Author Topic: 1976 Honda CB360T - The first step is admitting I have a problem build  (Read 227685 times)
Offline Worst cb650 ever
  • You can always get it running with time or money.
Hello again folks!
Apparently I have a bike problem, as I just bought another fine Honda.  The '79 CB650 is done and waiting for my brother to decide if he wants it, and the '93 CBR900RR is on hold until I get the upper fairing from Airtech.  Hey, that's a good enough reason to get another bike, right?
I followed up on am old Craigslist post for a CB360 "Tupperware case" bike on Thursday, and the guy told me "I want it gone, I'll be here Saturday."  So, we loaded up the pickup truck and headed out to investigate another bad idea.  The bike was mostly complete except the headlight, but a lot of it was in a couple of boxes.
The guy I got it from got it from another guy who got it from the proverbial little old lady who only rode it on Sundays to church.  Uh huh, yea, I've used that line myself.  He said it kicked over and had good compression, but he didn't have the time/motivation/money to keep working on it.  When I arrived to check it out, I couldn't get it to kick over, so the price dropped $50 more down to a place I was very happy with.  We loaded it up in the truck and hauled it back to the autopsy room garage to check it out.
I pulled all the engine covers off, and emptied about three pounds of leaves, dirt, and acorns out of the chain cover.  The bike had about half a quart of stinky oil in it, but it appeared that someone had emptied the oil and that it hadn't run out of oil on its own.  I poked at it a bit, sprayed PB Blaster in the spark plug holes, loosened the clutch spring bolts, and ta da, it kicked over.  Well, that's step one.
Step two was trying to figure out why I couldn't shift it out of neutral, even when spinning the rear wheel with the clutch hooked back up.  I suspect I might have to crack the case, but I was pretty much expecting that.  I'm hoping it's not a buggered shift fork.
I turned my attention to the carbs...something looked funny when I examined them...
Hmm, I suspect the last person to mess with the carbs didn't quite know what they were doing.  I wonder if it would have even run in this state?
I disassembled the carbs and have them soaking in Pine Sol and hot water.  I had some trouble with one of the slow jets, but some careful filling made a new screwdriver slot, as the last person there had busted out the original slot.  I'll order up rebuild kits and get them back into tip top shape.
More updates as things progress!
DTT Blue (cause Winter is Coming) CB360 Club.
1995 CBR900RR - a winter flip not worth a DTT writeup - Sold
1986 Yamaha SRX600 - mailed to me from California - build coming soon?
1983 VF750F
1976 CB360T
1993 CBR900RR - Sold
1979 CB650 - Sold
Offline edukaycheon
    • My pseudoblog
Same bike as mine. Look forward to seeing the progress!
“Seize the day guys - don’t say “Can I , can’t I” - just do it anyway and see what the results are. After fifty odd years of making those kinds of decisions, you will ALL have your own ‘Tales from the day’.
I’m still at it, buying toys I can’t really afford or getting out there and indulging my whims, but you find a way.
Let me assure you - there’s nothing worse than looking at maybe another fifteen or twenty years of life and looking back and saying “If only”. Don’t listen to the “Can’t be done” assholes - not, at least until you’ve tried it for yourself.
There’s NO point in regretting past decisions - they’re done, just take the results of that decision and run with it.” - Beachcomber
http://www.dotheton.com/forum/index.php?topic=45042.0  -  CB360...I want to ride again!
http://i.imgur.com/xLptvnG.gif
Offline crazypj
I would be interested to know how you filed a slot in the slow jet, it lives in a hole under blanking plug.
 If you mean primary main jet, that's so common it isn't worth mentioning
Best thing I ever overheard
Brian Morgan, 1982
PJ, I'm interested in what the hell I filed a slot in myself!  The rebuild kits for these carbs don't seem to have the same parts I pulled out of these carbs.  Guess I should have taken pictures  :P
I looked at the parts fiche, and its apparently the "primary main jet" as opposed to the "main jet."  How many main jets does this thing have?
