Author Topic: "Tangerine Dream" / Glemseck - KZ750  (Read 145657 times)
Offline beachcomber
  • TJ - Beachcomber
« Reply #810 on: Apr 14, 2019, 13:51:58 »
Just thinking about the NOS tank mount....how about a pair of webbing straps so you can quick undo as you'll be removing to recharge?
The exhaust clamps only require a half turn with a spanner to allow the bottle to slide out. We did try it earlier on a dry run to swap out bottle.
PJ - IF we run out of space [ looking likely ] I'll go back to the under seat tray - or more likely - the seat bum stop.
Originally I'd planned for an abbreviated side panel to line up with the seat base - which hid all the electrics nicely. The 7R seat base doesn't really lend itself to that, and it would hide the Weber !! It's an option. Plenty of room under the tail of the seat - and there's always the 1/2 fairing if push comes to shove.  ;)
« Last Edit: Apr 17, 2019, 14:25:03 by beachcomber »
Online irk miller
« Reply #811 on: Apr 14, 2019, 17:24:25 »
Interested in what you're doing for the fuel pump rig.  I installed a low pressure fuel pump on my BMW F650, which I've converted to dual TM34 carbs, and they want to flood.  Not sure if it's because of the float needle or what.
Offline cxman
« Reply #812 on: Apr 14, 2019, 18:13:52 »
need a different needle and seat to use a fuel pump they come with gravity feed needles and seats
« Last Edit: Apr 14, 2019, 18:15:51 by cxman »
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline beachcomber
  • TJ - Beachcomber
« Reply #813 on: Apr 15, 2019, 07:13:11 »
I'm also installing an inline fuel pressure regulator for the Weber circuit. No probs with the NOS feed.
Some peeps have asked about getting a base setting for the Weber. My Weber was one of a pair that was used on a 1500cc Cortina GT - so I'm taking a leap of faith in that one carb served 750cc !!!!! That should be close enough for me to play with.
Offline beachcomber
  • TJ - Beachcomber
« Reply #814 on: Apr 24, 2019, 18:20:58 »
Here's the 10.9 grade Hi-Po stud kit I commissioned from the company that does all the Hi-Po fixings for the RAM cars.
NEVER have a stud stretch / break again. Preserve those head gaskets. !!!   ;)
Nuts are Marine Grade A4 stainless.
I might be getting some made for Z1 / 900 etc.
Offline beachcomber
  • TJ - Beachcomber
« Reply #815 on: Apr 29, 2019, 08:21:42 »
Headers finally off to the Brough Superior man to be welded. ;) ;)He's got loads of work in at the moment, but hopes to fit it in the next 3-4 weeks. I've got another guy going to index the NOS nozzles for me and hopefully get a slightly better angle on the entry. Again - they will be rotated 180 degrees from the pic. That just leaves the DARC-2 ignition unit.
Offline beachcomber
  • TJ - Beachcomber
« Reply #816 on: May 14, 2019, 18:13:27 »
Headers away waiting to be welded - can't wait !
It's amazing trying to pick up after a 5 month forced layoff while my pal was in the US. It's taken us a complete morning just to find the parts we need for the next stages.
First off the fuel cell will be fitted into the belly fairing and all the mounts finished, then we can start laying in the fuel supply and feeds / overflows etc. The tank and seat will have to be mounted before we can plumb in the filler cap and tube as the filler will be mounted in the back of the seat bum stop.
The belly pan itself will need quite a bit of work as we had to cut and shut to get the fuel cell as low as possible in the fairing.
I'm not happy with the taper bearings we used for the headstock, for some reason they refuse to seat right down inside the headstock tube. So the forks have got to come off again to remedy that. Not too tragic as it will give us clear access where I want to mount the custom chassis plate.
While the front end's torn down I'll refit the hardware to the Grimeca 4LS brake plates and get the new spacers gold passivated, then it's just making the brake torque stays and then the front end's finished. Still looking for a fork brace if anyone's got one ??
By the time all that's completed the headers should be back and I can have a dummy fit of the exhaust and Weber to site the fuel / NOS lines.
Offline NoRiders
« Reply #817 on: May 16, 2019, 04:56:45 »
I'm glad I'm not the only one to lose new parts!
It's amazing how each part requires 2-3 other parts to be fitted to check clearances etc...talk about the hip bone's connected to the thigh bone which is connected to the knee bone...
Carry on :)
Offline beachcomber
  • TJ - Beachcomber
« Reply #818 on: May 16, 2019, 16:07:30 »
Carry on :)
I can't believe it either - my mate is OCD tidying fanatic and has boxes for everything.
Yep. hip bone, knee bone etc. The fuel cell has to be fitted before the tank and seat can be fitted, which has to be done before we can finalise to position of the footpegs, etc.,etc.,etc.............
Offline teazer
« Reply #819 on: May 16, 2019, 17:22:12 »
Beach, I just noticed you earlier comments about the source of that Weber.  1500 Cortina.  I hope this bike makes a lot more power than a complete 1500 motor, let along half of one. ;-)
Much as we all loved Cortina GTs and Lotus Cortinas, things have moved on a bit since then.  I think that the average POS grocery getter today makes more power than our old Ford motors of that era.  Even my old RS2000 (long gone but not forgotten) would be looked down on by a Civic owner today.
