Author Topic: "Tangerine Dream" / Glemseck - KZ750  (Read 142777 times)
Offline Turnturtle
Re: "Tangerine Dream" / Glemseck - KZ750
« Reply #590 on: Feb 08, 2018, 18:14:50 »
Better move it. Those viking zombies are going to chop it to bits!
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #591 on: Feb 09, 2018, 03:47:12 »
Nice! And yes I'd love to see the underside as well. I'll probably do something along the same lines with a GPZ-head for a Z1000J-engine.
My Blog:
Offline beachcomber
  • TJ - Beachcomber
« Reply #592 on: Feb 10, 2018, 08:30:22 »
yes - underside pix coming up  - just re-charging camera as we speak.
Time for blueprinting now. Nothing has been touched in the combustion chamber yet. With a blower polishing etc. doesn't really have any benefits for the amount of work involved, so it will just be careful matching and removal of any obvious "lumps". I always like to keep a full valve contact with blowers to aid cooling, so I won't be into a 3 angle valve job. There is just enough room for the second plug ! If I do another, I'll possibly go with a smaller dia. plug.
Vikings are there to guard !!!!
Offline beachcomber
  • TJ - Beachcomber
« Reply #593 on: Feb 12, 2018, 15:34:27 »
The next time you see this view - it will be shiny !!! ;)
Offline beachcomber
  • TJ - Beachcomber
« Reply #594 on: Mar 02, 2018, 07:42:54 »
Uncharted territory  ::).................. what do we think guys ?
The second plug .... short reach plug so the threads / body on the inside [ nearest crown ] are level with the opening where it enters combustion chamber and remove / smooth out the threads on the other side .... or - what ??  ???
Offline canyoncarver
  • 'hacking is learning'
« Reply #595 on: Mar 02, 2018, 12:01:01 »
Dual plugged shovelheads are similiar.  One plug is longer than the other.  Short reach plug on the second hole.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #596 on: Mar 02, 2018, 18:27:26 »
You never want the sparkplug threads to protrude beyonde the hole, so if that's only got depth for a short one, then that's the one to use.
Cheers,
Greg
My Blog:
Offline beachcomber
  • TJ - Beachcomber
« Reply #597 on: Mar 03, 2018, 10:43:57 »
Cheers,
Greg
yes, that was my thoughts Greg - nice for confirmation ! I'll "lose" the threads the other side where it's longer to get rid of potential "hot spots".
Offline beachcomber
  • TJ - Beachcomber
« Reply #598 on: Mar 07, 2018, 18:43:02 »
The belly pan finally arrived [ snowed in ! ::) ] and I got the fuel cell mocked up. Works out at 2.144 Imp gallons with a simple shape. Also room for the battery and or some electrics - the fuel pump is one obvious candidate. Just need to offer it all up to the rolling [ almost ] chassis as POC. The fuel fill pipe will come up behind the engine and there'll be a cut-out in the seat for access - central oil tank style.
Not long now before my pal is off to the US to work on his property - so I need to get as much done as possible before he goes. I've commissioned a set of +20% stronger clutch springs - see what they come out at price wise. Oh yes and the wire is a far better quality than the OEM jobbies. ;)
Offline beachcomber
  • TJ - Beachcomber
« Reply #599 on: Mar 09, 2018, 11:20:34 »
First POC fitting.  8) The fairing will go back 3" [ axle stands in the way ! ::) ] and the fuel cell will be 3" longer giving me 2.5 imp gallons. Fuel filler tube will go at the back of the engine and come out in the front seat area - like central oil tank filler caps on Manx, Dommie and Gold Star. There WILL be a fuel spill funnel feeding back to the tank as the battery will still probably go under the seat. If there's enough room - it might fit in the belly fairing.
The fuel pump will go in the front section and the whole thing will be modded cosmetically to make it "right".