Do you have a good recommendation for a brand/source of a complete rebuild kit?  The K&L and Keyster kits seem to be short some important parts, and the bowl gaskets in them seem to just be a large O-ring and not pre-formed.
The Pine Sol seems to be the color of bad diner coffee now, so I guess the carbs are almost done soaking...
1983 VF750F
1976 CB360T
1979 CB650 - Sold
Offline crazypj
None of the carb kits come with primary main jets.
 They all come with secondary main jets.
It's a 3 jet carb, pilot/slow jet, primary main, secondary main. It's what makes them so difficult to get running right with 'pods'.
The transition from primary to secondary causes a real rich running area around ~4,500rpm
It took a lot of experimenting and several dyno runs to see what was going on, that's why I do mid range mod for people (although it frequently turns into a carb resurrection)
 The bowl gasket is a large 'o' ring, new ones are something of a PITA to fit, most are slightly off on diameter and need to be 'glued' in place
« Last Edit: Dec 09, 2012, 12:02:45 by crazypj »
Brian Morgan, 1982
Whelp, that clears things up, thanks!  The good news is that I have the stock air boxes / filters, and plan on running those.
Do you sell overhaul kits that would include the primary main jet?  I'd much rather give money to a fellow DTTer than a random company.  Also, what does your mid range mod encompass / cost?
The carbs look a lot better now that they've been soaking, but I'm going to have to clean up the float bowls with some polish I think.  The chrome on the caps is in horrible condition, so I think it's going to get cleaned and painted.
What a pain about the bowl gasket.  Those things are enough of a PITA even when they are pre-formed.  Sheesh.
Thanks again for your advice!
1983 VF750F
1976 CB360T
1979 CB650 - Sold
Offline crazypj
I don't do overhaul kits, it's just a hobby (no way I can do them quick enough to make it pay and I don't keep anything 'in stock', would need too much outlay  ;D )
PM me for cost of conversion if you decide to go with K&N 1820's (I don't recommend cheap pods)
Brian Morgan, 1982
I think I'm going to stick with stock air filters and stock carb settings for now.  I'd like to hear the thing run before I go much further lol!
If I could bother you with two more questions, where would I get primary main jets?  I ordered a pair of rebuild kits, and as you mentioned, they do not come with those kits.  Also, do I need to remove the slow jet?  They seem to be stuck pretty good, and I don't want to break the heads off of them.
Thanks!
1983 VF750F
1976 CB360T
1979 CB650 - Sold
Offline crazypj
Yep, you have to remove pilot/slow jets, pretty much guarantee they are blocked.
 Last set I did I had soaking in bucket of diesel for about 10 days
You get replacements in kit, don't chew the heads up, it's a nightmare getting broken ones out
Your carbs look pretty oxidised/corroded
Probably have to go to Honda for primary main jets, aftermarket ones don't fit (too long)
Trek97 may have some? (he had some modified, local)
I can make them in 0.05mm steps but prefer not to (more trouble than it's worth)
« Last Edit: Dec 10, 2012, 02:58:36 by crazypj »
Brian Morgan, 1982
I was afraid you were going to say I had to remove them  :)  I've had them soaking in penetrating oil, and I imagine I might even have to apply some very very very gentle heat to see if I can get bits to expand.
I found this:
http://www.jetsrus.com/a_jets_by_carburetor_type/jets_keihin_99101-124_and_99101-ZF5_air.html
Are those the correct primary main jets?  I'm very much wishing the previous owner did not mess with them and chew the head off of one of them.  But hey, if every bike went back together with no problems there wouldn't be any sense of accomplishment at the end of the project.
Thanks again for all your help and taking the time to answer my questions.  I didn't realize that the 360s were somewhat rare, and now I understand why so many people go to aftermarket carbs for them.
1983 VF750F
1976 CB360T
1979 CB650 - Sold
