Author Topic: 520 Chain Conversions for CB350 CL360 CB400 CB450 CB77  (Read 33698 times)
Offline BLSully
Re: Re: 520 Chain Conversions for CB350 CL360 CB400 CB450 CB77
« Reply #40 on: Jan 22, 2013, 20:29:20 »
Let us know what other bikes you guys guys are interested in having some 520 Conversion kits for.
KZ400. Would also work on 440s with belt drives too for those guys who can't find belts. As long as you have the sprockets its a direct swap. KZ 750s share the same sprockets as well.
Don't know for sure but I think the kz305 and maybe 200 are the same as well.
Sent from my Galaxy Nexus using Tapatalk 2
« Last Edit: Jan 22, 2013, 20:31:04 by BLSully »
'05 Vulcan 1500 Classic - Daily rider.
'79 KZ400 B2 - http://www.dotheton.com/forum/index.php?topic=42063.0
'80 KZ440 - Actually runs.
Support these guys: www.power-barn.com www.dimecitycycles.com
Offline MotoMadness
    • Streetfighter & Cafe Racer Parts !!!!!!!
« Reply #41 on: Jan 22, 2013, 21:54:49 »
are you supplying O-ring chains with these kits?
Yes O-ring chanis are coming with the kits.  They are the EK 520 SRO5 chains
Offline MotoMadness
« Reply #42 on: Jan 22, 2013, 21:55:57 »
what are the benefits going to a 520 chain?
The 520 kits are much lighter than the 530 stock chains which is less rotating mass.  Also, with the 520 kits you can run the o-ring or x-ring chains unlike the 530 sprockets on most bikes.
Offline Tim
  • Administrator
    • DO THE TON
« Reply #43 on: Jan 22, 2013, 22:38:35 »
What would the odds be of getting a kit for the XS650?  Only option I know of at the moment is MikesXS.  I've used their sprockets and haven't died yet but would be happier knowing where they come from.
17 front 34 rear is stock gearing with some running 30 - 33 rears to reduce rpm and vibes.
Offline MotoMadness
« Reply #44 on: Jan 22, 2013, 22:39:58 »
Yea the XS650 I believe they can cut no problem.  I will check tomorrow with them and let you know.
Offline DrJ
« Reply #45 on: Jan 22, 2013, 22:42:50 »
Are you going to sell the sprockets separately? I prefer using a non o-ring chain.
Offline MotoMadness
« Reply #46 on: Jan 22, 2013, 22:44:51 »
Sure we can sell them separately.  Roughly $25 for the front and $60 for the Rear.  Anything under 34T is a bit cheaper.
Offline ronnie
  • Calm down and sail on
« Reply #47 on: Jan 23, 2013, 00:41:54 »
What's the difference between o-ring and x-ring chains..? Isn't o-ring the best or am I outdated?
HOLD FAST.
"'Today I Learned' that if you're going to drink all day you have to get started early." ~kop
CB350F/400Fpowered  "Dago": http://www.dotheton.com/forum/index.php?topic=35263.msg381531#msg381531
Offline Mydlyfkryzis
  • 当有疑问时踢你的敌人在生殖器上,你可以道歉后
    • CB360 Build
« Reply #48 on: Jan 23, 2013, 01:50:07 »
the difference is the cross section of the sealing ring. An o-ring is circular. 2 sealing surfaces, one on each side plate . The X ring cross section is like an x, so it has 4 sealing surfaces. Also, the X ring puts a little less force on the side plates, so there is less friction.  Less friction is good. Absorbs less HP. Some of the chains play with the thickness of the legs of the "x" to make it seal better, but still keep reduced friction.
X ring and their variations are the latest greatest. O-Ring is "old" technology.
But o-ring is better then no o-ring. X ring is a little better yet.
A new 520 chain is actually stronger then the OEM 530 chains on these bikes. A new 520 chain should last a lot longer then the old heavy duty 530 chain. The old chain had no seals at all. Dirt would get into the rollers and wear out the cross pins. A rubber sealed chain doesn't have that issue, and the steel is even stronger.
If I hadn't recently purchased a new chain and sprocket, this setup would of been the way to go.
Also, at least on the CB360, most O-ring/X ring 530 chains are wider than the stock heavy duty chain, and will rub on the side case.  The 520 chain is narrower, so no rubbing issues.
Those sprockets are pretty....
There are 10 kinds of people, those who know binary and those who don't
Ignorance is bliss....and there are a lot of happy people out there!
AlphaDogChoppers: "A friend of mine once said, "There's no such thing as a stupid question, but there sure are a lot of inquisitive idiots."
"if you need a hammer to do something...  you are probably doing it wrong" - LazloH
DTT Blue CB360 Club - We discriminate!
Mydlyfkryzis = Mid Life Crisis
1991 Honda Nighthawk 750
1976 Honda CB360t
http://www.dotheton.com/forum/index.php?topic=41649.new#new
Offline ronnie
« Reply #49 on: Jan 23, 2013, 02:51:05 »
Thanks for the lesson! Cool deal, and yes they are pretty! Lucky for me I dont have a chain.. So I will be getting these, but not to that stage yet!
HOLD FAST.
