Author Topic: CX500 minor bob job - whooooot issues solved goes like a bat out of hell, for an old bike at least  (Read 78916 times)
Offline Maritime
So i got 10 mins wirh the cx to test compressio.  Results 120 - 90.  Shit.  Have to check valves.  Put oil in low cilynder.  No change.  Must be valves.  Hope it is just adjustment.  So plans are a removal of huge signals and tails.  Clean, paint, new seat,  I like the bars and headlight.  Front will be lowered and it will be good to go.  Low budget.  Got it for 250.
Sent from my MB525 using Tapatalk 2
« Last Edit: Nov 11, 2013, 16:49:47 by Maritime »
Offline JustinLonghorn
Re: Cx500 minor bob job.
« Reply #1 on: Nov 15, 2012, 15:25:16 »
I'm in.
Into The Sunset, CB750 build
TT500 the Animal
Offline Maritime
« Reply #2 on: Nov 15, 2012, 15:27:12 »
So also when I hooked up a good battery I prompley blew a fuse or something.  Yay.  I am at the dentist now and will get to the valves when I get home.  Had to do c test by using booster cables to the starter motor.
Offline AlphaDogCustoms
  • Science is true whether you believe in it or not.
    • Alpha Dog Customs
« Reply #3 on: Nov 15, 2012, 16:08:47 »
Check to be sure you didn't reverse the battery polarity.
...every dump I take is original too, and it doesn't smell any better because of it's originality.
Alpha Dog Custom Cycles
Painting
Powdercoating
Custom Fabrication
Repairs
I'm so old, I even know what ignition points are.
Offline Maritime
« Reply #4 on: Nov 15, 2012, 16:12:55 »
Got polarity right. Lights were on etc.   Just popped when i hit the start botton.  I am going to adjust valves then check comp again.  The start stripping everything to get to work.  Pics of progress later tonight I hope.
Offline Big Rich
  • Heaven is so far away.
« Reply #5 on: Nov 15, 2012, 16:56:41 »
Signed up for sure on this one.
Offline Ringo
« Reply #6 on: Nov 15, 2012, 17:00:00 »
As am I.
Chris
Offline Maritime
« Reply #7 on: Nov 15, 2012, 21:42:13 »
Ok.  So the manual sucks but google foo and vakves checked.  Offending cylinder had a tight intake.  Adjustment done and bang 125 psi.  Redid other and te same.  Found bad fuse.  10 amp in a spot should have been 20.  Put a 30 in for now. Will be putting all new blade fuses in and moving fuse box anyway.  Lovely oil.  Lots of condensation.  Flushed it out.  Valves look alright though
Offline Maritime
« Reply #8 on: Nov 15, 2012, 22:13:31 »
ok good night so far.  on a computer now so typing gets better.  Here is kind of the direction for this bob.  Moto Mucci I think is the name of it.  It is a Cafe but the minimalist clean lines are the direction I want to take.  picture the mucci bike with the bars and tank from mine basically.
Pic
Offline Big Rich
« Reply #9 on: Nov 15, 2012, 22:41:36 »
Mike, there is a guy near me that might have a CX tank like that....if I get a chance to talk to him, I'll see if he has it and is willing to part with it.
And how does oil ever get that bad? Coolant leak?
