www.Moto-Madness.com
Author Topic: The SkyTeam 'Ace' Resource  (Read 517470 times)
Offline Timmy
Re: the "Ace" - getting a grip!
« Reply #60 on: Mar 13, 2013, 07:25:29 »
Hello! totally new here, so this is my first post.
Been stalking this site for a while though!
Must say that this bike is so good looking, and a bargain. So cheap for a new bike!
Getting this bike as well, but I need to get my license first. Currently studying on that now. Hopefully I will be done before the summer is over :D
Gonna do some changes to it though. Getting rid of the rear fender, clubmans/clip-ons, some tuning with exhaust, carbs. Also new suspensions and tires.
So this thread is a big inspiration. Keep up the good work!
Godspeed!
Offline stroker crazy
  • crazy as a fox
« Reply #61 on: Mar 13, 2013, 09:07:53 »
Glad you like the 'Ace'.  It's a fun bike to ride.
I should have  the Tarozzi clip-ons installed shortly and slow progress is being made on the fairing and instruments.
On the performance side, probably the most important change to make is the exhaust.  The air filter set up is not too bad but the pipe is extremely restricted.  As I make changes I will post my experiences here on DTT, perhaps you may find them helpful.
Crazy
“Ride like the Wind” W.H.
Offline juan@crqcycles
  • Not a lot of cafe's down here in Mexico...
    • CRQ Cycles
« Reply #62 on: Mar 13, 2013, 15:02:00 »
"The air filter set up is not too bad but the pipe is extremely restricted.  As I make changes I will post my experiences here on DTT, perhaps you may find them helpful."
Crazy
Hey Stroker Crazy! I've been reading this thread and I might be a little bit excited. I'll tell you why...correct me if I am wrong but I think the engine your bike has is a reproduction of a 125 OHV Honda engine. If that is the case, then your bike and mine (Honda CGL 125) have very similar mechanical and "performance" characteristics.
So...What are your plans for performance modifications on your bike?
I saw you purchased new jets, whats their size and whats the original jet's size? Mi bike comes with a #102 main jet and a #38 pilot jet.
Last but not least...Whats the top speed of your bike right from the factory?
Sorry for all the questions, but not a lot of people messes with these little bikes so theres not a lot of info about them.
BTW, That fairing you are planning to run looks BEAUTIFUL. As simple as that.
Cheers from Mexico,
Juan Fco. Castillo
  • crazy as a fox
« Reply #63 on: Mar 15, 2013, 01:16:27 »
The motor for the 'Ace' is copied from the CG125.  I don't know if any parts are interchangeable but it would be very useful if that was the case.
The jets were recommended to me by a person who has had some experience with modifications to these bikes.
The main is a 95 and pilot is a 45.  I have not dismantled the carby yet so I don't know what size the originals are.  When I have the new exhaust system to fit I will be attempting the re-jet, and will be able to say more then.
After 1500 k riding the motor is running much better than it was, but establishing a top speed is difficult.  A slight uphill or a headwind cause notable slowing, and a downhill helps to pick up revs.  So far I haven't seen a great deal over 90-95kph.  When I install the tacho I will know a bit more about how hard the bike is working!
Other than a new exhaust and a freer intake I won't be doing much in the way of engine changes.  A 125 pushrod motor doesn't have too much to gain without compromising reliability.  It makes more sense to spend development money on a somewhat larger capacity OHV motor.
Crazy
Offline Timmy
« Reply #64 on: Mar 16, 2013, 07:02:14 »
Why not use an OHC enginge? Is there any advantages with an OHV?
Godspeed!
  • crazy as a fox
« Reply #65 on: Mar 16, 2013, 07:52:45 »
OHV was a typo - I meant OHC!
Crazy
  • crazy as a fox
Re: the "Ace" - bars up!
« Reply #66 on: Mar 29, 2013, 23:58:09 »
Tarozzi bars fitted:
and a side view:
Much more comfortable, owing to the adjustability.
New throttle and switch blocks will be the next change, followed by the Koso instruments.
Crazy
Offline Timmy
« Reply #67 on: Apr 13, 2013, 11:49:52 »
Looking good!
What are your plans for tuning? If you have any.
Godspeed!
  • crazy as a fox
« Reply #68 on: Apr 13, 2013, 19:18:30 »
Timmy - on page 6 I mentioned that I was planning to make some tuning modifications.  The most important first change will be to replace the very restricted exhaust set-up.  This will be followed by filter-box alterations, upgrading the CDI, and re-jetting.
As these changes are completed they will be posted here.
Crazy
  • crazy as a fox
Re: the "Ace" - cleaner breathing!
« Reply #69 on: Apr 25, 2013, 22:05:34 »
Removed EGR:
