Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
DTT /
DIME CITY CYCLES
BOTM FEBRUARY 2019 WINNER!!!
Home
Forum
Help
Gallery
Search
Stats
Login
Register
DO THE TON
Blood Sweat Tears and Grease
Projects
Specials
(Moderator:
Sonreir
'74 CB383 (CB360) - a Mighty Mouse adventure bike
DTT /
DIME CITY CYCLES
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
Go Down
Author
Topic: '74 CB383 (CB360) - a Mighty Mouse adventure bike (Read 23463 times)
Treesus
Probably not sane.
Re: '74 CB383 (CB360) - a Mighty Mouse adventure bike
Reply #60 on:
Mar 28, 2013, 22:16:40 »
Any input on checking piston to valve clearance with the OS valves? Eh?
Logged
~Tree
CB360 Adventure build
http://www.dotheton.com/forum/index.php?topic=43834.20
"I think it says in the Bible that there is a time to listen to techno, and a time not to." -Joe Strummer
Sonreir
Moderator
DTT SUPPORTER
Oregon
Reply #61 on:
Mar 28, 2013, 22:57:35 »
Do it.
Use plastigauge or plasticine clay. Torque everything to spec and rotate the crank (slowly!) two full rotations. Take everything back apart and measure the clearance. You'll want at least .020" between intake valve and piston and .040" between exhaust valve and piston.
Logged
Sparck Moto -
http://www.sparckmoto.com
Audaces fortuna iuvat.
1977 Honda CJ360 -
Café SOS - Stage One™
Café SOS - Stage Two™
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Treesus
Probably not sane.
Reply #62 on:
Mar 28, 2013, 23:44:03 »
Thanks Sonreir. I'm going to head off and get some plasticine.
Logged
~Tree
Treesus
Probably not sane.
Reply #63 on:
Mar 29, 2013, 07:02:55 »
Ok. I did two clay tests. I figured the first one was unreliable because I forgot to set valve clearances after bolting the head and valve cover up.
So I re-did the test. I guess I should have put the clay on thicker because only the exhaust valves touched. So I measured everything anyhow.
Left Exhaust Impression was about .058" with a possible minimum of .056" (may have just forces the caliper on that one).
Right Exhaust Impression hovered around .059" with a possible .055" minimum.
Left Intake valve didn't make an impression, nor did the Right Intake. So I just measured the clay I had laid down to see how thick it was.
Left side varied between .1" and .059", the Right side between .1" and .053".
Am I ok in thinking that since the Intake Valves didn't make an impression and the clay was 3 times thicker than .020" I am good to go or should I check with thicker clay to make sure they are not too far away (as in not opening all the way)?
I watching the valves through the spark plug hole and everything seemed to open as it should. Also watching the rockers. Probably turned the engine through 4 or 5 rotations while watching everything.
Logged
~Tree
Sonreir
Moderator
DTT SUPPORTER
Oregon
Reply #64 on:
Mar 29, 2013, 11:06:23 »
Sounds like a successful check to me. I'd run with it.
Logged
Sparck Moto -
1977 Honda CJ360 -
Treesus
Probably not sane.
Reply #65 on:
Mar 29, 2013, 22:14:10 »
Ok. I did an acentone test before the clay test and all valves sealed nicely.
So, I've got the engine loosely mounted in the frame and did a compression test.
Does anyone have an idea of what a cold, unseated compression ballpark figure should be? The book says to tests while the engine is at operating temps. And though not stated this is, obviously, with seated rings.
My right cylinder is easily pushing 151 psi, however the left is barely hitting 95-100psi after 3 checks. Any ideas? Or should I completely ignore this because the engine has not been run?
Logged
~Tree
Sonreir
Moderator
DTT SUPPORTER
Oregon
Reply #66 on:
Mar 29, 2013, 22:21:47 »
Assuming the valve clearances have been set, the two cylinders should both be fairly equal. Cold compression test on my rebuilt 378 engine yielded 151 and 153, if I remember correctly.
Logged
Sparck Moto -
1977 Honda CJ360 -
Treesus
Probably not sane.
Reply #67 on:
Mar 29, 2013, 22:33:44 »
Disregard. I checked the valve clearances and did it again. Vastly different. Got 179 PSI Left and 172 PSI right.
Whew. I had myself scared.
Logged
~Tree
Sonreir
Moderator
DTT SUPPORTER
Oregon
Reply #68 on:
Mar 30, 2013, 01:40:06 »
Close enough.
Logged
Sparck Moto -
1977 Honda CJ360 -
canuk, eh
Reply #69 on:
Apr 01, 2013, 17:53:07 »
awesome build here treesus, really inspiring. almost makes me want to crack open my 200t and get real down and dirty with it.
the only point i might make is that when i did a mechanics course(heavy duty mind you), i had an engines instructor who was really into performance this kind of stuff. he always said if your going to polish, do it until you can see your own reflection in the metal. his suggestion was to get some kind of buffing tool that would fit on the end of your drill and fit snug into your ports, then buff until your wife divorces you
. i have never tried it myself, so i cant say how much it will do, but it always seemed like it couldn't hurt as long as you dont touch your valve guides/mating surface too much.
again, amazing stuff here, your a real inspiration for the gear-heads!
Logged
Drive like it's stolen
Dance like no one's watching
Sing like its your last song
Live like your still young
Print
Pages:
1
2
3
4
5
6
7
8
9
10
Go Up
« previous
next »
DO THE TON
Projects
Specials
(Moderator:
Sonreir
