »
Suggest you work your way through this...
https://docs.google.com/spreadsheets/d/1USvziYIyzfyxfZA1YYpQf9eP4djb0GLWbvWcmME88Gk/edit#gid=1
There are multiple sheets on this spreadsheet on different topics, look along the bottom.
Hope it helps.
Cheers
Richard
He's obsessed with order and clarity. He doesn't like mess.
Harold Pinter
Build thread: http://www.dotheton.com/forum/index.php?topic=61167.msg694438#msg694438
Offline Sneikz
« Reply #2591 on: May 20, 2017, 06:15:32 »
The slide may be placed in 180 degrees out. If you removed the slide and extracted the carbie, you may have replaced it back incorrectly. Ensure the idle stop screw is not aligned with the throttle cable slot. If it is put in the wrong way the idle stop screw has nothing to stop against. Hence no idle. You will also get air bypass. See pic. at link below. Idle stop at front of pic, throttle cable slot at rear of pic.
You may also have a failed manifold gasket. A little air makes a lot of difference. Check that the rubber o ring and the cardboard gasket are not buggered. If the cardboard gasket is torn you must replace. Trace and cut from a breakfast cereal box.
Hope this makes sense and is a help.
http://thumbs1.ebaystatic.com/d/l225/m/m_GpCeUZII8ituOzsUrqcMw.jpg
The Silver Bullet Thread: http://www.dotheton.com/forum/index.php?topic=71205.0
Silver Bullet Pics: https://goo.gl/photos/EXyfM3K42BHp2D6w9
Aces on the net: https://goo.gl/c8QmjP
Silver Bullet mods booklet: https://goo.gl/97mGRI
Other Bikes:
2012 Suzuki Boulevard M109R
2005 Tomos Revival (TS)
Live long and ride hard \\ //
Offline Sneikz
« Reply #2592 on: May 20, 2017, 06:19:25 »
New header and exhaust installed.
http://www.dotheton.com/forum/index.php?topic=71205.msg872857#msg872857
And OEM carbie replaced with a Mikuni.
http://www.dotheton.com/forum/index.php?topic=71205.msg872858#msg872858
Apart from the installation of a baffle in the exhaust (to bring it to a noise level more acceptable) that does me for mods (I think).
Any suggestions? I'm keen to keep the engine stock.
« Last Edit: May 20, 2017, 06:29:29 by Sneikz »
Other Bikes:
Offline kevmaster
« Reply #2593 on: Jun 03, 2017, 11:07:57 »
Hi Acethusiasts,
after I tried to make my bike as clean as possible, I had a good idea. Throw the exhaust away. See first pic.
OK, just a joke. But I thougt, I have to to something for my powerful racing 50 cc monster-engine, I bought a exhaust tape. And this is the first try. OK, it is not the best, but it looks faster.
Have a nice day
Rgds from good old Bavaria
Kev
Kev, bavarian Acethusiast
Offline CODDEX
« Reply #2594 on: Jun 04, 2017, 04:36:09 »
Hello again everyone
The coffers for the ACE are very slowly trickling full, so I have decided that my plan is as follows
1. Buy a second hand 50cc ace
2. Swap the 50cc lump for a 125cc ( please see question below)
3. Complete all necessary upgrades (as described in this fabulous resource)
4.Fit a fairing
The question I have is ;
I'm going to buy a 125 lump and I want twin exhausts ( just for the look)
Should it be OHV or OHC considering I want to upgrade to 150cc and put on a twin exhaust head?
Any help would be appreciated as although I have a smattering of technical ability I would like to have as easy a job as possible although future servicing has to be taken into account
Your thoughts please 😇😎
Sent from my Hudl 2 using Tapatalk
Offline CODDEX
« Reply #2595 on: Jun 04, 2017, 05:02:44 »
Just a quick note
I've just found a brand new FM571 OHV single cylinder twin exhaust for £450 here:;
http://www.china-parts.co.uk/acatalog/New_Engines.html
Is this the puppy ??
Any help please
Offline stroker crazy
  • crazy as a fox
« Reply #2596 on: Jun 04, 2017, 06:40:07 »
Answering your question with a question:
Why not go straight to the 150cc twin exhaust motor?
It almost certainly would work out cheaper than buying a 125cc, converting to 150cc, adding a twin port head.
Crazy
“Ride like the Wind” W.H.
Offline CODDEX
« Reply #2597 on: Jun 04, 2017, 07:20:46 »
 Crazy,
Thanks for the reply,
It would appear that I've solved my own problem inadvertently
Q. Do you think the wiring will cause many issues ??
Cheers
  • crazy as a fox
« Reply #2598 on: Jun 04, 2017, 07:32:45 »
Wiring should be pretty straightforward, but you will probably have to organise new engine mounts for the 'Ace' 50.
Crazy
Offline CODDEX
« Reply #2599 on: Jun 04, 2017, 07:55:15 »
Okay thanks
Another task to add to the list
I will keep everyone posted when it all starts
Thanks again, this resource is what convinced me that the ACE is the perfect middle aged project for me to sink my teeth and incredibly tight budget into
Now to let the missus know that a weeks camping in Cornwall is replacing the all inclusive trip to Spain
Cheers 😋
